Acurite Node Server not seeing all my sensors.
@JPaul As of 8:12 pm Eastern time Looks like it is getting closer. Closest strike and Last strike are matching what my dashboard is saying. The Strike count per day is incrementing however it does not match my dashboard. At one point it was at 11 and the next time I looked it was back to 5. If we do not get any new strikes in a few minutes it looks like it is reseting the Strikes today count.
Here is part of the log:
2022-06-16 20:07:04,868 Thread-54 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV3', 'value': '0', 'uom': '45'}]}
2022-06-16 20:07:04,870 Thread-54 udi_interface DEBUG AcuriteController:discover: Device Id: 313855
2022-06-16 20:07:04,871 Thread-54 udi_interface DEBUG AcuriteController:discover: Device Name: AC Temps
2022-06-16 20:07:04,872 Thread-54 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 313855, "name": "AC Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 3, "last_check_in_at": "2022-06-17T00:06:57.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "78.6", "temp_high_at": "6:41 PM", "temp_low_value": "53.0", "temp_low_at": "3:41 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2017-01-11T17:01:42.630Z", "sensors": [{"id": 1211149, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "69.8", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 1211150, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "86", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 1211151, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "66", "channel": 3, "chart_unit": "F"}, {"id": 1211148, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.05", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:07:04,872 Thread-54 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:07:04,873 Thread-54 udi_interface INFO AcuriteController:discover: Node 313855 already exists, skipping
2022-06-16 20:07:04,874 Thread-54 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV1's value
2022-06-16 20:07:04,874 Thread-54 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV2's value
2022-06-16 20:07:04,994 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV8 to 6 UOM 116
2022-06-16 20:07:05,095 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV3 to 0 UOM 45
2022-06-16 20:07:05,380 Thread-54 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set CLITEMP to 69.8 to Polyglot
2022-06-16 20:07:05,381 Thread-54 udi_interface.node DEBUG node:reportDriver: Updating value to 69.8
2022-06-16 20:07:05,381 Thread-54 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'CLITEMP', 'value': '69.8', 'uom': '17'}]}
2022-06-16 20:07:05,383 Thread-54 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Temp: 69.8 F
2022-06-16 20:07:05,532 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: CLITEMP to 69.8 UOM 17
2022-06-16 20:07:05,977 Thread-54 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set CLIHUM to 86 to Polyglot
2022-06-16 20:07:05,978 Thread-54 udi_interface.node DEBUG node:reportDriver: Updating value to 86
2022-06-16 20:07:05,978 Thread-54 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'CLIHUM', 'value': '86', 'uom': '22'}]}
2022-06-16 20:07:05,980 Thread-54 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Humidity: 86 %RH
2022-06-16 20:07:06,109 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: CLIHUM to 86 UOM 22
2022-06-16 20:07:06,458 Thread-54 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set DEWPT to 66 to Polyglot
2022-06-16 20:07:06,459 Thread-54 udi_interface.node DEBUG node:reportDriver: Updating value to 66
2022-06-16 20:07:06,460 Thread-54 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'DEWPT', 'value': '66', 'uom': '17'}]}
2022-06-16 20:07:06,461 Thread-54 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Dew Point: 66 F
2022-06-16 20:07:06,592 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: DEWPT to 66 UOM 17
2022-06-16 20:07:06,941 Thread-54 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in BARPRES's value
2022-06-16 20:07:06,942 Thread-54 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Barometric Pressure: 30.05 inHg
2022-06-16 20:07:06,942 Thread-54 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set GV3 to 0 to Polyglot
2022-06-16 20:07:06,943 Thread-54 udi_interface.node DEBUG node:reportDriver: Updating value to 0
2022-06-16 20:07:06,944 Thread-54 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'GV3', 'value': '0', 'uom': '45'}]}
2022-06-16 20:07:06,946 Thread-54 udi_interface DEBUG AcuriteController:discover: Device Id: 1065633
2022-06-16 20:07:06,946 Thread-54 udi_interface DEBUG AcuriteController:discover: Device Name: Bedroom Temps
2022-06-16 20:07:06,948 Thread-54 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 1065633, "name": "Bedroom Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 4, "last_check_in_at": "2022-06-17T00:06:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "79.7", "temp_high_at": "12:46 PM", "temp_low_value": "77.5", "temp_low_at": "1:36 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2020-09-06T21:46:43.678Z", "sensors": [{"id": 5041656, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "78.4", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 5041657, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "49", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 5041658, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 5041655, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.05", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:07:06,948 Thread-54 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:07:06,949 Thread-54 udi_interface INFO AcuriteController:discover: Node 1065633 already exists, skipping
2022-06-16 20:07:06,950 Thread-54 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV1's value
2022-06-16 20:07:06,950 Thread-54 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV2's value
2022-06-16 20:07:07,070 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: GV3 to 0 UOM 45
2022-06-16 20:07:07,426 Thread-54 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLITEMP's value
2022-06-16 20:07:07,427 Thread-54 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Temp: 78.4 F
2022-06-16 20:07:07,873 Thread-54 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLIHUM's value
2022-06-16 20:07:07,873 Thread-54 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Humidity: 49 %RH
2022-06-16 20:07:08,319 Thread-54 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in DEWPT's value
2022-06-16 20:07:08,319 Thread-54 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Dew Point: 58 F
2022-06-16 20:07:08,772 Thread-54 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in BARPRES's value
2022-06-16 20:07:08,773 Thread-54 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Barometric Pressure: 30.05 inHg
2022-06-16 20:07:08,774 Thread-54 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set GV3 to 0 to Polyglot
2022-06-16 20:07:08,774 Thread-54 udi_interface.node DEBUG node:reportDriver: Updating value to 0
2022-06-16 20:07:08,775 Thread-54 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'GV3', 'value': '0', 'uom': '45'}]}
2022-06-16 20:07:08,777 Thread-54 udi_interface INFO AcuriteController:query: AcuriteController - query
2022-06-16 20:07:08,878 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: GV3 to 0 UOM 45
2022-06-16 20:07:58,102 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2022-06-16 20:07:58,104 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2022-06-16 20:07:58,106 Thread-55 udi_interface INFO AcuriteController:poll: shortPoll (controller)
2022-06-16 20:07:58,107 Thread-55 udi_interface INFO AcuriteController:discover: Starting Acurite Device Discovery
2022-06-16 20:07:58,107 Thread-55 udi_interface INFO AcuriteController:discover: acurite_user: tlightne@aim.com
2022-06-16 20:07:58,968 Thread-55 udi_interface INFO AcuriteManager:login: Login HTTP Status Code: 200
2022-06-16 20:07:58,970 Thread-55 udi_interface DEBUG AcuriteManager:login: {"token_id": "e737091c-546e-458b-a322-3312ca561e09", "user": {"id": 34604, "email": "tlightne@aim.com", "first_name": "Terry", "last_name": "Lightner", "full_name": "Terry Lightner", "language": "en/us", "session_timeout": 7776000, "failed_login_count": 15, "is_locked": false, "default_user_contact_id": 38708, "password_set_token": null, "permissions": ["Account User-32858", "Account User-32858-Clock", "Account User-32858-Sensor", "Account User-32858-Bell Controller", "Account Admin-32858", "Account Admin-32858-Clock", "Account Admin-32858-Sensor", "Account Admin-32858-Bell Controller", "Account Manager-32858", "Account Manager-32858-Clock", "Account Manager-32858-Sensor", "Account Manager-32858-Bell Controller", "Network Admin-32858", "Network Admin-32858-Clock", "Network Admin-32858-Sensor", "Network Admin-32858-Bell Controller"], "user_contacts": [{"id": 38708, "user_id": 34604, "contact_type": "email", "value": "tlightne@aim.com", "name": "Default email", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 52558, "user_id": 34604, "contact_type": "android", "value": "fXomgUZZOZc:APA91bGp5qAhdyu9QgEneDASam1286SxRRp-VO6yv7rZLrS2ykL6KGI8Uj5XnGcee8-iWYvjqpg5LYbH_6Tzj9K9IAkF3xiIb6eQvY87sB_f1Bwj_KftKcGLVQ3iyUto1ZoOsEJx8cQP", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/51452137-2b9e-3daf-86e9-131a661185bc", "mri_monitor_states": []}, {"id": 60620, "user_id": 34604, "contact_type": "phone", "value": "9417180409", "name": "AC Temps", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 509896, "user_id": 34604, "contact_type": "android", "value": "fXANtCdsSu6DSZhlP5_SNk:APA91bGYor1EZCr-H4NbxXXGGvJxLLDRyC8FrKHBkf2hdSuu0PZUTdzS9k08QDOU2h0C9ushtIG2-5pVgyZwsiGxx7JTy87oZQtU4RLrEKeWOonZR-CSFooC2Ym6KbVEAzh64-hndgEr", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/f97f465d-27db-3345-88b9-281db46deeec", "mri_monitor_states": []}], "account_users": [{"id": 34744, "account_id": 32858, "is_active": true, "web_theme": "light", "account": {"id": 32858, "name": "MAR Acct", "street_address_1": "3275 26th Ave East Lot 7", "street_address_2": "", "city": "Bradenton", "state_province": "FL", "zip": "34208", "country_code": "US", "show_tenths": true, "measurement_system_id": 1, "timezone": "America/New_York", "map_center_point": {"lat": 0.0, "lng": 0.0}, "map_zoom_level": 8, "map_view": "current_temp", "map_views": ["current_temp", "todays_rain", "current_wind"], "measurement_system_units": {"LightningClosestStrikeDist": "MI", "IndoorTemperature": "F", "IndoorHumidity": "%", "LightningLastStrikeDist": "MI", "Water Leak": "V", "Temperature": "F", "Humidity": "%", "WaterFlowRate": "gal", "WaterTemp": "F", "Barometric Pressure": "inHg", "Wind Speed": "mph", "Rainfall": "in", "Rainrate": "in", "Feels Like": "F", "Dew Point": "F", "Heat Index": "F", "Wind Chill": "F", "Soil Temp": "F", "Remote Temp": "F", "Remote Humid": "%", "WindSpeedAvg": "mph"}, "time_format": "12_hour", "date_format": "mm/dd", "header_images": [], "background_images": []}}]}}
2022-06-16 20:08:00,274 Thread-55 udi_interface INFO AcuriteManager:getHubDevices: Got Acurite Devices
2022-06-16 20:08:00,275 Thread-55 udi_interface DEBUG AcuriteController:discover: Device Id: 943425
2022-06-16 20:08:00,276 Thread-55 udi_interface DEBUG AcuriteController:discover: Device Name: Lightning Tower
2022-06-16 20:08:00,277 Thread-55 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 943425, "name": "Lightning Tower", "model_code": "LightningT", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 1, "last_check_in_at": "2022-06-17T00:06:57.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-17.json"], "temp_high_value": "97.6", "temp_high_at": "12:36 PM", "temp_low_value": "75.6", "temp_low_at": "5:56 AM", "daily_cumulative_strikes": 46, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2019-10-02T21:32:52.220Z", "sensors": [{"id": 4356815, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "84.5", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 4356814, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "81", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 4356813, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "37", "channel": 3, "chart_unit": "F"}, {"id": 4356812, "sensor_code": "Heat Index", "sensor_name": "Heat Index", "last_reading_value": "96", "channel": 4, "chart_unit": "F"}, {"id": 4356811, "sensor_code": "Interference", "sensor_name": "Interference", "last_reading_value": "1", "channel": 5, "chart_unit": null}, {"id": 4356807, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.05", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [{"id": 4356810, "sensor_code": "LightningStrikeCnt", "sensor_name": "Lightning Strike Count", "last_reading_value": "15", "channel": 6, "chart_unit": null}, {"id": 4356809, "sensor_code": "LightningClosestStrikeDist", "sensor_name": "Lightning Closest Strike Distance", "last_reading_value": "6", "channel": 7, "chart_unit": "MI"}, {"id": 4356808, "sensor_code": "LightningLastStrikeDist", "sensor_name": "Lightning Last Strike Distance", "last_reading_value": "6", "channel": 8, "chart_unit": "MI"}], "model": {"id": 6077, "code": "LightningT", "description": "Lightning Tower", "has_wifi": false}}
2022-06-16 20:08:00,278 Thread-55 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:08:00,278 Thread-55 udi_interface INFO AcuriteController:discover: Node 943425 already exists, skipping
2022-06-16 20:08:00,279 Thread-55 udi_interface DEBUG AcuriteLightningTNode:update: AcuriteLightningTNode - update
2022-06-16 20:08:00,280 Thread-55 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV1's value
2022-06-16 20:08:00,280 Thread-55 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV2's value
2022-06-16 20:08:01,023 Thread-55 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLITEMP's value
2022-06-16 20:08:01,024 Thread-55 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Temp: 84.5 F
2022-06-16 20:08:01,657 Thread-55 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLIHUM's value
2022-06-16 20:08:01,658 Thread-55 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Humidity: 81 %RH
2022-06-16 20:08:02,111 Thread-55 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in DEWPT's value
2022-06-16 20:08:02,111 Thread-55 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Dew Point: 37 F
2022-06-16 20:08:02,566 Thread-55 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in BARPRES's value
2022-06-16 20:08:02,567 Thread-55 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Barometric Pressure: 30.05 inHg
2022-06-16 20:08:03,330 Thread-55 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV4's value
2022-06-16 20:08:03,331 Thread-55 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Heat Index: 96 F
2022-06-16 20:08:03,778 Thread-55 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV5's value
2022-06-16 20:08:03,779 Thread-55 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Strike Count: 15 None
2022-06-16 20:08:04,223 Thread-55 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV6's value
2022-06-16 20:08:04,224 Thread-55 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Last Strike Distance: 6 MI
2022-06-16 20:08:04,666 Thread-55 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV8's value
2022-06-16 20:08:04,666 Thread-55 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Closest Strike Distance: 6 MI
2022-06-16 20:08:04,667 Thread-55 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV3 to 1 to Polyglot
2022-06-16 20:08:04,668 Thread-55 udi_interface.node DEBUG node:reportDriver: Updating value to 1
2022-06-16 20:08:04,668 Thread-55 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV3', 'value': '1', 'uom': '45'}]}
2022-06-16 20:08:04,671 Thread-55 udi_interface DEBUG AcuriteController:discover: Device Id: 313855
2022-06-16 20:08:04,671 Thread-55 udi_interface DEBUG AcuriteController:discover: Device Name: AC Temps
2022-06-16 20:08:04,673 Thread-55 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 313855, "name": "AC Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 3, "last_check_in_at": "2022-06-17T00:06:57.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "78.6", "temp_high_at": "6:41 PM", "temp_low_value": "53.0", "temp_low_at": "3:41 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2017-01-11T17:01:42.630Z", "sensors": [{"id": 1211149, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "69.8", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 1211150, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "86", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 1211151, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "66", "channel": 3, "chart_unit": "F"}, {"id": 1211148, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.05", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:08:04,673 Thread-55 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:08:04,674 Thread-55 udi_interface INFO AcuriteController:discover: Node 313855 already exists, skipping
2022-06-16 20:08:04,675 Thread-55 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV1's value
2022-06-16 20:08:04,675 Thread-55 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV2's value
2022-06-16 20:08:04,807 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV3 to 1 UOM 45
2022-06-16 20:08:05,156 Thread-55 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLITEMP's value
2022-06-16 20:08:05,157 Thread-55 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Temp: 69.8 F
2022-06-16 20:08:05,603 Thread-55 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLIHUM's value
2022-06-16 20:08:05,603 Thread-55 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Humidity: 86 %RH
2022-06-16 20:08:06,174 Thread-55 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in DEWPT's value
2022-06-16 20:08:06,174 Thread-55 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Dew Point: 66 F
2022-06-16 20:08:06,667 Thread-55 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in BARPRES's value
2022-06-16 20:08:06,668 Thread-55 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Barometric Pressure: 30.05 inHg
2022-06-16 20:08:06,669 Thread-55 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set GV3 to 1 to Polyglot
2022-06-16 20:08:06,669 Thread-55 udi_interface.node DEBUG node:reportDriver: Updating value to 1
2022-06-16 20:08:06,670 Thread-55 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'GV3', 'value': '1', 'uom': '45'}]}
2022-06-16 20:08:06,672 Thread-55 udi_interface DEBUG AcuriteController:discover: Device Id: 1065633
2022-06-16 20:08:06,673 Thread-55 udi_interface DEBUG AcuriteController:discover: Device Name: Bedroom Temps
2022-06-16 20:08:06,674 Thread-55 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 1065633, "name": "Bedroom Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 4, "last_check_in_at": "2022-06-17T00:06:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "79.7", "temp_high_at": "12:46 PM", "temp_low_value": "77.5", "temp_low_at": "1:36 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2020-09-06T21:46:43.678Z", "sensors": [{"id": 5041656, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "78.4", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 5041657, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "49", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 5041658, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 5041655, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.05", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:08:06,675 Thread-55 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:08:06,675 Thread-55 udi_interface INFO AcuriteController:discover: Node 1065633 already exists, skipping
