v1.0.4 not running in PG3
Hi @simplextech,
Updated Polisy per Michel's last post via ssh. IoP on v5.4.0, PG3 on v3.0.41. After all rebooted and functioning normally I noticed ST-Inventory not connected. Version installed was 1.0.2, I stopped and started the node a number of times. Never would connect. I noticed you rolled out a new version this morning. But during restarts it was not updating. So I deleted the node and tried to reinstall in the same slot. It will not install. I tried installing in 2 other free slots, same results.
Thank you,
Tim
3/6/2022, 07:17:42 [pg3] debug: Stopping log stream for pg3frontend_YJPSY
3/6/2022, 07:17:55 [pg3] debug: Getting status for MyQ 00:0d:b9:59:39:b0 3cac3bad-92bb-40f4-966f-3b541e85c898
3/6/2022, 07:17:55 [pg3] info: [00:0d:b9:59:39:b0_10] tplkasactl reporting command DON
3/6/2022, 07:17:55 [pg3] debug: Scheduling http://localhost:8080/rest/ns/10/nodes/n010_tplkasactl/report/cmd/DON to group commandGroup
3/6/2022, 07:17:55 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:59:39:b0] :: [200] :: 7.062209ms - http://localhost:8080/rest/ns/10/nodes/n010_tplkasactl/report/cmd/DON
3/6/2022, 07:17:55 [pg3] debug: MQTT Results: [ns/command/00:0d:b9:59:39:b0,10] :: {"command":[{"address":"tplkasactl","success":true}]}
3/6/2022, 07:17:55 [pg3] debug: Scheduling http://localhost:8080/rest/ns/6/nodes/n006_cg085008f7c6/report/status/GV0/7397/58 to group statusGroup
3/6/2022, 07:17:55 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:59:39:b0] :: [200] :: 5.460989ms - http://localhost:8080/rest/ns/6/nodes/n006_cg085008f7c6/report/status/GV0/7397/58
3/6/2022, 07:17:55 [pg3] debug: SELECT * FROM driver WHERE (uuid, profileNum, address, driver) is ('00:0d:b9:59:39:b0', '6', 'cg085008f7c6', 'GV0')
3/6/2022, 07:17:55 [pg3] debug: UPDATE driver SET
        value = '7397',uom = '58',timeModified = 1646579875814
3/6/2022, 07:17:55 [pg3] debug: MQTT Results: [ns/status/00:0d:b9:59:39:b0,6] :: {"set":[{"address":"cg085008f7c6","driver":"GV0","value":"7397","uom":58}]}
3/6/2022, 07:17:55 [pg3] debug: Found info  {"found":true,"isActive":true,"isInstalled":true,"expiry":"2023-02-06T03:16:34.000Z"}
3/6/2022, 07:17:55 [pg3] info: set to expire on 2023-02-06T03:16:34.000Z
3/6/2022, 07:18:03 [pg3] debug: ########## {"docs":"https://github.com/simplextech/pg3_docs/tree/main/ST-Inventory","version":"1.0.4","status":"active","oauth":"","prem":true,"url":"https://pg3store.isy.io/v2/nodeservers/production/pg3_inventory.zip","name":"ST-Inventory","language":"node","nsdata":"","desc":"Inventory of ISY nodes.  Includes Insteon, Z-Wave, Scenes, Programs, Folders, Int and State Variables and Error log lines.","developer":"jeubanks@simplextech.net","ip_added":"107.77.204.108","purchaseOptions":[{"price":20,"isPerpetual":true}],"branch":"","uuid":"00:0d:b9:59:39:b0","ts_added":"1644790722","ts_updated":"1646539323","author":"Simplex Technology","price":20,"modified":"2022-03-06 04:02","profileNum":"17","nsid":"c126923a-afcd-4e6d-9e46-58576796f551","expires":0}
3/6/2022, 07:18:03 [pg3] info: [00:0d:b9:59:39:b0_17] :: Creating Nodeserver 'ST-Inventory'
