donwe123 Posted November 6, 2007 Posted November 6, 2007 Newbie here trying to turn a device on and off within a period of time randomly so I did this: -------------------------------------------------------------------------------- To turn on Lamp_Hall schedule 1: If From Sunset To 11:00PM Then Repeat 16 times (Random) Set 'Lamp_Hall' On Else -No Action- -------------------------------------------------------------------------------- To turn off Lamp_Hall schedule 2: If From Sunset To 11:00PM Then Repeat 8 times (Random) Set 'Lamp_Hall' Off Else -No Action- -------------------------------------------------------------------------------- It seems to turn on and off but it under status it shows idle:false Been playing with this for a while but unfornately not good at any programming languages. I'd appreciate any help anyone offers. Thanks in advance.
Chris Jahn Posted November 6, 2007 Posted November 6, 2007 These programs are both fine, although if the time is between sunset and 11:00PM it should show 'Idle: True'. Do the time and/or sunset/sunrise times appear correct? The sunset/rise times are off by one hour due to DST changeover, and thus make sure to go to configuration 'Synch the clock with computers time'. (This is a bug and is fixed for the next drop).
donwe123 Posted November 6, 2007 Author Posted November 6, 2007 Thank you Chris for the super fast reply. That's why people are saying you guys are the best in the indusdry. In response to the time and/or sunset/sunrise, they are correct and I have no problems. So it seems that if I check the Random box, status will show idle:true if current time falls in/between time set, and status will show idle:false if current time falls outside of time set. Is that correct?
Chris Jahn Posted November 6, 2007 Posted November 6, 2007 You should see 'Idle: True' if the current time is in between time range, and 'Idle: False' if the current time falls outside the time range, regardless of the 'Random Box' or any other actions you may have. Only the conditions in the 'If' control whether a program is True or False, the actions have no bearing on this.
donwe123 Posted November 7, 2007 Author Posted November 7, 2007 Thank you. How about this to make Appliance_1 on and off randomly within a given time: ------------------------------------------------------ To turn on: If From Sunset For 2 hours and 2 minutes Then Wait 20 minutes (Random) Repeat 16 times (Random) Set 'Appliance_1' On Else - No Actions - (To add one, press 'Action') ------------------------------------------------------ To turn off: If From Sunset For 2 hours and 8 minutes Then Wait 35 minutes (Random) Repeat 9 times (Random) Set 'Appliance_1' Off Else - No Actions - (To add one, press 'Action') ------------------------------------------------------ Thanks again.
Chris Jahn Posted November 7, 2007 Posted November 7, 2007 I think you are looking for something like this. This turns the light on at some time 20 minutes to an hour after Sunset, and turns it off 2 hours to 2 hours and 40 minutes later. If Time is Sunset + 20 minutes Then Wait 40 minutes (Random) Set 'Appliance_1' On Wait 2 hours Wait 40 minutes (Random) Set 'Appliance_1' Off Else - No Actions - (To add one, press 'Action')
donwe123 Posted November 7, 2007 Author Posted November 7, 2007 Your example shows that Appliance_1 is turned on and off once randomly within a given time. Can you show me an example to turned on and off Appliance_1 multiple times randomly within a given time?
Mark Sanctuary Posted November 7, 2007 Posted November 7, 2007 I don't think it can be done with the current command set. Random does not have a total run time argument. Repeat does not have a random argument. And grouping them in multiple ways does not add up.
Chris Jahn Posted November 7, 2007 Posted November 7, 2007 donwe123, Can you show me an example to turned on and off Appliance_1 multiple times randomly within a given time? This example turns 'Appliance_1' on and off multiple times randomly between sunset + 20 minutes to 11:30 PM every day. You can adjust the wait times if you want it to turn on/off more frequently. The 'Else' guarantees that the 'Appliance_1' will be turned off at 11:30PM If From Sunset + 20 minutes To 11:30:00PM (same day) Then Repeat Every 0 seconds Wait 10 minutes (Random) Set 'Appliance_1' On Wait 20 minutes Wait 10 minutes (Random) Set 'Appliance_1' Off Else Set 'Appliance_1' Off
donwe123 Posted November 8, 2007 Author Posted November 8, 2007 Thank you Chris and Mark. This has to be one of the friendliest forum anywhere. Chris, your example above is beautiful. In regards to adjusting the wait times if I want it to turn on/off more frequently, I would really like to but I am really not good at programming languages. Can you please tell me what 'Repeat Every 0 seconds' does? And how do I adjust the wait times to turn on/off more frequently?
donwe123 Posted November 8, 2007 Author Posted November 8, 2007 Chris, I think I got it! When you said I can adjust the wait times if I want it to turn on/off more frequently, I think it means that I can shorten the wait time even more so that device will turn on/off more frequently within that given time. Did I get it ?
Chris Jahn Posted November 8, 2007 Posted November 8, 2007 The 'Repeat' action repeats all actions following it, up to the end of the list or the next 'Repeat' action. Repeat Every X minutes repeats all actions following it every X minutes. If more than X minutes have elapsed when the list of actions is finished, then it repeats right away, otherwise it waits however much time is remaining and the repeats it. To adjust the wait time, adjust the number of minutes (or seconds) in the 'Wait' actions. In general, to wait between a range of time you would use two 'Wait' actions. For example, to wait between 20 and 30 minutes you would use: Wait 20 minutes Wait 10 minutes (Random) To wait between 10 and 15 minutes you would change it to: Wait 10 minutes Wait 5 minutes (Random)
Mark Sanctuary Posted November 8, 2007 Posted November 8, 2007 O shoot; I did not think of setting the If to control the length of time. Now I understand how you can do it.