2022-06-16 20:08:06,676 Thread-55 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV1's value
2022-06-16 20:08:06,676 Thread-55 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV2's value
2022-06-16 20:08:06,812 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: GV3 to 1 UOM 45
2022-06-16 20:08:07,154 Thread-55 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLITEMP's value
2022-06-16 20:08:07,155 Thread-55 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Temp: 78.4 F
2022-06-16 20:08:07,601 Thread-55 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLIHUM's value
2022-06-16 20:08:07,601 Thread-55 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Humidity: 49 %RH
2022-06-16 20:08:08,049 Thread-55 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in DEWPT's value
2022-06-16 20:08:08,050 Thread-55 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Dew Point: 58 F
2022-06-16 20:08:08,493 Thread-55 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in BARPRES's value
2022-06-16 20:08:08,493 Thread-55 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Barometric Pressure: 30.05 inHg
2022-06-16 20:08:08,494 Thread-55 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set GV3 to 1 to Polyglot
2022-06-16 20:08:08,495 Thread-55 udi_interface.node DEBUG node:reportDriver: Updating value to 1
2022-06-16 20:08:08,495 Thread-55 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'GV3', 'value': '1', 'uom': '45'}]}
2022-06-16 20:08:08,497 Thread-55 udi_interface INFO AcuriteController:query: AcuriteController - query
2022-06-16 20:08:08,607 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: GV3 to 1 UOM 45
2022-06-16 20:08:58,110 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2022-06-16 20:08:58,112 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2022-06-16 20:08:58,114 Thread-56 udi_interface INFO AcuriteController:poll: shortPoll (controller)
2022-06-16 20:08:58,115 Thread-56 udi_interface INFO AcuriteController:discover: Starting Acurite Device Discovery
2022-06-16 20:08:58,115 Thread-56 udi_interface INFO AcuriteController:discover: acurite_user: tlightne@aim.com
2022-06-16 20:08:58,965 Thread-56 udi_interface INFO AcuriteManager:login: Login HTTP Status Code: 200
2022-06-16 20:08:58,966 Thread-56 udi_interface DEBUG AcuriteManager:login: {"token_id": "7991c717-d494-40be-a155-247ca414313b", "user": {"id": 34604, "email": "tlightne@aim.com", "first_name": "Terry", "last_name": "Lightner", "full_name": "Terry Lightner", "language": "en/us", "session_timeout": 7776000, "failed_login_count": 15, "is_locked": false, "default_user_contact_id": 38708, "password_set_token": null, "permissions": ["Account User-32858", "Account User-32858-Clock", "Account User-32858-Sensor", "Account User-32858-Bell Controller", "Account Admin-32858", "Account Admin-32858-Clock", "Account Admin-32858-Sensor", "Account Admin-32858-Bell Controller", "Account Manager-32858", "Account Manager-32858-Clock", "Account Manager-32858-Sensor", "Account Manager-32858-Bell Controller", "Network Admin-32858", "Network Admin-32858-Clock", "Network Admin-32858-Sensor", "Network Admin-32858-Bell Controller"], "user_contacts": [{"id": 38708, "user_id": 34604, "contact_type": "email", "value": "tlightne@aim.com", "name": "Default email", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 52558, "user_id": 34604, "contact_type": "android", "value": "fXomgUZZOZc:APA91bGp5qAhdyu9QgEneDASam1286SxRRp-VO6yv7rZLrS2ykL6KGI8Uj5XnGcee8-iWYvjqpg5LYbH_6Tzj9K9IAkF3xiIb6eQvY87sB_f1Bwj_KftKcGLVQ3iyUto1ZoOsEJx8cQP", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/51452137-2b9e-3daf-86e9-131a661185bc", "mri_monitor_states": []}, {"id": 60620, "user_id": 34604, "contact_type": "phone", "value": "9417180409", "name": "AC Temps", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 509896, "user_id": 34604, "contact_type": "android", "value": "fXANtCdsSu6DSZhlP5_SNk:APA91bGYor1EZCr-H4NbxXXGGvJxLLDRyC8FrKHBkf2hdSuu0PZUTdzS9k08QDOU2h0C9ushtIG2-5pVgyZwsiGxx7JTy87oZQtU4RLrEKeWOonZR-CSFooC2Ym6KbVEAzh64-hndgEr", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/f97f465d-27db-3345-88b9-281db46deeec", "mri_monitor_states": []}], "account_users": [{"id": 34744, "account_id": 32858, "is_active": true, "web_theme": "light", "account": {"id": 32858, "name": "MAR Acct", "street_address_1": "3275 26th Ave East Lot 7", "street_address_2": "", "city": "Bradenton", "state_province": "FL", "zip": "34208", "country_code": "US", "show_tenths": true, "measurement_system_id": 1, "timezone": "America/New_York", "map_center_point": {"lat": 0.0, "lng": 0.0}, "map_zoom_level": 8, "map_view": "current_temp", "map_views": ["current_temp", "todays_rain", "current_wind"], "measurement_system_units": {"LightningClosestStrikeDist": "MI", "IndoorTemperature": "F", "IndoorHumidity": "%", "LightningLastStrikeDist": "MI", "Water Leak": "V", "Temperature": "F", "Humidity": "%", "WaterFlowRate": "gal", "WaterTemp": "F", "Barometric Pressure": "inHg", "Wind Speed": "mph", "Rainfall": "in", "Rainrate": "in", "Feels Like": "F", "Dew Point": "F", "Heat Index": "F", "Wind Chill": "F", "Soil Temp": "F", "Remote Temp": "F", "Remote Humid": "%", "WindSpeedAvg": "mph"}, "time_format": "12_hour", "date_format": "mm/dd", "header_images": [], "background_images": []}}]}}
2022-06-16 20:09:00,413 Thread-56 udi_interface INFO AcuriteManager:getHubDevices: Got Acurite Devices
2022-06-16 20:09:00,414 Thread-56 udi_interface DEBUG AcuriteController:discover: Device Id: 943425
2022-06-16 20:09:00,415 Thread-56 udi_interface DEBUG AcuriteController:discover: Device Name: Lightning Tower
2022-06-16 20:09:00,416 Thread-56 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 943425, "name": "Lightning Tower", "model_code": "LightningT", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 1, "last_check_in_at": "2022-06-17T00:06:57.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-17.json"], "temp_high_value": "97.6", "temp_high_at": "12:36 PM", "temp_low_value": "75.6", "temp_low_at": "5:56 AM", "daily_cumulative_strikes": 46, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2019-10-02T21:32:52.220Z", "sensors": [{"id": 4356815, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "84.5", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 4356814, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "81", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 4356813, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "37", "channel": 3, "chart_unit": "F"}, {"id": 4356812, "sensor_code": "Heat Index", "sensor_name": "Heat Index", "last_reading_value": "96", "channel": 4, "chart_unit": "F"}, {"id": 4356811, "sensor_code": "Interference", "sensor_name": "Interference", "last_reading_value": "1", "channel": 5, "chart_unit": null}, {"id": 4356807, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.05", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [{"id": 4356810, "sensor_code": "LightningStrikeCnt", "sensor_name": "Lightning Strike Count", "last_reading_value": "15", "channel": 6, "chart_unit": null}, {"id": 4356809, "sensor_code": "LightningClosestStrikeDist", "sensor_name": "Lightning Closest Strike Distance", "last_reading_value": "6", "channel": 7, "chart_unit": "MI"}, {"id": 4356808, "sensor_code": "LightningLastStrikeDist", "sensor_name": "Lightning Last Strike Distance", "last_reading_value": "6", "channel": 8, "chart_unit": "MI"}], "model": {"id": 6077, "code": "LightningT", "description": "Lightning Tower", "has_wifi": false}}
2022-06-16 20:09:00,417 Thread-56 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:09:00,417 Thread-56 udi_interface INFO AcuriteController:discover: Node 943425 already exists, skipping
2022-06-16 20:09:00,418 Thread-56 udi_interface DEBUG AcuriteLightningTNode:update: AcuriteLightningTNode - update
2022-06-16 20:09:00,419 Thread-56 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV1's value
2022-06-16 20:09:00,420 Thread-56 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV2's value
2022-06-16 20:09:01,156 Thread-56 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLITEMP's value
2022-06-16 20:09:01,157 Thread-56 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Temp: 84.5 F
2022-06-16 20:09:01,724 Thread-56 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLIHUM's value
2022-06-16 20:09:01,725 Thread-56 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Humidity: 81 %RH
2022-06-16 20:09:02,174 Thread-56 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in DEWPT's value
2022-06-16 20:09:02,175 Thread-56 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Dew Point: 37 F
2022-06-16 20:09:02,629 Thread-56 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in BARPRES's value
2022-06-16 20:09:02,629 Thread-56 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Barometric Pressure: 30.05 inHg
2022-06-16 20:09:03,390 Thread-56 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV4's value
2022-06-16 20:09:03,391 Thread-56 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Heat Index: 96 F
2022-06-16 20:09:03,832 Thread-56 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV5's value
2022-06-16 20:09:03,833 Thread-56 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Strike Count: 15 None
2022-06-16 20:09:04,279 Thread-56 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV6's value
2022-06-16 20:09:04,279 Thread-56 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Last Strike Distance: 6 MI
2022-06-16 20:09:04,725 Thread-56 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV8's value
2022-06-16 20:09:04,725 Thread-56 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Closest Strike Distance: 6 MI
2022-06-16 20:09:04,726 Thread-56 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV3 to 2 to Polyglot
2022-06-16 20:09:04,727 Thread-56 udi_interface.node DEBUG node:reportDriver: Updating value to 2
2022-06-16 20:09:04,727 Thread-56 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV3', 'value': '2', 'uom': '45'}]}
2022-06-16 20:09:04,729 Thread-56 udi_interface DEBUG AcuriteController:discover: Device Id: 313855
2022-06-16 20:09:04,730 Thread-56 udi_interface DEBUG AcuriteController:discover: Device Name: AC Temps
2022-06-16 20:09:04,731 Thread-56 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 313855, "name": "AC Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 3, "last_check_in_at": "2022-06-17T00:06:57.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "78.6", "temp_high_at": "6:41 PM", "temp_low_value": "53.0", "temp_low_at": "3:41 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2017-01-11T17:01:42.630Z", "sensors": [{"id": 1211149, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "69.8", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 1211150, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "86", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 1211151, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "66", "channel": 3, "chart_unit": "F"}, {"id": 1211148, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.05", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:09:04,731 Thread-56 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:09:04,732 Thread-56 udi_interface INFO AcuriteController:discover: Node 313855 already exists, skipping
2022-06-16 20:09:04,733 Thread-56 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV1's value
2022-06-16 20:09:04,733 Thread-56 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV2's value
2022-06-16 20:09:04,857 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV3 to 2 UOM 45
2022-06-16 20:09:05,218 Thread-56 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLITEMP's value
2022-06-16 20:09:05,219 Thread-56 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Temp: 69.8 F
2022-06-16 20:09:05,668 Thread-56 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLIHUM's value
2022-06-16 20:09:05,668 Thread-56 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Humidity: 86 %RH
2022-06-16 20:09:06,161 Thread-56 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in DEWPT's value
2022-06-16 20:09:06,162 Thread-56 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Dew Point: 66 F
2022-06-16 20:09:06,827 Thread-56 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in BARPRES's value
2022-06-16 20:09:06,828 Thread-56 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Barometric Pressure: 30.05 inHg
2022-06-16 20:09:06,829 Thread-56 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set GV3 to 2 to Polyglot
2022-06-16 20:09:06,830 Thread-56 udi_interface.node DEBUG node:reportDriver: Updating value to 2
2022-06-16 20:09:06,830 Thread-56 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'GV3', 'value': '2', 'uom': '45'}]}
2022-06-16 20:09:06,832 Thread-56 udi_interface DEBUG AcuriteController:discover: Device Id: 1065633
2022-06-16 20:09:06,833 Thread-56 udi_interface DEBUG AcuriteController:discover: Device Name: Bedroom Temps
2022-06-16 20:09:06,834 Thread-56 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 1065633, "name": "Bedroom Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 4, "last_check_in_at": "2022-06-17T00:06:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "79.7", "temp_high_at": "12:46 PM", "temp_low_value": "77.5", "temp_low_at": "1:36 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2020-09-06T21:46:43.678Z", "sensors": [{"id": 5041656, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "78.4", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 5041657, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "49", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 5041658, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 5041655, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.05", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:09:06,835 Thread-56 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:09:06,835 Thread-56 udi_interface INFO AcuriteController:discover: Node 1065633 already exists, skipping
2022-06-16 20:09:06,836 Thread-56 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV1's value
2022-06-16 20:09:06,837 Thread-56 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV2's value
2022-06-16 20:09:06,964 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: GV3 to 2 UOM 45
2022-06-16 20:09:07,320 Thread-56 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLITEMP's value
2022-06-16 20:09:07,320 Thread-56 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Temp: 78.4 F
2022-06-16 20:09:07,766 Thread-56 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLIHUM's value
2022-06-16 20:09:07,766 Thread-56 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Humidity: 49 %RH
2022-06-16 20:09:08,216 Thread-56 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in DEWPT's value
2022-06-16 20:09:08,217 Thread-56 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Dew Point: 58 F
2022-06-16 20:09:08,659 Thread-56 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in BARPRES's value
2022-06-16 20:09:08,660 Thread-56 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Barometric Pressure: 30.05 inHg
2022-06-16 20:09:08,661 Thread-56 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set GV3 to 2 to Polyglot
2022-06-16 20:09:08,661 Thread-56 udi_interface.node DEBUG node:reportDriver: Updating value to 2
2022-06-16 20:09:08,662 Thread-56 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'GV3', 'value': '2', 'uom': '45'}]}
2022-06-16 20:09:08,664 Thread-56 udi_interface INFO AcuriteController:query: AcuriteController - query
2022-06-16 20:09:08,767 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: GV3 to 2 UOM 45
2022-06-16 20:10:00,420 Thread-58 udi_interface INFO AcuriteManager:getHubDevices: Got Acurite Devices
2022-06-16 20:10:00,422 Thread-58 udi_interface DEBUG AcuriteController:discover: Device Id: 943425
2022-06-16 20:10:00,422 Thread-58 udi_interface DEBUG AcuriteController:discover: Device Name: Lightning Tower
2022-06-16 20:10:00,424 Thread-58 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 943425, "name": "Lightning Tower", "model_code": "LightningT", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 1, "last_check_in_at": "2022-06-17T00:06:57.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-17.json"], "temp_high_value": "97.6", "temp_high_at": "12:36 PM", "temp_low_value": "75.6", "temp_low_at": "5:56 AM", "daily_cumulative_strikes": 46, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2019-10-02T21:32:52.220Z", "sensors": [{"id": 4356815, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "84.5", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 4356814, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "81", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 4356813, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "37", "channel": 3, "chart_unit": "F"}, {"id": 4356812, "sensor_code": "Heat Index", "sensor_name": "Heat Index", "last_reading_value": "96", "channel": 4, "chart_unit": "F"}, {"id": 4356811, "sensor_code": "Interference", "sensor_name": "Interference", "last_reading_value": "1", "channel": 5, "chart_unit": null}, {"id": 4356807, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.05", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [{"id": 4356810, "sensor_code": "LightningStrikeCnt", "sensor_name": "Lightning Strike Count", "last_reading_value": "15", "channel": 6, "chart_unit": null}, {"id": 4356809, "sensor_code": "LightningClosestStrikeDist", "sensor_name": "Lightning Closest Strike Distance", "last_reading_value": "6", "channel": 7, "chart_unit": "MI"}, {"id": 4356808, "sensor_code": "LightningLastStrikeDist", "sensor_name": "Lightning Last Strike Distance", "last_reading_value": "6", "channel": 8, "chart_unit": "MI"}], "model": {"id": 6077, "code": "LightningT", "description": "Lightning Tower", "has_wifi": false}}
2022-06-16 20:10:00,424 Thread-58 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:10:00,425 Thread-58 udi_interface INFO AcuriteController:discover: Node 943425 already exists, skipping
2022-06-16 20:10:00,425 Thread-58 udi_interface DEBUG AcuriteLightningTNode:update: AcuriteLightningTNode - update
2022-06-16 20:10:00,426 Thread-58 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV1's value
2022-06-16 20:10:00,427 Thread-58 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV2's value
2022-06-16 20:10:01,152 Thread-58 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLITEMP's value
2022-06-16 20:10:01,153 Thread-58 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Temp: 84.5 F
2022-06-16 20:10:01,824 Thread-58 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLIHUM's value
2022-06-16 20:10:01,825 Thread-58 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Humidity: 81 %RH
2022-06-16 20:10:02,467 Thread-58 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in DEWPT's value
2022-06-16 20:10:02,468 Thread-58 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Dew Point: 37 F
2022-06-16 20:10:03,135 Thread-58 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in BARPRES's value
2022-06-16 20:10:03,136 Thread-58 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Barometric Pressure: 30.05 inHg
2022-06-16 20:10:04,258 Thread-58 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV4's value
2022-06-16 20:10:04,259 Thread-58 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Heat Index: 96 F
2022-06-16 20:10:04,921 Thread-58 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV5's value