3/6/2022, 07:18:04 [pg3] error: unhandledRejection REPORT THIS!: [object Promise], reason: Error: Request failed with status code 404
3/6/2022, 07:18:07 [pg3] debug: Sending logfile to frontend :: /var/polyglot/pg3/logs/pg3-current.log
3/6/2022, 07:18:16 [pg3] debug: Starting log stream for pg3frontend_YJPSY :: /var/polyglot/pg3/logs/pg3-current.log
3/6/2022, 07:18:25 [pg3] debug: Scheduling http://localhost:8080/rest/ns/2/nodes/n002_controller/report/status/GV1/18/0 to group statusGroup
3/6/2022, 07:18:25 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:59:39:b0] :: [200] :: 18.382399ms - http://localhost:8080/rest/ns/2/nodes/n002_controller/report/status/GV1/18/0
3/6/2022, 07:18:25 [pg3] debug: SELECT * FROM driver WHERE (uuid, profileNum, address, driver) is ('00:0d:b9:59:39:b0', '2', 'controller', 'GV1')
3/6/2022, 07:18:25 [pg3] debug: UPDATE driver SET
        value = '18',uom = '0',timeModified = 1646579905764
3/6/2022, 07:18:25 [pg3] debug: Scheduling http://localhost:8080/rest/ns/2/nodes/n002_controller/report/status/GV9/92598/0 to group statusGroup
3/6/2022, 07:18:25 [pg3] debug: MQTT Results: [ns/status/00:0d:b9:59:39:b0,2] :: {"set":[{"address":"controller","driver":"GV1","value":"18","uom":0}]}
3/6/2022, 07:18:25 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:59:39:b0] :: [200] :: 5.746094ms - http://localhost:8080/rest/ns/2/nodes/n002_controller/report/status/GV9/92598/0
3/6/2022, 07:18:25 [pg3] debug: SELECT * FROM driver WHERE (uuid, profileNum, address, driver) is ('00:0d:b9:59:39:b0', '2', 'controller', 'GV9')
        value = '92598',uom = '0',timeModified = 1646579905841
3/6/2022, 07:18:25 [pg3] debug: MQTT Results: [ns/status/00:0d:b9:59:39:b0,2] :: {"set":[{"address":"controller","driver":"GV9","value":"92598","uom":0}]}
3/6/2022, 07:18:55 [pg3] debug: Getting status for MyQ 00:0d:b9:59:39:b0 3cac3bad-92bb-40f4-966f-3b541e85c898
3/6/2022, 07:18:55 [pg3] debug: Scheduling http://localhost:8080/rest/ns/6/nodes/n006_cg085008f7c6/report/status/GV0/7457/58 to group statusGroup
3/6/2022, 07:18:55 [pg3] debug: ISY Response: [Try: 1] [00:0d:b9:59:39:b0] :: [200] :: 6.670109ms - http://localhost:8080/rest/ns/6/nodes/n006_cg085008f7c6/report/status/GV0/7457/58
3/6/2022, 07:18:55 [pg3] debug: SELECT * FROM driver WHERE (uuid, profileNum, address, driver) is ('00:0d:b9:59:39:b0', '6', 'cg085008f7c6', 'GV0')
3/6/2022, 07:18:55 [pg3] debug: UPDATE driver SET
        value = '7457',uom = '58',timeModified = 1646579935682
3/6/2022, 07:18:55 [pg3] debug: MQTT Results: [ns/status/00:0d:b9:59:39:b0,6] :: {"set":[{"address":"cg085008f7c6","driver":"GV0","value":"7457","uom":58}]}
3/6/2022, 07:18:55 [pg3] debug: Found info  {"found":true,"isActive":true,"isInstalled":true,"expiry":"2023-02-06T03:16:34.000Z"}
3/6/2022, 07:18:55 [pg3] info: set to expire on 2023-02-06T03:16:34.000Z
I'm aware that the NS is not installing or updating.  The update has no functionality just a version change trying to work out problems with the NS store.  There is a store problem with production vs beta packages in the store.  Before it was delivering the beta package even for production installs and now it's not delivering any package.
The UD developer working on this was informed last night.