Illusion Posted April 13, 2008 Posted April 13, 2008 If From Sunset + 20 minutes To 2:00:00AM (next day) Then Wait 20 minutes (Random) Set 'Bathroom Vanity' On Repeat 15 times Wait 20 minutes Wait 20 minutes (Random) Set 'Bathroom Vanity' Off Wait 20 minutes Wait 20 minutes (Random) Set 'Bathroom Vanity' On Else Wait 15 minutes (Random) Repeat 3 times Set 'Bathroom Vanity' Off Wait 2 seconds (Random) I am trying to refine this code. This is the template for my "Lived -In" away look. I have a program similar to this for each light that is part of the away look. Questions: 1. Is the 2.00am (next day) the proper code for this program to go false about 6 hours after going true (in the summer anyway)? 2. Could I change the repeat so the code would be: If From Sunset + 20 minutes To 2:00:00AM (next day) Then Wait 20 minutes (Random) Set 'Bathroom Vanity' On Repeat Every 0 seconds Wait 20 minutes Wait 20 minutes (Random) Set 'Bathroom Vanity' Off Wait 20 minutes Wait 20 minutes (Random) Set 'Bathroom Vanity' On Else Wait 15 minutes (Random) Repeat 3 times Set 'Bathroom Vanity' Off Wait 2 seconds (Random) I feel like this will not repeat at all (the repeat 0 seconds scares me), but from Chris' example this should work, no? I like the repeat every 0 seconds as I do not have to put a large repeat in there. I know that with a 15 times repeat it will work, but again I am trying to refine my programming. Chris, so 'repeat every 0 seconds' is nothing like 'repeat 0 times'? I know from reading other posts that 'repeat 0 times' effectively comments out programming lines, but are you saying that 'repeat every 0 seconds' does not? The wait 2 seconds (Random) at the end is for the X-10 lights mostly as I use this as a template for all my lights that I have not yet converted over to Insteon. This way if there is a transmission collision with another command the request gets resent. Oh, even more refined! Looking over my post I think I could change the code to be: If From Sunset To 2:00:00AM (next day) Then Repeat Every 0 seconds Wait 20 minutes Wait 20 minutes (Random) Set 'Bathroom Vanity' On Wait 20 minutes Wait 20 minutes (Random) Set 'Bathroom Vanity' Off Else Wait 15 minutes (Random) Repeat 3 times Set 'Bathroom Vanity' Off Wait 2 seconds (Random) This would do exactly what the first set of code did but with much less programming, right?
Chris Jahn Posted April 14, 2008 Posted April 14, 2008 Questions: 1. Is the 2.00am (next day) the proper code for this program to go false about 6 hours after going true (in the summer anyway)? Yes I feel like this will not repeat at all (the repeat 0 seconds scares me), but from Chris' example this should work, no? I like the repeat every 0 seconds as I do not have to put a large repeat in there. I know that with a 15 times repeat it will work, but again I am trying to refine my programming. Chris, so 'repeat every 0 seconds' is nothing like 'repeat 0 times'? I know from reading other posts that 'repeat 0 times' effectively comments out programming lines, but are you saying that 'repeat every 0 seconds' does not? 'Repeat Every 0 seconds' loops like you would expect; it loops until the program is stopped, or the Then or Else is run again. The wait 2 seconds (Random) at the end is for the X-10 lights mostly as I use this as a template for all my lights that I have not yet converted over to Insteon. This way if there is a transmission collision with another command the request gets resent. Not sure why you are using the (Random) option here for your two seconds. Oh, even more refined! Looking over my post I think I could change the code to be: If From Sunset To 2:00:00AM (next day) Then Repeat Every 0 seconds Wait 20 minutes Wait 20 minutes (Random) Set 'Bathroom Vanity' On Wait 20 minutes Wait 20 minutes (Random) Set 'Bathroom Vanity' Off Else Wait 15 minutes (Random) Repeat 3 times Set 'Bathroom Vanity' Off Wait 2 seconds (Random) This would do exactly what the first set of code did but with much less programming, right? Yes, looks good.
Illusion Posted April 14, 2008 Posted April 14, 2008 The 2 second random is because I have lots of lights using this template. If two off (X-10) requests happen to coincide the ISY will try each again at a slightly different time. Oh, wait! The only way two X-10 signals can collide is if they are sent from different transmitters simultaneously, and that can not happen here because the ISY uses only one transmitter. Doh... Okay that was pretty stupid. I will take the random 2 sec out when I clean up my start times and repeat 15 times. Thanks for getting back to me. I did also notice that in the end I ended up with almost exactly what you had posted earlier in this topic. Sometimes the ISY is so powerful with it's command set it can be hard to think about how little needs to be coded. Reading that post the first time I guess the power of those few lines did not sink in. I had to go the hard way myself to understand. The first version of my "Away-Look" template had each on and off cycle written as a separate line. After getting my head around it I have ended up with this very simple looking code that does exactly the same thing with 90% fewer code lines.