2022-06-16 20:10:04,922 Thread-58 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Strike Count: 15 None
2022-06-16 20:10:05,581 Thread-58 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV6's value
2022-06-16 20:10:05,582 Thread-58 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Last Strike Distance: 6 MI
2022-06-16 20:10:06,170 Thread-58 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV8's value
2022-06-16 20:10:06,171 Thread-58 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Closest Strike Distance: 6 MI
2022-06-16 20:10:06,171 Thread-58 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV3 to 3 to Polyglot
2022-06-16 20:10:06,172 Thread-58 udi_interface.node DEBUG node:reportDriver: Updating value to 3
2022-06-16 20:10:06,173 Thread-58 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV3', 'value': '3', 'uom': '45'}]}
2022-06-16 20:10:06,175 Thread-58 udi_interface DEBUG AcuriteController:discover: Device Id: 313855
2022-06-16 20:10:06,176 Thread-58 udi_interface DEBUG AcuriteController:discover: Device Name: AC Temps
2022-06-16 20:10:06,177 Thread-58 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 313855, "name": "AC Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 3, "last_check_in_at": "2022-06-17T00:06:57.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "78.6", "temp_high_at": "6:41 PM", "temp_low_value": "53.0", "temp_low_at": "3:41 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2017-01-11T17:01:42.630Z", "sensors": [{"id": 1211149, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "69.8", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 1211150, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "86", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 1211151, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "66", "channel": 3, "chart_unit": "F"}, {"id": 1211148, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.05", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:10:06,178 Thread-58 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:10:06,178 Thread-58 udi_interface INFO AcuriteController:discover: Node 313855 already exists, skipping
2022-06-16 20:10:06,179 Thread-58 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV1's value
2022-06-16 20:10:06,180 Thread-58 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV2's value
2022-06-16 20:10:06,332 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV3 to 3 UOM 45
2022-06-16 20:10:06,736 Thread-58 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLITEMP's value
2022-06-16 20:10:06,736 Thread-58 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Temp: 69.8 F
2022-06-16 20:10:07,184 Thread-58 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLIHUM's value
2022-06-16 20:10:07,184 Thread-58 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Humidity: 86 %RH
2022-06-16 20:10:07,635 Thread-58 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in DEWPT's value
2022-06-16 20:10:07,636 Thread-58 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Dew Point: 66 F
2022-06-16 20:10:08,087 Thread-58 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in BARPRES's value
2022-06-16 20:10:08,088 Thread-58 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Barometric Pressure: 30.05 inHg
2022-06-16 20:10:08,088 Thread-58 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set GV3 to 3 to Polyglot
2022-06-16 20:10:08,089 Thread-58 udi_interface.node DEBUG node:reportDriver: Updating value to 3
2022-06-16 20:10:08,090 Thread-58 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'GV3', 'value': '3', 'uom': '45'}]}
2022-06-16 20:10:08,092 Thread-58 udi_interface DEBUG AcuriteController:discover: Device Id: 1065633
2022-06-16 20:10:08,092 Thread-58 udi_interface DEBUG AcuriteController:discover: Device Name: Bedroom Temps
2022-06-16 20:10:08,093 Thread-58 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 1065633, "name": "Bedroom Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 4, "last_check_in_at": "2022-06-17T00:06:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "79.7", "temp_high_at": "12:46 PM", "temp_low_value": "77.5", "temp_low_at": "1:36 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2020-09-06T21:46:43.678Z", "sensors": [{"id": 5041656, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "78.4", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 5041657, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "49", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 5041658, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 5041655, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.05", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:10:08,094 Thread-58 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:10:08,095 Thread-58 udi_interface INFO AcuriteController:discover: Node 1065633 already exists, skipping
2022-06-16 20:10:08,095 Thread-58 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV1's value
2022-06-16 20:10:08,096 Thread-58 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV2's value
2022-06-16 20:10:08,224 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: GV3 to 3 UOM 45
2022-06-16 20:10:08,571 Thread-58 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLITEMP's value
2022-06-16 20:10:08,572 Thread-58 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Temp: 78.4 F
2022-06-16 20:10:09,025 Thread-58 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLIHUM's value
2022-06-16 20:10:09,026 Thread-58 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Humidity: 49 %RH
2022-06-16 20:10:09,475 Thread-58 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in DEWPT's value
2022-06-16 20:10:09,475 Thread-58 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Dew Point: 58 F
2022-06-16 20:10:09,922 Thread-58 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in BARPRES's value
2022-06-16 20:10:09,923 Thread-58 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Barometric Pressure: 30.05 inHg
2022-06-16 20:10:09,924 Thread-58 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set GV3 to 3 to Polyglot
2022-06-16 20:10:09,924 Thread-58 udi_interface.node DEBUG node:reportDriver: Updating value to 3
2022-06-16 20:10:09,925 Thread-58 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'GV3', 'value': '3', 'uom': '45'}]}
2022-06-16 20:10:09,927 Thread-58 udi_interface INFO AcuriteController:query: AcuriteController - query
2022-06-16 20:10:10,038 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: GV3 to 3 UOM 45
2022-06-16 20:10:58,129 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2022-06-16 20:10:58,131 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2022-06-16 20:10:58,132 Thread-59 udi_interface INFO AcuriteController:poll: shortPoll (controller)
2022-06-16 20:10:58,134 Thread-59 udi_interface INFO AcuriteController:discover: Starting Acurite Device Discovery
2022-06-16 20:10:58,134 Thread-59 udi_interface INFO AcuriteController:discover: acurite_user: tlightne@aim.com
2022-06-16 20:10:58,961 Thread-59 udi_interface INFO AcuriteManager:login: Login HTTP Status Code: 200
2022-06-16 20:10:58,963 Thread-59 udi_interface DEBUG AcuriteManager:login: {"token_id": "706877f8-41ae-46f4-8f00-64a9a7abc367", "user": {"id": 34604, "email": "tlightne@aim.com", "first_name": "Terry", "last_name": "Lightner", "full_name": "Terry Lightner", "language": "en/us", "session_timeout": 7776000, "failed_login_count": 15, "is_locked": false, "default_user_contact_id": 38708, "password_set_token": null, "permissions": ["Account User-32858", "Account User-32858-Clock", "Account User-32858-Sensor", "Account User-32858-Bell Controller", "Account Admin-32858", "Account Admin-32858-Clock", "Account Admin-32858-Sensor", "Account Admin-32858-Bell Controller", "Account Manager-32858", "Account Manager-32858-Clock", "Account Manager-32858-Sensor", "Account Manager-32858-Bell Controller", "Network Admin-32858", "Network Admin-32858-Clock", "Network Admin-32858-Sensor", "Network Admin-32858-Bell Controller"], "user_contacts": [{"id": 38708, "user_id": 34604, "contact_type": "email", "value": "tlightne@aim.com", "name": "Default email", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 52558, "user_id": 34604, "contact_type": "android", "value": "fXomgUZZOZc:APA91bGp5qAhdyu9QgEneDASam1286SxRRp-VO6yv7rZLrS2ykL6KGI8Uj5XnGcee8-iWYvjqpg5LYbH_6Tzj9K9IAkF3xiIb6eQvY87sB_f1Bwj_KftKcGLVQ3iyUto1ZoOsEJx8cQP", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/51452137-2b9e-3daf-86e9-131a661185bc", "mri_monitor_states": []}, {"id": 60620, "user_id": 34604, "contact_type": "phone", "value": "9417180409", "name": "AC Temps", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 509896, "user_id": 34604, "contact_type": "android", "value": "fXANtCdsSu6DSZhlP5_SNk:APA91bGYor1EZCr-H4NbxXXGGvJxLLDRyC8FrKHBkf2hdSuu0PZUTdzS9k08QDOU2h0C9ushtIG2-5pVgyZwsiGxx7JTy87oZQtU4RLrEKeWOonZR-CSFooC2Ym6KbVEAzh64-hndgEr", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/f97f465d-27db-3345-88b9-281db46deeec", "mri_monitor_states": []}], "account_users": [{"id": 34744, "account_id": 32858, "is_active": true, "web_theme": "light", "account": {"id": 32858, "name": "MAR Acct", "street_address_1": "3275 26th Ave East Lot 7", "street_address_2": "", "city": "Bradenton", "state_province": "FL", "zip": "34208", "country_code": "US", "show_tenths": true, "measurement_system_id": 1, "timezone": "America/New_York", "map_center_point": {"lat": 0.0, "lng": 0.0}, "map_zoom_level": 8, "map_view": "current_temp", "map_views": ["current_temp", "todays_rain", "current_wind"], "measurement_system_units": {"LightningClosestStrikeDist": "MI", "IndoorTemperature": "F", "IndoorHumidity": "%", "LightningLastStrikeDist": "MI", "Water Leak": "V", "Temperature": "F", "Humidity": "%", "WaterFlowRate": "gal", "WaterTemp": "F", "Barometric Pressure": "inHg", "Wind Speed": "mph", "Rainfall": "in", "Rainrate": "in", "Feels Like": "F", "Dew Point": "F", "Heat Index": "F", "Wind Chill": "F", "Soil Temp": "F", "Remote Temp": "F", "Remote Humid": "%", "WindSpeedAvg": "mph"}, "time_format": "12_hour", "date_format": "mm/dd", "header_images": [], "background_images": []}}]}}
2022-06-16 20:11:05,934 Thread-59 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLIHUM's value
2022-06-16 20:11:05,935 Thread-59 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Humidity: 86 %RH
2022-06-16 20:11:06,389 Thread-59 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in DEWPT's value
2022-06-16 20:11:06,390 Thread-59 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Dew Point: 66 F
2022-06-16 20:11:06,914 Thread-59 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in BARPRES's value
2022-06-16 20:11:06,916 Thread-59 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Barometric Pressure: 30.05 inHg
2022-06-16 20:11:06,916 Thread-59 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set GV3 to 4 to Polyglot
2022-06-16 20:11:06,917 Thread-59 udi_interface.node DEBUG node:reportDriver: Updating value to 4
2022-06-16 20:11:06,918 Thread-59 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'GV3', 'value': '4', 'uom': '45'}]}
2022-06-16 20:11:06,919 Thread-59 udi_interface DEBUG AcuriteController:discover: Device Id: 1065633
2022-06-16 20:11:06,920 Thread-59 udi_interface DEBUG AcuriteController:discover: Device Name: Bedroom Temps
2022-06-16 20:11:06,921 Thread-59 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 1065633, "name": "Bedroom Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 4, "last_check_in_at": "2022-06-17T00:06:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "79.7", "temp_high_at": "12:46 PM", "temp_low_value": "77.5", "temp_low_at": "1:36 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2020-09-06T21:46:43.678Z", "sensors": [{"id": 5041656, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "78.4", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 5041657, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "49", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 5041658, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 5041655, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.05", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:11:06,922 Thread-59 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:11:06,923 Thread-59 udi_interface INFO AcuriteController:discover: Node 1065633 already exists, skipping
2022-06-16 20:11:06,923 Thread-59 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV1's value
2022-06-16 20:11:06,924 Thread-59 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV2's value
2022-06-16 20:11:07,051 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: GV3 to 4 UOM 45
2022-06-16 20:11:07,520 Thread-59 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLITEMP's value
2022-06-16 20:11:07,521 Thread-59 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Temp: 78.4 F
2022-06-16 20:11:08,101 Thread-59 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLIHUM's value
2022-06-16 20:11:08,101 Thread-59 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Humidity: 49 %RH
2022-06-16 20:11:08,674 Thread-59 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in DEWPT's value
2022-06-16 20:11:08,675 Thread-59 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Dew Point: 58 F
2022-06-16 20:11:09,247 Thread-59 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in BARPRES's value
2022-06-16 20:11:09,247 Thread-59 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Barometric Pressure: 30.05 inHg
2022-06-16 20:11:09,248 Thread-59 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set GV3 to 4 to Polyglot
2022-06-16 20:11:09,249 Thread-59 udi_interface.node DEBUG node:reportDriver: Updating value to 4
2022-06-16 20:11:09,249 Thread-59 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'GV3', 'value': '4', 'uom': '45'}]}
2022-06-16 20:11:09,251 Thread-59 udi_interface INFO AcuriteController:query: AcuriteController - query
2022-06-16 20:11:09,367 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: GV3 to 4 UOM 45
2022-06-16 20:11:58,150 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2022-06-16 20:11:58,152 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2022-06-16 20:11:58,153 Thread-60 udi_interface INFO AcuriteController:poll: shortPoll (controller)
2022-06-16 20:11:58,155 Thread-60 udi_interface INFO AcuriteController:discover: Starting Acurite Device Discovery
2022-06-16 20:11:58,155 Thread-60 udi_interface INFO AcuriteController:discover: acurite_user: tlightne@aim.com
2022-06-16 20:11:59,021 Thread-60 udi_interface INFO AcuriteManager:login: Login HTTP Status Code: 200
2022-06-16 20:11:59,023 Thread-60 udi_interface DEBUG AcuriteManager:login: {"token_id": "0f0bfdd1-0710-4ea7-a2cd-98907248a1d4", "user": {"id": 34604, "email": "tlightne@aim.com", "first_name": "Terry", "last_name": "Lightner", "full_name": "Terry Lightner", "language": "en/us", "session_timeout": 7776000, "failed_login_count": 15, "is_locked": false, "default_user_contact_id": 38708, "password_set_token": null, "permissions": ["Account User-32858", "Account User-32858-Clock", "Account User-32858-Sensor", "Account User-32858-Bell Controller", "Account Admin-32858", "Account Admin-32858-Clock", "Account Admin-32858-Sensor", "Account Admin-32858-Bell Controller", "Account Manager-32858", "Account Manager-32858-Clock", "Account Manager-32858-Sensor", "Account Manager-32858-Bell Controller", "Network Admin-32858", "Network Admin-32858-Clock", "Network Admin-32858-Sensor", "Network Admin-32858-Bell Controller"], "user_contacts": [{"id": 38708, "user_id": 34604, "contact_type": "email", "value": "tlightne@aim.com", "name": "Default email", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 52558, "user_id": 34604, "contact_type": "android", "value": "fXomgUZZOZc:APA91bGp5qAhdyu9QgEneDASam1286SxRRp-VO6yv7rZLrS2ykL6KGI8Uj5XnGcee8-iWYvjqpg5LYbH_6Tzj9K9IAkF3xiIb6eQvY87sB_f1Bwj_KftKcGLVQ3iyUto1ZoOsEJx8cQP", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/51452137-2b9e-3daf-86e9-131a661185bc", "mri_monitor_states": []}, {"id": 60620, "user_id": 34604, "contact_type": "phone", "value": "9417180409", "name": "AC Temps", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 509896, "user_id": 34604, "contact_type": "android", "value": "fXANtCdsSu6DSZhlP5_SNk:APA91bGYor1EZCr-H4NbxXXGGvJxLLDRyC8FrKHBkf2hdSuu0PZUTdzS9k08QDOU2h0C9ushtIG2-5pVgyZwsiGxx7JTy87oZQtU4RLrEKeWOonZR-CSFooC2Ym6KbVEAzh64-hndgEr", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/f97f465d-27db-3345-88b9-281db46deeec", "mri_monitor_states": []}], "account_users": [{"id": 34744, "account_id": 32858, "is_active": true, "web_theme": "light", "account": {"id": 32858, "name": "MAR Acct", "street_address_1": "3275 26th Ave East Lot 7", "street_address_2": "", "city": "Bradenton", "state_province": "FL", "zip": "34208", "country_code": "US", "show_tenths": true, "measurement_system_id": 1, "timezone": "America/New_York", "map_center_point": {"lat": 0.0, "lng": 0.0}, "map_zoom_level": 8, "map_view": "current_temp", "map_views": ["current_temp", "todays_rain", "current_wind"], "measurement_system_units": {"LightningClosestStrikeDist": "MI", "IndoorTemperature": "F", "IndoorHumidity": "%", "LightningLastStrikeDist": "MI", "Water Leak": "V", "Temperature": "F", "Humidity": "%", "WaterFlowRate": "gal", "WaterTemp": "F", "Barometric Pressure": "inHg", "Wind Speed": "mph", "Rainfall": "in", "Rainrate": "in", "Feels Like": "F", "Dew Point": "F", "Heat Index": "F", "Wind Chill": "F", "Soil Temp": "F", "Remote Temp": "F", "Remote Humid": "%", "WindSpeedAvg": "mph"}, "time_format": "12_hour", "date_format": "mm/dd", "header_images": [], "background_images": []}}]}}
2022-06-16 20:12:00,529 Thread-60 udi_interface INFO AcuriteManager:getHubDevices: Got Acurite Devices
2022-06-16 20:12:00,530 Thread-60 udi_interface DEBUG AcuriteController:discover: Device Id: 943425
2022-06-16 20:12:00,531 Thread-60 udi_interface DEBUG AcuriteController:discover: Device Name: Lightning Tower
2022-06-16 20:12:00,532 Thread-60 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 943425, "name": "Lightning Tower", "model_code": "LightningT", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 1, "last_check_in_at": "2022-06-17T00:11:57.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-17.json"], "temp_high_value": "97.6", "temp_high_at": "12:36 PM", "temp_low_value": "75.6", "temp_low_at": "5:56 AM", "daily_cumulative_strikes": 73, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2019-10-02T21:32:52.220Z", "sensors": [{"id": 4356815, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "84.1", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 4356814, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "99", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 4356813, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "55", "channel": 3, "chart_unit": "F"}, {"id": 4356812, "sensor_code": "Heat Index", "sensor_name": "Heat Index", "last_reading_value": "103", "channel": 4, "chart_unit": "F"}, {"id": 4356811, "sensor_code": "Interference", "sensor_name": "Interference", "last_reading_value": "1", "channel": 5, "chart_unit": null}, {"id": 4356807, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.06", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [{"id": 4356810, "sensor_code": "LightningStrikeCnt", "sensor_name": "Lightning Strike Count", "last_reading_value": "27", "channel": 6, "chart_unit": null}, {"id": 4356809, "sensor_code": "LightningClosestStrikeDist", "sensor_name": "Lightning Closest Strike Distance", "last_reading_value": "4", "channel": 7, "chart_unit": "MI"}, {"id": 4356808, "sensor_code": "LightningLastStrikeDist", "sensor_name": "Lightning Last Strike Distance", "last_reading_value": "4", "channel": 8, "chart_unit": "MI"}], "model": {"id": 6077, "code": "LightningT", "description": "Lightning Tower", "has_wifi": false}}
