April 16, 20223 yr I wanted to test out the Polisy to see what I smart devices I can migrate to now that Insteon is not accessable. I was able to follow the instructions and access Polisy through a browser. The Admin Consul would not respond to commands . Then I checked the info and fount that the PLM was not connecting. I used the serial cable connection on my Polisy and the RJ45 port on my PLM. Now I can use the Polisy to connect to Insteon. Wish I knew
April 16, 20223 yr Try using the ISY Launcher. Here's the link. https://isy.universal-devices.com/start.jnlp
April 16, 20223 yr 23 minutes ago, design lighting said: I wanted to test out the Polisy to see what I smart devices I can migrate to now that Insteon is not accessable. I was able to follow the instructions and access Polisy through a browser. The Admin Consul would not respond to commands . Then I checked the info and fount that the PLM was not connecting. I used the serial cable connection on my Polisy and the RJ45 port on my PLM. Now I can use the Polisy to connect to Insteon. Wish I knew The PLM needs to be booted up first. it must be connected to Polisy when Polisy starts or Polisy won't detect the port. Are you having trouble starting the admin console and getting connected to Polisy? Or was it simply not responding because of the PLM issue? If you need more admin console help tell us if you are using Windows or a Mac.