2022-06-16 20:12:00,533 Thread-60 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:12:00,533 Thread-60 udi_interface INFO AcuriteController:discover: Node 943425 already exists, skipping
2022-06-16 20:12:00,534 Thread-60 udi_interface DEBUG AcuriteLightningTNode:update: AcuriteLightningTNode - update
2022-06-16 20:12:00,534 Thread-60 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV1's value
2022-06-16 20:12:00,535 Thread-60 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV2's value
2022-06-16 20:12:01,211 Thread-60 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set CLITEMP to 84.1 to Polyglot
2022-06-16 20:12:01,213 Thread-60 udi_interface.node DEBUG node:reportDriver: Updating value to 84.1
2022-06-16 20:12:01,213 Thread-60 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'CLITEMP', 'value': '84.1', 'uom': '17'}]}
2022-06-16 20:12:01,215 Thread-60 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Temp: 84.1 F
2022-06-16 20:12:01,877 Thread-60 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set CLIHUM to 99 to Polyglot
2022-06-16 20:12:01,879 Thread-60 udi_interface.node DEBUG node:reportDriver: Updating value to 99
2022-06-16 20:12:01,879 Thread-60 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'CLIHUM', 'value': '99', 'uom': '22'}]}
2022-06-16 20:12:01,881 Thread-60 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Humidity: 99 %RH
2022-06-16 20:12:01,943 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: CLITEMP to 84.1 UOM 17
2022-06-16 20:12:02,107 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: CLIHUM to 99 UOM 22
2022-06-16 20:12:02,483 Thread-60 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set DEWPT to 55 to Polyglot
2022-06-16 20:12:02,483 Thread-60 udi_interface.node DEBUG node:reportDriver: Updating value to 55
2022-06-16 20:12:02,484 Thread-60 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'DEWPT', 'value': '55', 'uom': '17'}]}
2022-06-16 20:12:02,485 Thread-60 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Dew Point: 55 F
2022-06-16 20:12:02,662 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: DEWPT to 55 UOM 17
2022-06-16 20:12:03,074 Thread-60 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set BARPRES to 30.06 to Polyglot
2022-06-16 20:12:03,075 Thread-60 udi_interface.node DEBUG node:reportDriver: Updating value to 30.06
2022-06-16 20:12:03,075 Thread-60 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'BARPRES', 'value': '30.06', 'uom': '23'}]}
2022-06-16 20:12:03,077 Thread-60 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Barometric Pressure: 30.06 inHg
2022-06-16 20:12:03,276 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: BARPRES to 30.06 UOM 23
2022-06-16 20:12:04,043 Thread-60 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV4 to 103 to Polyglot
2022-06-16 20:12:04,044 Thread-60 udi_interface.node DEBUG node:reportDriver: Updating value to 103
2022-06-16 20:12:04,045 Thread-60 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV4', 'value': '103', 'uom': '17'}]}
2022-06-16 20:12:04,047 Thread-60 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Heat Index: 103 F
2022-06-16 20:12:04,189 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV4 to 103 UOM 17
2022-06-16 20:12:58,154 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2022-06-16 20:12:58,156 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2022-06-16 20:12:58,157 Thread-61 udi_interface INFO AcuriteController:poll: shortPoll (controller)
2022-06-16 20:12:58,158 Thread-61 udi_interface INFO AcuriteController:discover: Starting Acurite Device Discovery
2022-06-16 20:12:58,159 Thread-61 udi_interface INFO AcuriteController:discover: acurite_user: tlightne@aim.com
2022-06-16 20:12:59,035 Thread-61 udi_interface INFO AcuriteManager:login: Login HTTP Status Code: 200
2022-06-16 20:12:59,037 Thread-61 udi_interface DEBUG AcuriteManager:login: {"token_id": "36895ee6-0a5c-4a64-92c7-8fd3abd672e8", "user": {"id": 34604, "email": "tlightne@aim.com", "first_name": "Terry", "last_name": "Lightner", "full_name": "Terry Lightner", "language": "en/us", "session_timeout": 7776000, "failed_login_count": 15, "is_locked": false, "default_user_contact_id": 38708, "password_set_token": null, "permissions": ["Account User-32858", "Account User-32858-Clock", "Account User-32858-Sensor", "Account User-32858-Bell Controller", "Account Admin-32858", "Account Admin-32858-Clock", "Account Admin-32858-Sensor", "Account Admin-32858-Bell Controller", "Account Manager-32858", "Account Manager-32858-Clock", "Account Manager-32858-Sensor", "Account Manager-32858-Bell Controller", "Network Admin-32858", "Network Admin-32858-Clock", "Network Admin-32858-Sensor", "Network Admin-32858-Bell Controller"], "user_contacts": [{"id": 38708, "user_id": 34604, "contact_type": "email", "value": "tlightne@aim.com", "name": "Default email", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 52558, "user_id": 34604, "contact_type": "android", "value": "fXomgUZZOZc:APA91bGp5qAhdyu9QgEneDASam1286SxRRp-VO6yv7rZLrS2ykL6KGI8Uj5XnGcee8-iWYvjqpg5LYbH_6Tzj9K9IAkF3xiIb6eQvY87sB_f1Bwj_KftKcGLVQ3iyUto1ZoOsEJx8cQP", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/51452137-2b9e-3daf-86e9-131a661185bc", "mri_monitor_states": []}, {"id": 60620, "user_id": 34604, "contact_type": "phone", "value": "9417180409", "name": "AC Temps", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 509896, "user_id": 34604, "contact_type": "android", "value": "fXANtCdsSu6DSZhlP5_SNk:APA91bGYor1EZCr-H4NbxXXGGvJxLLDRyC8FrKHBkf2hdSuu0PZUTdzS9k08QDOU2h0C9ushtIG2-5pVgyZwsiGxx7JTy87oZQtU4RLrEKeWOonZR-CSFooC2Ym6KbVEAzh64-hndgEr", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/f97f465d-27db-3345-88b9-281db46deeec", "mri_monitor_states": []}], "account_users": [{"id": 34744, "account_id": 32858, "is_active": true, "web_theme": "light", "account": {"id": 32858, "name": "MAR Acct", "street_address_1": "3275 26th Ave East Lot 7", "street_address_2": "", "city": "Bradenton", "state_province": "FL", "zip": "34208", "country_code": "US", "show_tenths": true, "measurement_system_id": 1, "timezone": "America/New_York", "map_center_point": {"lat": 0.0, "lng": 0.0}, "map_zoom_level": 8, "map_view": "current_temp", "map_views": ["current_temp", "todays_rain", "current_wind"], "measurement_system_units": {"LightningClosestStrikeDist": "MI", "IndoorTemperature": "F", "IndoorHumidity": "%", "LightningLastStrikeDist": "MI", "Water Leak": "V", "Temperature": "F", "Humidity": "%", "WaterFlowRate": "gal", "WaterTemp": "F", "Barometric Pressure": "inHg", "Wind Speed": "mph", "Rainfall": "in", "Rainrate": "in", "Feels Like": "F", "Dew Point": "F", "Heat Index": "F", "Wind Chill": "F", "Soil Temp": "F", "Remote Temp": "F", "Remote Humid": "%", "WindSpeedAvg": "mph"}, "time_format": "12_hour", "date_format": "mm/dd", "header_images": [], "background_images": []}}]}}
2022-06-16 20:13:00,411 Thread-61 udi_interface INFO AcuriteManager:getHubDevices: Got Acurite Devices
2022-06-16 20:13:00,412 Thread-61 udi_interface DEBUG AcuriteController:discover: Device Id: 943425
2022-06-16 20:13:00,413 Thread-61 udi_interface DEBUG AcuriteController:discover: Device Name: Lightning Tower
2022-06-16 20:13:00,414 Thread-61 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 943425, "name": "Lightning Tower", "model_code": "LightningT", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 1, "last_check_in_at": "2022-06-17T00:11:57.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-17.json"], "temp_high_value": "97.6", "temp_high_at": "12:36 PM", "temp_low_value": "75.6", "temp_low_at": "5:56 AM", "daily_cumulative_strikes": 73, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2019-10-02T21:32:52.220Z", "sensors": [{"id": 4356815, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "84.1", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 4356814, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "99", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 4356813, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "55", "channel": 3, "chart_unit": "F"}, {"id": 4356812, "sensor_code": "Heat Index", "sensor_name": "Heat Index", "last_reading_value": "103", "channel": 4, "chart_unit": "F"}, {"id": 4356811, "sensor_code": "Interference", "sensor_name": "Interference", "last_reading_value": "1", "channel": 5, "chart_unit": null}, {"id": 4356807, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.06", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [{"id": 4356810, "sensor_code": "LightningStrikeCnt", "sensor_name": "Lightning Strike Count", "last_reading_value": "27", "channel": 6, "chart_unit": null}, {"id": 4356809, "sensor_code": "LightningClosestStrikeDist", "sensor_name": "Lightning Closest Strike Distance", "last_reading_value": "4", "channel": 7, "chart_unit": "MI"}, {"id": 4356808, "sensor_code": "LightningLastStrikeDist", "sensor_name": "Lightning Last Strike Distance", "last_reading_value": "4", "channel": 8, "chart_unit": "MI"}], "model": {"id": 6077, "code": "LightningT", "description": "Lightning Tower", "has_wifi": false}}
2022-06-16 20:13:00,415 Thread-61 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:13:00,415 Thread-61 udi_interface INFO AcuriteController:discover: Node 943425 already exists, skipping
2022-06-16 20:13:00,416 Thread-61 udi_interface DEBUG AcuriteLightningTNode:update: AcuriteLightningTNode - update
2022-06-16 20:13:00,417 Thread-61 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV1's value
2022-06-16 20:13:00,417 Thread-61 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV2's value
2022-06-16 20:13:01,146 Thread-61 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLITEMP's value
2022-06-16 20:13:01,147 Thread-61 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Temp: 84.1 F
2022-06-16 20:13:01,775 Thread-61 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLIHUM's value
2022-06-16 20:13:01,775 Thread-61 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Humidity: 99 %RH
2022-06-16 20:13:02,260 Thread-61 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in DEWPT's value
2022-06-16 20:13:02,260 Thread-61 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Dew Point: 55 F
2022-06-16 20:13:02,908 Thread-61 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in BARPRES's value
2022-06-16 20:13:02,909 Thread-61 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Barometric Pressure: 30.06 inHg
2022-06-16 20:13:04,003 Thread-61 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV4's value
2022-06-16 20:13:04,004 Thread-61 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Heat Index: 103 F
2022-06-16 20:13:04,542 Thread-61 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV5's value
2022-06-16 20:13:04,543 Thread-61 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Strike Count: 27 None
2022-06-16 20:13:05,004 Thread-61 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV6's value
2022-06-16 20:13:05,005 Thread-61 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Last Strike Distance: 4 MI
2022-06-16 20:13:05,456 Thread-61 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV8's value
2022-06-16 20:13:05,456 Thread-61 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Closest Strike Distance: 4 MI
2022-06-16 20:13:05,457 Thread-61 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV3 to 1 to Polyglot
2022-06-16 20:13:05,457 Thread-61 udi_interface.node DEBUG node:reportDriver: Updating value to 1
2022-06-16 20:13:05,458 Thread-61 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV3', 'value': '1', 'uom': '45'}]}
2022-06-16 20:13:05,460 Thread-61 udi_interface DEBUG AcuriteController:discover: Device Id: 313855
2022-06-16 20:13:05,461 Thread-61 udi_interface DEBUG AcuriteController:discover: Device Name: AC Temps
2022-06-16 20:13:05,462 Thread-61 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 313855, "name": "AC Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 3, "last_check_in_at": "2022-06-17T00:11:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "78.6", "temp_high_at": "6:41 PM", "temp_low_value": "53.0", "temp_low_at": "3:41 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2017-01-11T17:01:42.630Z", "sensors": [{"id": 1211149, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "71.9", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 1211150, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "75", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 1211151, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "64", "channel": 3, "chart_unit": "F"}, {"id": 1211148, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.06", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:13:05,463 Thread-61 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:13:05,464 Thread-61 udi_interface INFO AcuriteController:discover: Node 313855 already exists, skipping
2022-06-16 20:13:05,464 Thread-61 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV1's value
2022-06-16 20:13:05,465 Thread-61 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV2's value
2022-06-16 20:13:05,587 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV3 to 1 UOM 45
2022-06-16 20:13:05,941 Thread-61 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLITEMP's value
2022-06-16 20:13:05,942 Thread-61 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Temp: 71.9 F
2022-06-16 20:13:06,389 Thread-61 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLIHUM's value
2022-06-16 20:13:06,390 Thread-61 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Humidity: 75 %RH
2022-06-16 20:13:06,840 Thread-61 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in DEWPT's value
2022-06-16 20:13:06,841 Thread-61 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Dew Point: 64 F
2022-06-16 20:13:07,290 Thread-61 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in BARPRES's value
2022-06-16 20:13:07,291 Thread-61 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Barometric Pressure: 30.06 inHg
2022-06-16 20:13:07,291 Thread-61 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set GV3 to 1 to Polyglot
2022-06-16 20:13:07,292 Thread-61 udi_interface.node DEBUG node:reportDriver: Updating value to 1
2022-06-16 20:13:07,293 Thread-61 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'GV3', 'value': '1', 'uom': '45'}]}
2022-06-16 20:13:07,295 Thread-61 udi_interface DEBUG AcuriteController:discover: Device Id: 1065633
2022-06-16 20:13:07,296 Thread-61 udi_interface DEBUG AcuriteController:discover: Device Name: Bedroom Temps
2022-06-16 20:13:07,297 Thread-61 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 1065633, "name": "Bedroom Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 4, "last_check_in_at": "2022-06-17T00:11:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "79.7", "temp_high_at": "12:46 PM", "temp_low_value": "77.5", "temp_low_at": "1:36 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2020-09-06T21:46:43.678Z", "sensors": [{"id": 5041656, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "78.4", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 5041657, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "50", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 5041658, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 5041655, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.06", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:13:07,298 Thread-61 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:13:07,298 Thread-61 udi_interface INFO AcuriteController:discover: Node 1065633 already exists, skipping
2022-06-16 20:13:07,299 Thread-61 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV1's value
2022-06-16 20:13:07,300 Thread-61 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV2's value
2022-06-16 20:13:07,436 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: GV3 to 1 UOM 45
2022-06-16 20:13:07,791 Thread-61 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLITEMP's value
2022-06-16 20:13:07,792 Thread-61 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Temp: 78.4 F
2022-06-16 20:13:08,241 Thread-61 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLIHUM's value
2022-06-16 20:13:08,241 Thread-61 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Humidity: 50 %RH
2022-06-16 20:13:08,694 Thread-61 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in DEWPT's value
2022-06-16 20:13:08,695 Thread-61 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Dew Point: 58 F
2022-06-16 20:13:09,141 Thread-61 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in BARPRES's value
2022-06-16 20:13:09,142 Thread-61 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Barometric Pressure: 30.06 inHg
2022-06-16 20:13:09,142 Thread-61 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set GV3 to 1 to Polyglot
2022-06-16 20:13:09,143 Thread-61 udi_interface.node DEBUG node:reportDriver: Updating value to 1
2022-06-16 20:13:09,144 Thread-61 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'GV3', 'value': '1', 'uom': '45'}]}
2022-06-16 20:13:09,146 Thread-61 udi_interface INFO AcuriteController:query: AcuriteController - query
2022-06-16 20:13:09,245 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: GV3 to 1 UOM 45
2022-06-16 20:13:58,167 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2022-06-16 20:13:58,169 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2022-06-16 20:13:58,170 Thread-62 udi_interface INFO AcuriteController:poll: shortPoll (controller)
2022-06-16 20:13:58,171 Thread-62 udi_interface INFO AcuriteController:discover: Starting Acurite Device Discovery
2022-06-16 20:13:58,172 Thread-62 udi_interface INFO AcuriteController:discover: acurite_user: tlightne@aim.com
2022-06-16 20:13:58,972 Thread-62 udi_interface INFO AcuriteManager:login: Login HTTP Status Code: 200
2022-06-16 20:13:58,974 Thread-62 udi_interface DEBUG AcuriteManager:login: {"token_id": "e101c37b-10ed-4236-b839-e2e10fe45434", "user": {"id": 34604, "email": "tlightne@aim.com", "first_name": "Terry", "last_name": "Lightner", "full_name": "Terry Lightner", "language": "en/us", "session_timeout": 7776000, "failed_login_count": 15, "is_locked": false, "default_user_contact_id": 38708, "password_set_token": null, "permissions": ["Account User-32858", "Account User-32858-Clock", "Account User-32858-Sensor", "Account User-32858-Bell Controller", "Account Admin-32858", "Account Admin-32858-Clock", "Account Admin-32858-Sensor", "Account Admin-32858-Bell Controller", "Account Manager-32858", "Account Manager-32858-Clock", "Account Manager-32858-Sensor", "Account Manager-32858-Bell Controller", "Network Admin-32858", "Network Admin-32858-Clock", "Network Admin-32858-Sensor", "Network Admin-32858-Bell Controller"], "user_contacts": [{"id": 38708, "user_id": 34604, "contact_type": "email", "value": "tlightne@aim.com", "name": "Default email", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 52558, "user_id": 34604, "contact_type": "android", "value": "fXomgUZZOZc:APA91bGp5qAhdyu9QgEneDASam1286SxRRp-VO6yv7rZLrS2ykL6KGI8Uj5XnGcee8-iWYvjqpg5LYbH_6Tzj9K9IAkF3xiIb6eQvY87sB_f1Bwj_KftKcGLVQ3iyUto1ZoOsEJx8cQP", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/51452137-2b9e-3daf-86e9-131a661185bc", "mri_monitor_states": []}, {"id": 60620, "user_id": 34604, "contact_type": "phone", "value": "9417180409", "name": "AC Temps", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 509896, "user_id": 34604, "contact_type": "android", "value": "fXANtCdsSu6DSZhlP5_SNk:APA91bGYor1EZCr-H4NbxXXGGvJxLLDRyC8FrKHBkf2hdSuu0PZUTdzS9k08QDOU2h0C9ushtIG2-5pVgyZwsiGxx7JTy87oZQtU4RLrEKeWOonZR-CSFooC2Ym6KbVEAzh64-hndgEr", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/f97f465d-27db-3345-88b9-281db46deeec", "mri_monitor_states": []}], "account_users": [{"id": 34744, "account_id": 32858, "is_active": true, "web_theme": "light", "account": {"id": 32858, "name": "MAR Acct", "street_address_1": "3275 26th Ave East Lot 7", "street_address_2": "", "city": "Bradenton", "state_province": "FL", "zip": "34208", "country_code": "US", "show_tenths": true, "measurement_system_id": 1, "timezone": "America/New_York", "map_center_point": {"lat": 0.0, "lng": 0.0}, "map_zoom_level": 8, "map_view": "current_temp", "map_views": ["current_temp", "todays_rain", "current_wind"], "measurement_system_units": {"LightningClosestStrikeDist": "MI", "IndoorTemperature": "F", "IndoorHumidity": "%", "LightningLastStrikeDist": "MI", "Water Leak": "V", "Temperature": "F", "Humidity": "%", "WaterFlowRate": "gal", "WaterTemp": "F", "Barometric Pressure": "inHg", "Wind Speed": "mph", "Rainfall": "in", "Rainrate": "in", "Feels Like": "F", "Dew Point": "F", "Heat Index": "F", "Wind Chill": "F", "Soil Temp": "F", "Remote Temp": "F", "Remote Humid": "%", "WindSpeedAvg": "mph"}, "time_format": "12_hour", "date_format": "mm/dd", "header_images": [], "background_images": []}}]}}
2022-06-16 20:14:00,324 Thread-62 udi_interface INFO AcuriteManager:getHubDevices: Got Acurite Devices
2022-06-16 20:14:00,325 Thread-62 udi_interface DEBUG AcuriteController:discover: Device Id: 943425
2022-06-16 20:14:00,326 Thread-62 udi_interface DEBUG AcuriteController:discover: Device Name: Lightning Tower
2022-06-16 20:14:00,327 Thread-62 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 943425, "name": "Lightning Tower", "model_code": "LightningT", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 1, "last_check_in_at": "2022-06-17T00:11:57.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-17.json"], "temp_high_value": "97.6", "temp_high_at": "12:36 PM", "temp_low_value": "75.6", "temp_low_at": "5:56 AM", "daily_cumulative_strikes": 73, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2019-10-02T21:32:52.220Z", "sensors": [{"id": 4356815, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "84.1", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 4356814, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "99", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 4356813, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "55", "channel": 3, "chart_unit": "F"}, {"id": 4356812, "sensor_code": "Heat Index", "sensor_name": "Heat Index", "last_reading_value": "103", "channel": 4, "chart_unit": "F"}, {"id": 4356811, "sensor_code": "Interference", "sensor_name": "Interference", "last_reading_value": "1", "channel": 5, "chart_unit": null}, {"id": 4356807, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.06", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [{"id": 4356810, "sensor_code": "LightningStrikeCnt", "sensor_name": "Lightning Strike Count", "last_reading_value": "27", "channel": 6, "chart_unit": null}, {"id": 4356809, "sensor_code": "LightningClosestStrikeDist", "sensor_name": "Lightning Closest Strike Distance", "last_reading_value": "4", "channel": 7, "chart_unit": "MI"}, {"id": 4356808, "sensor_code": "LightningLastStrikeDist", "sensor_name": "Lightning Last Strike Distance", "last_reading_value": "4", "channel": 8, "chart_unit": "MI"}], "model": {"id": 6077, "code": "LightningT", "description": "Lightning Tower", "has_wifi": false}}
2022-06-16 20:14:00,328 Thread-62 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:14:00,328 Thread-62 udi_interface INFO AcuriteController:discover: Node 943425 already exists, skipping
2022-06-16 20:14:00,329 Thread-62 udi_interface DEBUG AcuriteLightningTNode:update: AcuriteLightningTNode - update
2022-06-16 20:14:00,330 Thread-62 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV1's value
2022-06-16 20:14:00,331 Thread-62 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV2's value
2022-06-16 20:14:01,065 Thread-62 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLITEMP's value
2022-06-16 20:14:01,066 Thread-62 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Temp: 84.1 F
2022-06-16 20:14:01,711 Thread-62 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLIHUM's value
2022-06-16 20:14:01,711 Thread-62 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Humidity: 99 %RH
2022-06-16 20:14:02,212 Thread-62 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in DEWPT's value
2022-06-16 20:14:02,213 Thread-62 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Dew Point: 55 F
2022-06-16 20:14:02,668 Thread-62 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in BARPRES's value
2022-06-16 20:14:02,669 Thread-62 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Barometric Pressure: 30.06 inHg
2022-06-16 20:14:03,729 Thread-62 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV4's value
2022-06-16 20:14:03,730 Thread-62 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Heat Index: 103 F
2022-06-16 20:14:04,296 Thread-62 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV5's value
2022-06-16 20:14:04,297 Thread-62 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Strike Count: 27 None
2022-06-16 20:14:04,863 Thread-62 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV6's value
2022-06-16 20:14:04,864 Thread-62 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Last Strike Distance: 4 MI
2022-06-16 20:14:05,441 Thread-62 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV8's value
2022-06-16 20:14:05,442 Thread-62 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Closest Strike Distance: 4 MI
2022-06-16 20:14:05,443 Thread-62 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV3 to 2 to Polyglot
2022-06-16 20:14:05,443 Thread-62 udi_interface.node DEBUG node:reportDriver: Updating value to 2
2022-06-16 20:14:05,444 Thread-62 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV3', 'value': '2', 'uom': '45'}]}
2022-06-16 20:14:05,446 Thread-62 udi_interface DEBUG AcuriteController:discover: Device Id: 313855
2022-06-16 20:14:05,447 Thread-62 udi_interface DEBUG AcuriteController:discover: Device Name: AC Temps
2022-06-16 20:14:05,448 Thread-62 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 313855, "name": "AC Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 3, "last_check_in_at": "2022-06-17T00:11:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "78.6", "temp_high_at": "6:41 PM", "temp_low_value": "53.0", "temp_low_at": "3:41 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2017-01-11T17:01:42.630Z", "sensors": [{"id": 1211149, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "71.9", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 1211150, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "75", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 1211151, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "64", "channel": 3, "chart_unit": "F"}, {"id": 1211148, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.06", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:14:05,448 Thread-62 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:14:05,449 Thread-62 udi_interface INFO AcuriteController:discover: Node 313855 already exists, skipping
2022-06-16 20:14:05,450 Thread-62 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV1's value
2022-06-16 20:14:05,450 Thread-62 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV2's value
2022-06-16 20:14:05,583 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV3 to 2 UOM 45
2022-06-16 20:14:05,935 Thread-62 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLITEMP's value
2022-06-16 20:14:05,935 Thread-62 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Temp: 71.9 F
2022-06-16 20:14:06,392 Thread-62 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLIHUM's value
2022-06-16 20:14:06,392 Thread-62 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Humidity: 75 %RH
2022-06-16 20:14:06,876 Thread-62 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in DEWPT's value
2022-06-16 20:14:06,876 Thread-62 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Dew Point: 64 F
2022-06-16 20:14:07,324 Thread-62 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in BARPRES's value
2022-06-16 20:14:07,324 Thread-62 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Barometric Pressure: 30.06 inHg
2022-06-16 20:14:07,325 Thread-62 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set GV3 to 2 to Polyglot
2022-06-16 20:14:07,325 Thread-62 udi_interface.node DEBUG node:reportDriver: Updating value to 2
2022-06-16 20:14:07,326 Thread-62 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'GV3', 'value': '2', 'uom': '45'}]}
2022-06-16 20:14:07,328 Thread-62 udi_interface DEBUG AcuriteController:discover: Device Id: 1065633
2022-06-16 20:14:07,328 Thread-62 udi_interface DEBUG AcuriteController:discover: Device Name: Bedroom Temps
2022-06-16 20:14:07,329 Thread-62 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 1065633, "name": "Bedroom Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 4, "last_check_in_at": "2022-06-17T00:11:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "79.7", "temp_high_at": "12:46 PM", "temp_low_value": "77.5", "temp_low_at": "1:36 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2020-09-06T21:46:43.678Z", "sensors": [{"id": 5041656, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "78.4", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 5041657, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "50", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 5041658, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 5041655, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.06", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:14:07,330 Thread-62 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:14:07,331 Thread-62 udi_interface INFO AcuriteController:discover: Node 1065633 already exists, skipping
2022-06-16 20:14:07,331 Thread-62 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV1's value
2022-06-16 20:14:07,332 Thread-62 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV2's value
2022-06-16 20:14:07,465 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: GV3 to 2 UOM 45
2022-06-16 20:14:07,891 Thread-62 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLITEMP's value
2022-06-16 20:14:07,892 Thread-62 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Temp: 78.4 F
2022-06-16 20:14:08,558 Thread-62 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLIHUM's value
2022-06-16 20:14:08,559 Thread-62 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Humidity: 50 %RH
2022-06-16 20:14:09,161 Thread-62 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in DEWPT's value
2022-06-16 20:14:09,161 Thread-62 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Dew Point: 58 F
2022-06-16 20:14:09,734 Thread-62 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in BARPRES's value
2022-06-16 20:14:09,734 Thread-62 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Barometric Pressure: 30.06 inHg
2022-06-16 20:14:09,735 Thread-62 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set GV3 to 2 to Polyglot
2022-06-16 20:14:09,735 Thread-62 udi_interface.node DEBUG node:reportDriver: Updating value to 2
2022-06-16 20:14:09,736 Thread-62 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'GV3', 'value': '2', 'uom': '45'}]}
2022-06-16 20:14:09,738 Thread-62 udi_interface INFO AcuriteController:query: AcuriteController - query
2022-06-16 20:14:09,846 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: GV3 to 2 UOM 45
2022-06-16 20:14:57,700 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll
2022-06-16 20:14:57,702 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll
2022-06-16 20:14:57,703 Thread-63 udi_interface INFO AcuriteController:poll: longPoll (controller)
2022-06-16 20:14:58,174 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2022-06-16 20:14:58,176 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2022-06-16 20:14:58,177 Thread-64 udi_interface INFO AcuriteController:poll: shortPoll (controller)
2022-06-16 20:14:58,179 Thread-64 udi_interface INFO AcuriteController:discover: Starting Acurite Device Discovery
2022-06-16 20:14:58,179 Thread-64 udi_interface INFO AcuriteController:discover: acurite_user: tlightne@aim.com
2022-06-16 20:14:58,995 Thread-64 udi_interface INFO AcuriteManager:login: Login HTTP Status Code: 200
2022-06-16 20:14:58,996 Thread-64 udi_interface DEBUG AcuriteManager:login: {"token_id": "13580ee4-ff20-4ff7-a4d2-155b699216cb", "user": {"id": 34604, "email": "tlightne@aim.com", "first_name": "Terry", "last_name": "Lightner", "full_name": "Terry Lightner", "language": "en/us", "session_timeout": 7776000, "failed_login_count": 15, "is_locked": false, "default_user_contact_id": 38708, "password_set_token": null, "permissions": ["Account User-32858", "Account User-32858-Clock", "Account User-32858-Sensor", "Account User-32858-Bell Controller", "Account Admin-32858", "Account Admin-32858-Clock", "Account Admin-32858-Sensor", "Account Admin-32858-Bell Controller", "Account Manager-32858", "Account Manager-32858-Clock", "Account Manager-32858-Sensor", "Account Manager-32858-Bell Controller", "Network Admin-32858", "Network Admin-32858-Clock", "Network Admin-32858-Sensor", "Network Admin-32858-Bell Controller"], "user_contacts": [{"id": 38708, "user_id": 34604, "contact_type": "email", "value": "tlightne@aim.com", "name": "Default email", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 52558, "user_id": 34604, "contact_type": "android", "value": "fXomgUZZOZc:APA91bGp5qAhdyu9QgEneDASam1286SxRRp-VO6yv7rZLrS2ykL6KGI8Uj5XnGcee8-iWYvjqpg5LYbH_6Tzj9K9IAkF3xiIb6eQvY87sB_f1Bwj_KftKcGLVQ3iyUto1ZoOsEJx8cQP", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/51452137-2b9e-3daf-86e9-131a661185bc", "mri_monitor_states": []}, {"id": 60620, "user_id": 34604, "contact_type": "phone", "value": "9417180409", "name": "AC Temps", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 509896, "user_id": 34604, "contact_type": "android", "value": "fXANtCdsSu6DSZhlP5_SNk:APA91bGYor1EZCr-H4NbxXXGGvJxLLDRyC8FrKHBkf2hdSuu0PZUTdzS9k08QDOU2h0C9ushtIG2-5pVgyZwsiGxx7JTy87oZQtU4RLrEKeWOonZR-CSFooC2Ym6KbVEAzh64-hndgEr", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/f97f465d-27db-3345-88b9-281db46deeec", "mri_monitor_states": []}], "account_users": [{"id": 34744, "account_id": 32858, "is_active": true, "web_theme": "light", "account": {"id": 32858, "name": "MAR Acct", "street_address_1": "3275 26th Ave East Lot 7", "street_address_2": "", "city": "Bradenton", "state_province": "FL", "zip": "34208", "country_code": "US", "show_tenths": true, "measurement_system_id": 1, "timezone": "America/New_York", "map_center_point": {"lat": 0.0, "lng": 0.0}, "map_zoom_level": 8, "map_view": "current_temp", "map_views": ["current_temp", "todays_rain", "current_wind"], "measurement_system_units": {"LightningClosestStrikeDist": "MI", "IndoorTemperature": "F", "IndoorHumidity": "%", "LightningLastStrikeDist": "MI", "Water Leak": "V", "Temperature": "F", "Humidity": "%", "WaterFlowRate": "gal", "WaterTemp": "F", "Barometric Pressure": "inHg", "Wind Speed": "mph", "Rainfall": "in", "Rainrate": "in", "Feels Like": "F", "Dew Point": "F", "Heat Index": "F", "Wind Chill": "F", "Soil Temp": "F", "Remote Temp": "F", "Remote Humid": "%", "WindSpeedAvg": "mph"}, "time_format": "12_hour", "date_format": "mm/dd", "header_images": [], "background_images": []}}]}}
2022-06-16 20:15:00,295 Thread-64 udi_interface INFO AcuriteManager:getHubDevices: Got Acurite Devices
2022-06-16 20:15:00,297 Thread-64 udi_interface DEBUG AcuriteController:discover: Device Id: 943425
2022-06-16 20:15:00,297 Thread-64 udi_interface DEBUG AcuriteController:discover: Device Name: Lightning Tower
2022-06-16 20:15:00,298 Thread-64 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 943425, "name": "Lightning Tower", "model_code": "LightningT", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 1, "last_check_in_at": "2022-06-17T00:11:57.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-17.json"], "temp_high_value": "97.6", "temp_high_at": "12:36 PM", "temp_low_value": "75.6", "temp_low_at": "5:56 AM", "daily_cumulative_strikes": 73, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2019-10-02T21:32:52.220Z", "sensors": [{"id": 4356815, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "84.1", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 4356814, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "99", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 4356813, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "55", "channel": 3, "chart_unit": "F"}, {"id": 4356812, "sensor_code": "Heat Index", "sensor_name": "Heat Index", "last_reading_value": "103", "channel": 4, "chart_unit": "F"}, {"id": 4356811, "sensor_code": "Interference", "sensor_name": "Interference", "last_reading_value": "1", "channel": 5, "chart_unit": null}, {"id": 4356807, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.06", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [{"id": 4356810, "sensor_code": "LightningStrikeCnt", "sensor_name": "Lightning Strike Count", "last_reading_value": "27", "channel": 6, "chart_unit": null}, {"id": 4356809, "sensor_code": "LightningClosestStrikeDist", "sensor_name": "Lightning Closest Strike Distance", "last_reading_value": "4", "channel": 7, "chart_unit": "MI"}, {"id": 4356808, "sensor_code": "LightningLastStrikeDist", "sensor_name": "Lightning Last Strike Distance", "last_reading_value": "4", "channel": 8, "chart_unit": "MI"}], "model": {"id": 6077, "code": "LightningT", "description": "Lightning Tower", "has_wifi": false}}
2022-06-16 20:15:00,299 Thread-64 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:15:00,300 Thread-64 udi_interface INFO AcuriteController:discover: Node 943425 already exists, skipping
2022-06-16 20:15:00,300 Thread-64 udi_interface DEBUG AcuriteLightningTNode:update: AcuriteLightningTNode - update
2022-06-16 20:15:00,301 Thread-64 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV1's value
2022-06-16 20:15:00,302 Thread-64 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV2's value
2022-06-16 20:15:01,031 Thread-64 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLITEMP's value
2022-06-16 20:15:01,032 Thread-64 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Temp: 84.1 F
2022-06-16 20:15:01,654 Thread-64 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLIHUM's value
2022-06-16 20:15:01,654 Thread-64 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Humidity: 99 %RH
2022-06-16 20:15:02,106 Thread-64 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in DEWPT's value
2022-06-16 20:15:02,106 Thread-64 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Dew Point: 55 F
2022-06-16 20:15:02,559 Thread-64 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in BARPRES's value
2022-06-16 20:15:02,560 Thread-64 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Barometric Pressure: 30.06 inHg
2022-06-16 20:15:03,465 Thread-64 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV4's value
2022-06-16 20:15:03,466 Thread-64 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Heat Index: 103 F
2022-06-16 20:15:03,950 Thread-64 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV5's value
2022-06-16 20:15:03,950 Thread-64 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Strike Count: 27 None
2022-06-16 20:15:04,395 Thread-64 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV6's value
2022-06-16 20:15:04,395 Thread-64 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Last Strike Distance: 4 MI
2022-06-16 20:15:04,847 Thread-64 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV8's value
2022-06-16 20:15:04,848 Thread-64 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Closest Strike Distance: 4 MI
2022-06-16 20:15:04,849 Thread-64 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV3 to 3 to Polyglot
2022-06-16 20:15:04,849 Thread-64 udi_interface.node DEBUG node:reportDriver: Updating value to 3
2022-06-16 20:15:04,850 Thread-64 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV3', 'value': '3', 'uom': '45'}]}
2022-06-16 20:15:04,852 Thread-64 udi_interface DEBUG AcuriteController:discover: Device Id: 313855
2022-06-16 20:15:04,853 Thread-64 udi_interface DEBUG AcuriteController:discover: Device Name: AC Temps
2022-06-16 20:15:04,854 Thread-64 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 313855, "name": "AC Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 3, "last_check_in_at": "2022-06-17T00:11:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "78.6", "temp_high_at": "6:41 PM", "temp_low_value": "53.0", "temp_low_at": "3:41 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2017-01-11T17:01:42.630Z", "sensors": [{"id": 1211149, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "71.9", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 1211150, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "75", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 1211151, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "64", "channel": 3, "chart_unit": "F"}, {"id": 1211148, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.06", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:15:04,855 Thread-64 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:15:04,856 Thread-64 udi_interface INFO AcuriteController:discover: Node 313855 already exists, skipping
2022-06-16 20:15:04,857 Thread-64 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV1's value
2022-06-16 20:15:04,857 Thread-64 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV2's value
2022-06-16 20:15:04,987 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV3 to 3 UOM 45
2022-06-16 20:15:05,340 Thread-64 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLITEMP's value
2022-06-16 20:15:05,341 Thread-64 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Temp: 71.9 F
2022-06-16 20:15:05,786 Thread-64 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLIHUM's value
2022-06-16 20:15:05,786 Thread-64 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Humidity: 75 %RH
2022-06-16 20:15:06,236 Thread-64 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in DEWPT's value
2022-06-16 20:15:06,237 Thread-64 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Dew Point: 64 F
2022-06-16 20:15:06,680 Thread-64 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in BARPRES's value
2022-06-16 20:15:06,680 Thread-64 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Barometric Pressure: 30.06 inHg
2022-06-16 20:15:06,681 Thread-64 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set GV3 to 3 to Polyglot
2022-06-16 20:15:06,682 Thread-64 udi_interface.node DEBUG node:reportDriver: Updating value to 3
2022-06-16 20:15:06,682 Thread-64 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'GV3', 'value': '3', 'uom': '45'}]}
2022-06-16 20:15:06,684 Thread-64 udi_interface DEBUG AcuriteController:discover: Device Id: 1065633
2022-06-16 20:15:06,685 Thread-64 udi_interface DEBUG AcuriteController:discover: Device Name: Bedroom Temps
2022-06-16 20:15:06,687 Thread-64 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 1065633, "name": "Bedroom Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 4, "last_check_in_at": "2022-06-17T00:11:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "79.7", "temp_high_at": "12:46 PM", "temp_low_value": "77.5", "temp_low_at": "1:36 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2020-09-06T21:46:43.678Z", "sensors": [{"id": 5041656, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "78.4", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 5041657, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "50", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 5041658, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 5041655, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.06", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:15:06,687 Thread-64 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:15:06,688 Thread-64 udi_interface INFO AcuriteController:discover: Node 1065633 already exists, skipping
2022-06-16 20:15:06,689 Thread-64 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV1's value
2022-06-16 20:15:06,689 Thread-64 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV2's value
2022-06-16 20:15:06,819 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: GV3 to 3 UOM 45
2022-06-16 20:15:07,166 Thread-64 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLITEMP's value
2022-06-16 20:15:07,167 Thread-64 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Temp: 78.4 F
2022-06-16 20:15:07,615 Thread-64 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLIHUM's value
2022-06-16 20:15:07,615 Thread-64 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Humidity: 50 %RH
2022-06-16 20:15:08,086 Thread-64 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in DEWPT's value
2022-06-16 20:15:08,087 Thread-64 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Dew Point: 58 F
2022-06-16 20:15:08,745 Thread-64 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in BARPRES's value
2022-06-16 20:15:08,746 Thread-64 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Barometric Pressure: 30.06 inHg
2022-06-16 20:15:08,747 Thread-64 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set GV3 to 3 to Polyglot
2022-06-16 20:15:08,748 Thread-64 udi_interface.node DEBUG node:reportDriver: Updating value to 3
2022-06-16 20:15:08,748 Thread-64 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'GV3', 'value': '3', 'uom': '45'}]}
2022-06-16 20:15:08,750 Thread-64 udi_interface INFO AcuriteController:query: AcuriteController - query
2022-06-16 20:15:08,871 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: GV3 to 3 UOM 45
2022-06-16 20:15:58,203 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2022-06-16 20:15:58,204 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2022-06-16 20:15:58,206 Thread-65 udi_interface INFO AcuriteController:poll: shortPoll (controller)
2022-06-16 20:15:58,207 Thread-65 udi_interface INFO AcuriteController:discover: Starting Acurite Device Discovery
2022-06-16 20:15:58,208 Thread-65 udi_interface INFO AcuriteController:discover: acurite_user: tlightne@aim.com
2022-06-16 20:15:59,118 Thread-65 udi_interface INFO AcuriteManager:login: Login HTTP Status Code: 200
2022-06-16 20:15:59,120 Thread-65 udi_interface DEBUG AcuriteManager:login: {"token_id": "2468e1c8-a47e-487d-8881-3f2e0930ba9d", "user": {"id": 34604, "email": "tlightne@aim.com", "first_name": "Terry", "last_name": "Lightner", "full_name": "Terry Lightner", "language": "en/us", "session_timeout": 7776000, "failed_login_count": 15, "is_locked": false, "default_user_contact_id": 38708, "password_set_token": null, "permissions": ["Account User-32858", "Account User-32858-Clock", "Account User-32858-Sensor", "Account User-32858-Bell Controller", "Account Admin-32858", "Account Admin-32858-Clock", "Account Admin-32858-Sensor", "Account Admin-32858-Bell Controller", "Account Manager-32858", "Account Manager-32858-Clock", "Account Manager-32858-Sensor", "Account Manager-32858-Bell Controller", "Network Admin-32858", "Network Admin-32858-Clock", "Network Admin-32858-Sensor", "Network Admin-32858-Bell Controller"], "user_contacts": [{"id": 38708, "user_id": 34604, "contact_type": "email", "value": "tlightne@aim.com", "name": "Default email", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 52558, "user_id": 34604, "contact_type": "android", "value": "fXomgUZZOZc:APA91bGp5qAhdyu9QgEneDASam1286SxRRp-VO6yv7rZLrS2ykL6KGI8Uj5XnGcee8-iWYvjqpg5LYbH_6Tzj9K9IAkF3xiIb6eQvY87sB_f1Bwj_KftKcGLVQ3iyUto1ZoOsEJx8cQP", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/51452137-2b9e-3daf-86e9-131a661185bc", "mri_monitor_states": []}, {"id": 60620, "user_id": 34604, "contact_type": "phone", "value": "9417180409", "name": "AC Temps", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 509896, "user_id": 34604, "contact_type": "android", "value": "fXANtCdsSu6DSZhlP5_SNk:APA91bGYor1EZCr-H4NbxXXGGvJxLLDRyC8FrKHBkf2hdSuu0PZUTdzS9k08QDOU2h0C9ushtIG2-5pVgyZwsiGxx7JTy87oZQtU4RLrEKeWOonZR-CSFooC2Ym6KbVEAzh64-hndgEr", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/f97f465d-27db-3345-88b9-281db46deeec", "mri_monitor_states": []}], "account_users": [{"id": 34744, "account_id": 32858, "is_active": true, "web_theme": "light", "account": {"id": 32858, "name": "MAR Acct", "street_address_1": "3275 26th Ave East Lot 7", "street_address_2": "", "city": "Bradenton", "state_province": "FL", "zip": "34208", "country_code": "US", "show_tenths": true, "measurement_system_id": 1, "timezone": "America/New_York", "map_center_point": {"lat": 0.0, "lng": 0.0}, "map_zoom_level": 8, "map_view": "current_temp", "map_views": ["current_temp", "todays_rain", "current_wind"], "measurement_system_units": {"LightningClosestStrikeDist": "MI", "IndoorTemperature": "F", "IndoorHumidity": "%", "LightningLastStrikeDist": "MI", "Water Leak": "V", "Temperature": "F", "Humidity": "%", "WaterFlowRate": "gal", "WaterTemp": "F", "Barometric Pressure": "inHg", "Wind Speed": "mph", "Rainfall": "in", "Rainrate": "in", "Feels Like": "F", "Dew Point": "F", "Heat Index": "F", "Wind Chill": "F", "Soil Temp": "F", "Remote Temp": "F", "Remote Humid": "%", "WindSpeedAvg": "mph"}, "time_format": "12_hour", "date_format": "mm/dd", "header_images": [], "background_images": []}}]}}
2022-06-16 20:16:00,689 Thread-65 udi_interface INFO AcuriteManager:getHubDevices: Got Acurite Devices
2022-06-16 20:16:00,691 Thread-65 udi_interface DEBUG AcuriteController:discover: Device Id: 943425
2022-06-16 20:16:00,691 Thread-65 udi_interface DEBUG AcuriteController:discover: Device Name: Lightning Tower
2022-06-16 20:16:00,692 Thread-65 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 943425, "name": "Lightning Tower", "model_code": "LightningT", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 1, "last_check_in_at": "2022-06-17T00:11:57.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-17.json"], "temp_high_value": "97.6", "temp_high_at": "12:36 PM", "temp_low_value": "75.6", "temp_low_at": "5:56 AM", "daily_cumulative_strikes": 73, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2019-10-02T21:32:52.220Z", "sensors": [{"id": 4356815, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "84.1", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 4356814, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "99", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 4356813, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "55", "channel": 3, "chart_unit": "F"}, {"id": 4356812, "sensor_code": "Heat Index", "sensor_name": "Heat Index", "last_reading_value": "103", "channel": 4, "chart_unit": "F"}, {"id": 4356811, "sensor_code": "Interference", "sensor_name": "Interference", "last_reading_value": "1", "channel": 5, "chart_unit": null}, {"id": 4356807, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.06", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [{"id": 4356810, "sensor_code": "LightningStrikeCnt", "sensor_name": "Lightning Strike Count", "last_reading_value": "27", "channel": 6, "chart_unit": null}, {"id": 4356809, "sensor_code": "LightningClosestStrikeDist", "sensor_name": "Lightning Closest Strike Distance", "last_reading_value": "4", "channel": 7, "chart_unit": "MI"}, {"id": 4356808, "sensor_code": "LightningLastStrikeDist", "sensor_name": "Lightning Last Strike Distance", "last_reading_value": "4", "channel": 8, "chart_unit": "MI"}], "model": {"id": 6077, "code": "LightningT", "description": "Lightning Tower", "has_wifi": false}}
2022-06-16 20:16:00,693 Thread-65 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:16:00,694 Thread-65 udi_interface INFO AcuriteController:discover: Node 943425 already exists, skipping
2022-06-16 20:16:00,694 Thread-65 udi_interface DEBUG AcuriteLightningTNode:update: AcuriteLightningTNode - update
2022-06-16 20:16:00,695 Thread-65 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV1's value
2022-06-16 20:16:00,696 Thread-65 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV2's value
2022-06-16 20:16:01,427 Thread-65 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLITEMP's value
2022-06-16 20:16:01,428 Thread-65 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Temp: 84.1 F
2022-06-16 20:16:02,119 Thread-65 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLIHUM's value
2022-06-16 20:16:02,120 Thread-65 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Humidity: 99 %RH
2022-06-16 20:16:02,634 Thread-65 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in DEWPT's value
2022-06-16 20:16:02,635 Thread-65 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Dew Point: 55 F
2022-06-16 20:16:03,084 Thread-65 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in BARPRES's value
2022-06-16 20:16:03,085 Thread-65 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Barometric Pressure: 30.06 inHg
2022-06-16 20:16:04,027 Thread-65 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV4's value
2022-06-16 20:16:04,028 Thread-65 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Heat Index: 103 F
2022-06-16 20:16:04,649 Thread-65 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV5's value
2022-06-16 20:16:04,650 Thread-65 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Strike Count: 27 None
2022-06-16 20:16:05,102 Thread-65 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV6's value
2022-06-16 20:16:05,103 Thread-65 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Last Strike Distance: 4 MI
2022-06-16 20:16:05,552 Thread-65 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV8's value
2022-06-16 20:16:05,553 Thread-65 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Closest Strike Distance: 4 MI
2022-06-16 20:16:05,553 Thread-65 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV3 to 4 to Polyglot
2022-06-16 20:16:05,554 Thread-65 udi_interface.node DEBUG node:reportDriver: Updating value to 4
2022-06-16 20:16:05,554 Thread-65 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV3', 'value': '4', 'uom': '45'}]}
2022-06-16 20:16:05,556 Thread-65 udi_interface DEBUG AcuriteController:discover: Device Id: 313855
2022-06-16 20:16:05,557 Thread-65 udi_interface DEBUG AcuriteController:discover: Device Name: AC Temps
2022-06-16 20:16:05,558 Thread-65 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 313855, "name": "AC Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 3, "last_check_in_at": "2022-06-17T00:11:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "78.6", "temp_high_at": "6:41 PM", "temp_low_value": "53.0", "temp_low_at": "3:41 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2017-01-11T17:01:42.630Z", "sensors": [{"id": 1211149, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "71.9", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 1211150, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "75", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 1211151, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "64", "channel": 3, "chart_unit": "F"}, {"id": 1211148, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.06", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:16:05,559 Thread-65 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:16:05,559 Thread-65 udi_interface INFO AcuriteController:discover: Node 313855 already exists, skipping
2022-06-16 20:16:05,560 Thread-65 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV1's value
2022-06-16 20:16:05,561 Thread-65 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV2's value
2022-06-16 20:16:05,705 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV3 to 4 UOM 45
2022-06-16 20:16:06,047 Thread-65 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLITEMP's value
2022-06-16 20:16:06,048 Thread-65 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Temp: 71.9 F
2022-06-16 20:16:06,531 Thread-65 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLIHUM's value
2022-06-16 20:16:06,532 Thread-65 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Humidity: 75 %RH
2022-06-16 20:16:06,990 Thread-65 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in DEWPT's value
2022-06-16 20:16:06,990 Thread-65 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Dew Point: 64 F
2022-06-16 20:16:07,444 Thread-65 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in BARPRES's value
2022-06-16 20:16:07,445 Thread-65 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Barometric Pressure: 30.06 inHg
2022-06-16 20:16:07,445 Thread-65 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set GV3 to 4 to Polyglot
2022-06-16 20:16:07,446 Thread-65 udi_interface.node DEBUG node:reportDriver: Updating value to 4
2022-06-16 20:16:07,446 Thread-65 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'GV3', 'value': '4', 'uom': '45'}]}
2022-06-16 20:16:07,448 Thread-65 udi_interface DEBUG AcuriteController:discover: Device Id: 1065633
2022-06-16 20:16:07,449 Thread-65 udi_interface DEBUG AcuriteController:discover: Device Name: Bedroom Temps
2022-06-16 20:16:07,450 Thread-65 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 1065633, "name": "Bedroom Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 4, "last_check_in_at": "2022-06-17T00:11:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "79.7", "temp_high_at": "12:46 PM", "temp_low_value": "77.5", "temp_low_at": "1:36 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2020-09-06T21:46:43.678Z", "sensors": [{"id": 5041656, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "78.4", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 5041657, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "50", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 5041658, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 5041655, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.06", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:16:07,451 Thread-65 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:16:07,451 Thread-65 udi_interface INFO AcuriteController:discover: Node 1065633 already exists, skipping
2022-06-16 20:16:07,452 Thread-65 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV1's value
2022-06-16 20:16:07,453 Thread-65 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV2's value
2022-06-16 20:16:07,594 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: GV3 to 4 UOM 45
2022-06-16 20:16:07,936 Thread-65 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLITEMP's value
2022-06-16 20:16:07,937 Thread-65 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Temp: 78.4 F
2022-06-16 20:16:08,389 Thread-65 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLIHUM's value
2022-06-16 20:16:08,390 Thread-65 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Humidity: 50 %RH
2022-06-16 20:16:08,942 Thread-65 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in DEWPT's value
2022-06-16 20:16:08,943 Thread-65 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Dew Point: 58 F
2022-06-16 20:16:09,390 Thread-65 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in BARPRES's value
2022-06-16 20:16:09,391 Thread-65 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Barometric Pressure: 30.06 inHg
2022-06-16 20:16:09,391 Thread-65 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set GV3 to 4 to Polyglot
2022-06-16 20:16:09,392 Thread-65 udi_interface.node DEBUG node:reportDriver: Updating value to 4
2022-06-16 20:16:09,393 Thread-65 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'GV3', 'value': '4', 'uom': '45'}]}
2022-06-16 20:16:09,395 Thread-65 udi_interface INFO AcuriteController:query: AcuriteController - query
2022-06-16 20:16:09,512 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: GV3 to 4 UOM 45
2022-06-16 20:16:58,216 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2022-06-16 20:16:58,217 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2022-06-16 20:16:58,219 Thread-66 udi_interface INFO AcuriteController:poll: shortPoll (controller)
2022-06-16 20:16:58,220 Thread-66 udi_interface INFO AcuriteController:discover: Starting Acurite Device Discovery
2022-06-16 20:16:58,221 Thread-66 udi_interface INFO AcuriteController:discover: acurite_user: tlightne@aim.com
2022-06-16 20:16:59,058 Thread-66 udi_interface INFO AcuriteManager:login: Login HTTP Status Code: 200
2022-06-16 20:16:59,059 Thread-66 udi_interface DEBUG AcuriteManager:login: {"token_id": "5ac9c974-8f05-42c5-bc45-f96b2c40ce11", "user": {"id": 34604, "email": "tlightne@aim.com", "first_name": "Terry", "last_name": "Lightner", "full_name": "Terry Lightner", "language": "en/us", "session_timeout": 7776000, "failed_login_count": 15, "is_locked": false, "default_user_contact_id": 38708, "password_set_token": null, "permissions": ["Account User-32858", "Account User-32858-Clock", "Account User-32858-Sensor", "Account User-32858-Bell Controller", "Account Admin-32858", "Account Admin-32858-Clock", "Account Admin-32858-Sensor", "Account Admin-32858-Bell Controller", "Account Manager-32858", "Account Manager-32858-Clock", "Account Manager-32858-Sensor", "Account Manager-32858-Bell Controller", "Network Admin-32858", "Network Admin-32858-Clock", "Network Admin-32858-Sensor", "Network Admin-32858-Bell Controller"], "user_contacts": [{"id": 38708, "user_id": 34604, "contact_type": "email", "value": "tlightne@aim.com", "name": "Default email", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 52558, "user_id": 34604, "contact_type": "android", "value": "fXomgUZZOZc:APA91bGp5qAhdyu9QgEneDASam1286SxRRp-VO6yv7rZLrS2ykL6KGI8Uj5XnGcee8-iWYvjqpg5LYbH_6Tzj9K9IAkF3xiIb6eQvY87sB_f1Bwj_KftKcGLVQ3iyUto1ZoOsEJx8cQP", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/51452137-2b9e-3daf-86e9-131a661185bc", "mri_monitor_states": []}, {"id": 60620, "user_id": 34604, "contact_type": "phone", "value": "9417180409", "name": "AC Temps", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 509896, "user_id": 34604, "contact_type": "android", "value": "fXANtCdsSu6DSZhlP5_SNk:APA91bGYor1EZCr-H4NbxXXGGvJxLLDRyC8FrKHBkf2hdSuu0PZUTdzS9k08QDOU2h0C9ushtIG2-5pVgyZwsiGxx7JTy87oZQtU4RLrEKeWOonZR-CSFooC2Ym6KbVEAzh64-hndgEr", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/f97f465d-27db-3345-88b9-281db46deeec", "mri_monitor_states": []}], "account_users": [{"id": 34744, "account_id": 32858, "is_active": true, "web_theme": "light", "account": {"id": 32858, "name": "MAR Acct", "street_address_1": "3275 26th Ave East Lot 7", "street_address_2": "", "city": "Bradenton", "state_province": "FL", "zip": "34208", "country_code": "US", "show_tenths": true, "measurement_system_id": 1, "timezone": "America/New_York", "map_center_point": {"lat": 0.0, "lng": 0.0}, "map_zoom_level": 8, "map_view": "current_temp", "map_views": ["current_temp", "todays_rain", "current_wind"], "measurement_system_units": {"LightningClosestStrikeDist": "MI", "IndoorTemperature": "F", "IndoorHumidity": "%", "LightningLastStrikeDist": "MI", "Water Leak": "V", "Temperature": "F", "Humidity": "%", "WaterFlowRate": "gal", "WaterTemp": "F", "Barometric Pressure": "inHg", "Wind Speed": "mph", "Rainfall": "in", "Rainrate": "in", "Feels Like": "F", "Dew Point": "F", "Heat Index": "F", "Wind Chill": "F", "Soil Temp": "F", "Remote Temp": "F", "Remote Humid": "%", "WindSpeedAvg": "mph"}, "time_format": "12_hour", "date_format": "mm/dd", "header_images": [], "background_images": []}}]}}
2022-06-16 20:17:00,598 Thread-66 udi_interface INFO AcuriteManager:getHubDevices: Got Acurite Devices
2022-06-16 20:17:00,600 Thread-66 udi_interface DEBUG AcuriteController:discover: Device Id: 943425
2022-06-16 20:17:00,600 Thread-66 udi_interface DEBUG AcuriteController:discover: Device Name: Lightning Tower
2022-06-16 20:17:00,602 Thread-66 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 943425, "name": "Lightning Tower", "model_code": "LightningT", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 1, "last_check_in_at": "2022-06-17T00:16:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-17.json"], "temp_high_value": "97.6", "temp_high_at": "12:36 PM", "temp_low_value": "75.6", "temp_low_at": "5:56 AM", "daily_cumulative_strikes": 109, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2019-10-02T21:32:52.220Z", "sensors": [{"id": 4356815, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "83.9", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 4356814, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "103", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 4356813, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 4356812, "sensor_code": "Heat Index", "sensor_name": "Heat Index", "last_reading_value": "105", "channel": 4, "chart_unit": "F"}, {"id": 4356811, "sensor_code": "Interference", "sensor_name": "Interference", "last_reading_value": "1", "channel": 5, "chart_unit": null}, {"id": 4356807, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.04", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [{"id": 4356810, "sensor_code": "LightningStrikeCnt", "sensor_name": "Lightning Strike Count", "last_reading_value": "36", "channel": 6, "chart_unit": null}, {"id": 4356809, "sensor_code": "LightningClosestStrikeDist", "sensor_name": "Lightning Closest Strike Distance", "last_reading_value": "3", "channel": 7, "chart_unit": "MI"}, {"id": 4356808, "sensor_code": "LightningLastStrikeDist", "sensor_name": "Lightning Last Strike Distance", "last_reading_value": "3", "channel": 8, "chart_unit": "MI"}], "model": {"id": 6077, "code": "LightningT", "description": "Lightning Tower", "has_wifi": false}}
2022-06-16 20:17:00,602 Thread-66 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:17:00,603 Thread-66 udi_interface INFO AcuriteController:discover: Node 943425 already exists, skipping
2022-06-16 20:17:00,604 Thread-66 udi_interface DEBUG AcuriteLightningTNode:update: AcuriteLightningTNode - update
2022-06-16 20:17:00,604 Thread-66 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV1's value
2022-06-16 20:17:00,605 Thread-66 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV2's value
2022-06-16 20:17:01,339 Thread-66 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set CLITEMP to 83.9 to Polyglot
2022-06-16 20:17:01,340 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 83.9
2022-06-16 20:17:01,340 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'CLITEMP', 'value': '83.9', 'uom': '17'}]}
2022-06-16 20:17:01,342 Thread-66 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Temp: 83.9 F
2022-06-16 20:17:01,483 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: CLITEMP to 83.9 UOM 17
2022-06-16 20:17:01,928 Thread-66 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set CLIHUM to 103 to Polyglot
2022-06-16 20:17:01,929 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 103
2022-06-16 20:17:01,930 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'CLIHUM', 'value': '103', 'uom': '22'}]}
2022-06-16 20:17:01,932 Thread-66 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Humidity: 103 %RH
2022-06-16 20:17:02,066 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: CLIHUM to 103 UOM 22
2022-06-16 20:17:02,413 Thread-66 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set DEWPT to 58 to Polyglot
2022-06-16 20:17:02,414 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 58
2022-06-16 20:17:02,414 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'DEWPT', 'value': '58', 'uom': '17'}]}
2022-06-16 20:17:02,416 Thread-66 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Dew Point: 58 F
2022-06-16 20:17:02,543 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: DEWPT to 58 UOM 17
2022-06-16 20:17:02,894 Thread-66 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set BARPRES to 30.04 to Polyglot
2022-06-16 20:17:02,895 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 30.04
2022-06-16 20:17:02,895 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'BARPRES', 'value': '30.04', 'uom': '23'}]}
2022-06-16 20:17:02,897 Thread-66 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Barometric Pressure: 30.04 inHg
2022-06-16 20:17:03,037 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: BARPRES to 30.04 UOM 23
2022-06-16 20:17:03,693 Thread-66 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV4 to 105 to Polyglot
2022-06-16 20:17:03,694 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 105
2022-06-16 20:17:03,694 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV4', 'value': '105', 'uom': '17'}]}
2022-06-16 20:17:03,696 Thread-66 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Heat Index: 105 F
2022-06-16 20:17:03,837 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV4 to 105 UOM 17
2022-06-16 20:17:04,301 Thread-66 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV5 to 36 to Polyglot
2022-06-16 20:17:04,302 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 36
2022-06-16 20:17:04,303 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV5', 'value': '36', 'uom': '0'}]}
2022-06-16 20:17:04,304 Thread-66 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Strike Count: 36 None
2022-06-16 20:17:04,443 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV5 to 36 UOM 0
2022-06-16 20:17:04,786 Thread-66 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV6 to 3 to Polyglot
2022-06-16 20:17:04,786 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 3
2022-06-16 20:17:04,787 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV6', 'value': '3', 'uom': '116'}]}
2022-06-16 20:17:04,788 Thread-66 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Last Strike Distance: 3 MI
2022-06-16 20:17:04,926 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV6 to 3 UOM 116
2022-06-16 20:17:05,270 Thread-66 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV8 to 3 to Polyglot
2022-06-16 20:17:05,271 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 3
2022-06-16 20:17:05,272 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV8', 'value': '3', 'uom': '116'}]}
2022-06-16 20:17:05,273 Thread-66 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Closest Strike Distance: 3 MI
2022-06-16 20:17:05,274 Thread-66 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV3 to 0 to Polyglot
2022-06-16 20:17:05,275 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 0
2022-06-16 20:17:05,276 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV3', 'value': '0', 'uom': '45'}]}
2022-06-16 20:17:05,278 Thread-66 udi_interface DEBUG AcuriteController:discover: Device Id: 313855
2022-06-16 20:17:05,278 Thread-66 udi_interface DEBUG AcuriteController:discover: Device Name: AC Temps
2022-06-16 20:17:05,279 Thread-66 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 313855, "name": "AC Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 3, "last_check_in_at": "2022-06-17T00:16:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "78.6", "temp_high_at": "6:41 PM", "temp_low_value": "53.0", "temp_low_at": "3:41 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2017-01-11T17:01:42.630Z", "sensors": [{"id": 1211149, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "63.1", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 1211150, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "71", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 1211151, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "54", "channel": 3, "chart_unit": "F"}, {"id": 1211148, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.04", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:17:05,280 Thread-66 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:17:05,280 Thread-66 udi_interface INFO AcuriteController:discover: Node 313855 already exists, skipping
2022-06-16 20:17:05,281 Thread-66 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV1's value
2022-06-16 20:17:05,282 Thread-66 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV2's value
2022-06-16 20:17:05,412 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV8 to 3 UOM 116
2022-06-16 20:17:05,511 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV3 to 0 UOM 45
2022-06-16 20:17:05,793 Thread-66 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set CLITEMP to 63.1 to Polyglot
2022-06-16 20:17:05,794 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 63.1
2022-06-16 20:17:05,794 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'CLITEMP', 'value': '63.1', 'uom': '17'}]}
2022-06-16 20:17:05,796 Thread-66 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Temp: 63.1 F
2022-06-16 20:17:05,928 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: CLITEMP to 63.1 UOM 17
2022-06-16 20:17:06,276 Thread-66 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set CLIHUM to 71 to Polyglot
2022-06-16 20:17:06,277 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 71
2022-06-16 20:17:06,278 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'CLIHUM', 'value': '71', 'uom': '22'}]}
2022-06-16 20:17:06,279 Thread-66 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Humidity: 71 %RH
2022-06-16 20:17:06,405 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: CLIHUM to 71 UOM 22
2022-06-16 20:17:06,760 Thread-66 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set DEWPT to 54 to Polyglot
2022-06-16 20:17:06,761 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 54
2022-06-16 20:17:06,761 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'DEWPT', 'value': '54', 'uom': '17'}]}
2022-06-16 20:17:06,763 Thread-66 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Dew Point: 54 F
2022-06-16 20:17:06,899 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: DEWPT to 54 UOM 17
2022-06-16 20:17:07,245 Thread-66 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set BARPRES to 30.04 to Polyglot
2022-06-16 20:17:07,246 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 30.04
2022-06-16 20:17:07,247 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'BARPRES', 'value': '30.04', 'uom': '23'}]}
2022-06-16 20:17:07,248 Thread-66 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Barometric Pressure: 30.04 inHg
2022-06-16 20:17:07,249 Thread-66 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set GV3 to 0 to Polyglot
2022-06-16 20:17:07,250 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 0
2022-06-16 20:17:07,251 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'GV3', 'value': '0', 'uom': '45'}]}
2022-06-16 20:17:07,252 Thread-66 udi_interface DEBUG AcuriteController:discover: Device Id: 1065633
2022-06-16 20:17:07,253 Thread-66 udi_interface DEBUG AcuriteController:discover: Device Name: Bedroom Temps
2022-06-16 20:17:07,254 Thread-66 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 1065633, "name": "Bedroom Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 4, "last_check_in_at": "2022-06-17T00:16:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "79.7", "temp_high_at": "12:46 PM", "temp_low_value": "77.5", "temp_low_at": "1:36 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2020-09-06T21:46:43.678Z", "sensors": [{"id": 5041656, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "78.6", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 5041657, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "49", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 5041658, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 5041655, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.04", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:17:07,254 Thread-66 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:17:07,255 Thread-66 udi_interface INFO AcuriteController:discover: Node 1065633 already exists, skipping
2022-06-16 20:17:07,255 Thread-66 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV1's value
2022-06-16 20:17:07,256 Thread-66 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV2's value
2022-06-16 20:17:07,386 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: BARPRES to 30.04 UOM 23
2022-06-16 20:17:07,482 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: GV3 to 0 UOM 45
2022-06-16 20:17:07,773 Thread-66 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set CLITEMP to 78.6 to Polyglot
2022-06-16 20:17:07,774 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 78.6
2022-06-16 20:17:07,774 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'CLITEMP', 'value': '78.6', 'uom': '17'}]}
2022-06-16 20:17:07,776 Thread-66 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Temp: 78.6 F
2022-06-16 20:17:07,916 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: CLITEMP to 78.6 UOM 17
2022-06-16 20:17:08,259 Thread-66 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set CLIHUM to 49 to Polyglot
2022-06-16 20:17:08,260 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 49
2022-06-16 20:17:08,260 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'CLIHUM', 'value': '49', 'uom': '22'}]}
2022-06-16 20:17:08,262 Thread-66 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Humidity: 49 %RH
2022-06-16 20:17:08,388 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: CLIHUM to 49 UOM 22
2022-06-16 20:17:08,740 Thread-66 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in DEWPT's value
2022-06-16 20:17:08,741 Thread-66 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Dew Point: 58 F
2022-06-16 20:17:09,331 Thread-66 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set BARPRES to 30.04 to Polyglot
2022-06-16 20:17:09,332 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 30.04
2022-06-16 20:17:09,333 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'BARPRES', 'value': '30.04', 'uom': '23'}]}
2022-06-16 20:17:09,334 Thread-66 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Barometric Pressure: 30.04 inHg
2022-06-16 20:17:09,335 Thread-66 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set GV3 to 0 to Polyglot
2022-06-16 20:17:09,336 Thread-66 udi_interface.node DEBUG node:reportDriver: Updating value to 0
2022-06-16 20:17:09,337 Thread-66 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'GV3', 'value': '0', 'uom': '45'}]}
2022-06-16 20:17:09,338 Thread-66 udi_interface INFO AcuriteController:query: AcuriteController - query
2022-06-16 20:17:09,470 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: BARPRES to 30.04 UOM 23
2022-06-16 20:17:09,554 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: GV3 to 0 UOM 45
2022-06-16 20:17:58,230 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2022-06-16 20:17:58,231 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2022-06-16 20:17:58,233 Thread-67 udi_interface INFO AcuriteController:poll: shortPoll (controller)
2022-06-16 20:17:58,234 Thread-67 udi_interface INFO AcuriteController:discover: Starting Acurite Device Discovery
2022-06-16 20:17:58,235 Thread-67 udi_interface INFO AcuriteController:discover: acurite_user: tlightne@aim.com
2022-06-16 20:17:59,111 Thread-67 udi_interface INFO AcuriteManager:login: Login HTTP Status Code: 200
2022-06-16 20:17:59,113 Thread-67 udi_interface DEBUG AcuriteManager:login: {"token_id": "394ef80b-b0b8-4016-977a-7d89ce8cb178", "user": {"id": 34604, "email": "tlightne@aim.com", "first_name": "Terry", "last_name": "Lightner", "full_name": "Terry Lightner", "language": "en/us", "session_timeout": 7776000, "failed_login_count": 15, "is_locked": false, "default_user_contact_id": 38708, "password_set_token": null, "permissions": ["Account User-32858", "Account User-32858-Clock", "Account User-32858-Sensor", "Account User-32858-Bell Controller", "Account Admin-32858", "Account Admin-32858-Clock", "Account Admin-32858-Sensor", "Account Admin-32858-Bell Controller", "Account Manager-32858", "Account Manager-32858-Clock", "Account Manager-32858-Sensor", "Account Manager-32858-Bell Controller", "Network Admin-32858", "Network Admin-32858-Clock", "Network Admin-32858-Sensor", "Network Admin-32858-Bell Controller"], "user_contacts": [{"id": 38708, "user_id": 34604, "contact_type": "email", "value": "tlightne@aim.com", "name": "Default email", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 52558, "user_id": 34604, "contact_type": "android", "value": "fXomgUZZOZc:APA91bGp5qAhdyu9QgEneDASam1286SxRRp-VO6yv7rZLrS2ykL6KGI8Uj5XnGcee8-iWYvjqpg5LYbH_6Tzj9K9IAkF3xiIb6eQvY87sB_f1Bwj_KftKcGLVQ3iyUto1ZoOsEJx8cQP", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/51452137-2b9e-3daf-86e9-131a661185bc", "mri_monitor_states": []}, {"id": 60620, "user_id": 34604, "contact_type": "phone", "value": "9417180409", "name": "AC Temps", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 509896, "user_id": 34604, "contact_type": "android", "value": "fXANtCdsSu6DSZhlP5_SNk:APA91bGYor1EZCr-H4NbxXXGGvJxLLDRyC8FrKHBkf2hdSuu0PZUTdzS9k08QDOU2h0C9ushtIG2-5pVgyZwsiGxx7JTy87oZQtU4RLrEKeWOonZR-CSFooC2Ym6KbVEAzh64-hndgEr", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/f97f465d-27db-3345-88b9-281db46deeec", "mri_monitor_states": []}], "account_users": [{"id": 34744, "account_id": 32858, "is_active": true, "web_theme": "light", "account": {"id": 32858, "name": "MAR Acct", "street_address_1": "3275 26th Ave East Lot 7", "street_address_2": "", "city": "Bradenton", "state_province": "FL", "zip": "34208", "country_code": "US", "show_tenths": true, "measurement_system_id": 1, "timezone": "America/New_York", "map_center_point": {"lat": 0.0, "lng": 0.0}, "map_zoom_level": 8, "map_view": "current_temp", "map_views": ["current_temp", "todays_rain", "current_wind"], "measurement_system_units": {"LightningClosestStrikeDist": "MI", "IndoorTemperature": "F", "IndoorHumidity": "%", "LightningLastStrikeDist": "MI", "Water Leak": "V", "Temperature": "F", "Humidity": "%", "WaterFlowRate": "gal", "WaterTemp": "F", "Barometric Pressure": "inHg", "Wind Speed": "mph", "Rainfall": "in", "Rainrate": "in", "Feels Like": "F", "Dew Point": "F", "Heat Index": "F", "Wind Chill": "F", "Soil Temp": "F", "Remote Temp": "F", "Remote Humid": "%", "WindSpeedAvg": "mph"}, "time_format": "12_hour", "date_format": "mm/dd", "header_images": [], "background_images": []}}]}}
2022-06-16 20:18:00,696 Thread-67 udi_interface INFO AcuriteManager:getHubDevices: Got Acurite Devices
2022-06-16 20:18:00,698 Thread-67 udi_interface DEBUG AcuriteController:discover: Device Id: 943425
2022-06-16 20:18:00,698 Thread-67 udi_interface DEBUG AcuriteController:discover: Device Name: Lightning Tower
2022-06-16 20:18:00,700 Thread-67 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 943425, "name": "Lightning Tower", "model_code": "LightningT", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 1, "last_check_in_at": "2022-06-17T00:16:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-17.json"], "temp_high_value": "97.6", "temp_high_at": "12:36 PM", "temp_low_value": "75.6", "temp_low_at": "5:56 AM", "daily_cumulative_strikes": 109, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2019-10-02T21:32:52.220Z", "sensors": [{"id": 4356815, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "83.9", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 4356814, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "103", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 4356813, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 4356812, "sensor_code": "Heat Index", "sensor_name": "Heat Index", "last_reading_value": "105", "channel": 4, "chart_unit": "F"}, {"id": 4356811, "sensor_code": "Interference", "sensor_name": "Interference", "last_reading_value": "1", "channel": 5, "chart_unit": null}, {"id": 4356807, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.04", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [{"id": 4356810, "sensor_code": "LightningStrikeCnt", "sensor_name": "Lightning Strike Count", "last_reading_value": "36", "channel": 6, "chart_unit": null}, {"id": 4356809, "sensor_code": "LightningClosestStrikeDist", "sensor_name": "Lightning Closest Strike Distance", "last_reading_value": "3", "channel": 7, "chart_unit": "MI"}, {"id": 4356808, "sensor_code": "LightningLastStrikeDist", "sensor_name": "Lightning Last Strike Distance", "last_reading_value": "3", "channel": 8, "chart_unit": "MI"}], "model": {"id": 6077, "code": "LightningT", "description": "Lightning Tower", "has_wifi": false}}
2022-06-16 20:18:00,700 Thread-67 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:18:00,701 Thread-67 udi_interface INFO AcuriteController:discover: Node 943425 already exists, skipping
2022-06-16 20:18:00,702 Thread-67 udi_interface DEBUG AcuriteLightningTNode:update: AcuriteLightningTNode - update
2022-06-16 20:18:00,702 Thread-67 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV1's value
2022-06-16 20:18:00,703 Thread-67 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV2's value
2022-06-16 20:18:01,443 Thread-67 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLITEMP's value
2022-06-16 20:18:01,444 Thread-67 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Temp: 83.9 F
2022-06-16 20:18:02,004 Thread-67 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLIHUM's value
2022-06-16 20:18:02,004 Thread-67 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Humidity: 103 %RH
2022-06-16 20:18:02,458 Thread-67 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in DEWPT's value
2022-06-16 20:18:02,459 Thread-67 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Dew Point: 58 F
2022-06-16 20:18:02,916 Thread-67 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in BARPRES's value
2022-06-16 20:18:02,916 Thread-67 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Barometric Pressure: 30.04 inHg
2022-06-16 20:18:03,678 Thread-67 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV4's value
2022-06-16 20:18:03,679 Thread-67 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Heat Index: 105 F
2022-06-16 20:18:04,153 Thread-67 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV5's value
2022-06-16 20:18:04,154 Thread-67 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Strike Count: 36 None
2022-06-16 20:18:04,790 Thread-67 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV6's value
2022-06-16 20:18:04,791 Thread-67 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Last Strike Distance: 3 MI
2022-06-16 20:18:05,362 Thread-67 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV8's value
2022-06-16 20:18:05,363 Thread-67 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Closest Strike Distance: 3 MI
2022-06-16 20:18:05,364 Thread-67 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV3 to 1 to Polyglot
2022-06-16 20:18:05,364 Thread-67 udi_interface.node DEBUG node:reportDriver: Updating value to 1
2022-06-16 20:18:05,365 Thread-67 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV3', 'value': '1', 'uom': '45'}]}
2022-06-16 20:18:05,367 Thread-67 udi_interface DEBUG AcuriteController:discover: Device Id: 313855
2022-06-16 20:18:05,368 Thread-67 udi_interface DEBUG AcuriteController:discover: Device Name: AC Temps
2022-06-16 20:18:05,369 Thread-67 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 313855, "name": "AC Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 3, "last_check_in_at": "2022-06-17T00:16:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "78.6", "temp_high_at": "6:41 PM", "temp_low_value": "53.0", "temp_low_at": "3:41 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2017-01-11T17:01:42.630Z", "sensors": [{"id": 1211149, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "63.1", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 1211150, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "71", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 1211151, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "54", "channel": 3, "chart_unit": "F"}, {"id": 1211148, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.04", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:18:05,370 Thread-67 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:18:05,370 Thread-67 udi_interface INFO AcuriteController:discover: Node 313855 already exists, skipping
2022-06-16 20:18:05,371 Thread-67 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV1's value
2022-06-16 20:18:05,372 Thread-67 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV2's value
2022-06-16 20:18:05,519 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV3 to 1 UOM 45
2022-06-16 20:18:05,859 Thread-67 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLITEMP's value
2022-06-16 20:18:05,860 Thread-67 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Temp: 63.1 F
2022-06-16 20:18:06,316 Thread-67 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLIHUM's value
2022-06-16 20:18:06,317 Thread-67 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Humidity: 71 %RH
2022-06-16 20:18:06,806 Thread-67 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in DEWPT's value
2022-06-16 20:18:06,807 Thread-67 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Dew Point: 54 F
2022-06-16 20:18:07,259 Thread-67 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in BARPRES's value
2022-06-16 20:18:07,259 Thread-67 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Barometric Pressure: 30.04 inHg
2022-06-16 20:18:07,260 Thread-67 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set GV3 to 1 to Polyglot
2022-06-16 20:18:07,260 Thread-67 udi_interface.node DEBUG node:reportDriver: Updating value to 1
2022-06-16 20:18:07,261 Thread-67 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'GV3', 'value': '1', 'uom': '45'}]}
2022-06-16 20:18:07,263 Thread-67 udi_interface DEBUG AcuriteController:discover: Device Id: 1065633
2022-06-16 20:18:07,264 Thread-67 udi_interface DEBUG AcuriteController:discover: Device Name: Bedroom Temps
2022-06-16 20:18:07,265 Thread-67 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 1065633, "name": "Bedroom Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 4, "last_check_in_at": "2022-06-17T00:16:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "79.7", "temp_high_at": "12:46 PM", "temp_low_value": "77.5", "temp_low_at": "1:36 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2020-09-06T21:46:43.678Z", "sensors": [{"id": 5041656, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "78.6", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 5041657, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "49", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 5041658, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 5041655, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.04", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:18:07,265 Thread-67 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:18:07,266 Thread-67 udi_interface INFO AcuriteController:discover: Node 1065633 already exists, skipping
2022-06-16 20:18:07,266 Thread-67 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV1's value
2022-06-16 20:18:07,267 Thread-67 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV2's value
2022-06-16 20:18:07,402 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: GV3 to 1 UOM 45
2022-06-16 20:18:07,743 Thread-67 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLITEMP's value
2022-06-16 20:18:07,744 Thread-67 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Temp: 78.6 F
2022-06-16 20:18:08,192 Thread-67 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLIHUM's value
2022-06-16 20:18:08,192 Thread-67 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Humidity: 49 %RH
2022-06-16 20:18:08,637 Thread-67 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in DEWPT's value
2022-06-16 20:18:08,637 Thread-67 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Dew Point: 58 F
2022-06-16 20:18:09,129 Thread-67 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in BARPRES's value
2022-06-16 20:18:09,130 Thread-67 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Barometric Pressure: 30.04 inHg
2022-06-16 20:18:09,131 Thread-67 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set GV3 to 1 to Polyglot
2022-06-16 20:18:09,132 Thread-67 udi_interface.node DEBUG node:reportDriver: Updating value to 1
2022-06-16 20:18:09,132 Thread-67 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'GV3', 'value': '1', 'uom': '45'}]}
2022-06-16 20:18:09,134 Thread-67 udi_interface INFO AcuriteController:query: AcuriteController - query
2022-06-16 20:18:09,254 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: GV3 to 1 UOM 45
2022-06-16 20:18:58,244 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2022-06-16 20:18:58,246 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2022-06-16 20:18:58,247 Thread-68 udi_interface INFO AcuriteController:poll: shortPoll (controller)
2022-06-16 20:18:58,249 Thread-68 udi_interface INFO AcuriteController:discover: Starting Acurite Device Discovery
2022-06-16 20:18:58,249 Thread-68 udi_interface INFO AcuriteController:discover: acurite_user: tlightne@aim.com
2022-06-16 20:18:59,022 Thread-68 udi_interface INFO AcuriteManager:login: Login HTTP Status Code: 200
2022-06-16 20:18:59,024 Thread-68 udi_interface DEBUG AcuriteManager:login: {"token_id": "505dd514-7fb1-47db-8883-df4be042d29f", "user": {"id": 34604, "email": "tlightne@aim.com", "first_name": "Terry", "last_name": "Lightner", "full_name": "Terry Lightner", "language": "en/us", "session_timeout": 7776000, "failed_login_count": 15, "is_locked": false, "default_user_contact_id": 38708, "password_set_token": null, "permissions": ["Account User-32858", "Account User-32858-Clock", "Account User-32858-Sensor", "Account User-32858-Bell Controller", "Account Admin-32858", "Account Admin-32858-Clock", "Account Admin-32858-Sensor", "Account Admin-32858-Bell Controller", "Account Manager-32858", "Account Manager-32858-Clock", "Account Manager-32858-Sensor", "Account Manager-32858-Bell Controller", "Network Admin-32858", "Network Admin-32858-Clock", "Network Admin-32858-Sensor", "Network Admin-32858-Bell Controller"], "user_contacts": [{"id": 38708, "user_id": 34604, "contact_type": "email", "value": "tlightne@aim.com", "name": "Default email", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 52558, "user_id": 34604, "contact_type": "android", "value": "fXomgUZZOZc:APA91bGp5qAhdyu9QgEneDASam1286SxRRp-VO6yv7rZLrS2ykL6KGI8Uj5XnGcee8-iWYvjqpg5LYbH_6Tzj9K9IAkF3xiIb6eQvY87sB_f1Bwj_KftKcGLVQ3iyUto1ZoOsEJx8cQP", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/51452137-2b9e-3daf-86e9-131a661185bc", "mri_monitor_states": []}, {"id": 60620, "user_id": 34604, "contact_type": "phone", "value": "9417180409", "name": "AC Temps", "aws_sns_endpoint_arn": null, "mri_monitor_states": []}, {"id": 509896, "user_id": 34604, "contact_type": "android", "value": "fXANtCdsSu6DSZhlP5_SNk:APA91bGYor1EZCr-H4NbxXXGGvJxLLDRyC8FrKHBkf2hdSuu0PZUTdzS9k08QDOU2h0C9ushtIG2-5pVgyZwsiGxx7JTy87oZQtU4RLrEKeWOonZR-CSFooC2Ym6KbVEAzh64-hndgEr", "name": "user: 34604 android push", "aws_sns_endpoint_arn": "arn:aws:sns:us-east-1:934393190351:endpoint/GCM/myacurite_production/f97f465d-27db-3345-88b9-281db46deeec", "mri_monitor_states": []}], "account_users": [{"id": 34744, "account_id": 32858, "is_active": true, "web_theme": "light", "account": {"id": 32858, "name": "MAR Acct", "street_address_1": "3275 26th Ave East Lot 7", "street_address_2": "", "city": "Bradenton", "state_province": "FL", "zip": "34208", "country_code": "US", "show_tenths": true, "measurement_system_id": 1, "timezone": "America/New_York", "map_center_point": {"lat": 0.0, "lng": 0.0}, "map_zoom_level": 8, "map_view": "current_temp", "map_views": ["current_temp", "todays_rain", "current_wind"], "measurement_system_units": {"LightningClosestStrikeDist": "MI", "IndoorTemperature": "F", "IndoorHumidity": "%", "LightningLastStrikeDist": "MI", "Water Leak": "V", "Temperature": "F", "Humidity": "%", "WaterFlowRate": "gal", "WaterTemp": "F", "Barometric Pressure": "inHg", "Wind Speed": "mph", "Rainfall": "in", "Rainrate": "in", "Feels Like": "F", "Dew Point": "F", "Heat Index": "F", "Wind Chill": "F", "Soil Temp": "F", "Remote Temp": "F", "Remote Humid": "%", "WindSpeedAvg": "mph"}, "time_format": "12_hour", "date_format": "mm/dd", "header_images": [], "background_images": []}}]}}
2022-06-16 20:19:00,452 Thread-68 udi_interface INFO AcuriteManager:getHubDevices: Got Acurite Devices
2022-06-16 20:19:00,454 Thread-68 udi_interface DEBUG AcuriteController:discover: Device Id: 943425
2022-06-16 20:19:00,454 Thread-68 udi_interface DEBUG AcuriteController:discover: Device Name: Lightning Tower
2022-06-16 20:19:00,456 Thread-68 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 943425, "name": "Lightning Tower", "model_code": "LightningT", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 1, "last_check_in_at": "2022-06-17T00:16:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00000136-LightningT/1h-summaries/2022-06-17.json"], "temp_high_value": "97.6", "temp_high_at": "12:36 PM", "temp_low_value": "75.6", "temp_low_at": "5:56 AM", "daily_cumulative_strikes": 109, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2019-10-02T21:32:52.220Z", "sensors": [{"id": 4356815, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "83.9", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 4356814, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "103", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 4356813, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 4356812, "sensor_code": "Heat Index", "sensor_name": "Heat Index", "last_reading_value": "105", "channel": 4, "chart_unit": "F"}, {"id": 4356811, "sensor_code": "Interference", "sensor_name": "Interference", "last_reading_value": "1", "channel": 5, "chart_unit": null}, {"id": 4356807, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.04", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [{"id": 4356810, "sensor_code": "LightningStrikeCnt", "sensor_name": "Lightning Strike Count", "last_reading_value": "36", "channel": 6, "chart_unit": null}, {"id": 4356809, "sensor_code": "LightningClosestStrikeDist", "sensor_name": "Lightning Closest Strike Distance", "last_reading_value": "3", "channel": 7, "chart_unit": "MI"}, {"id": 4356808, "sensor_code": "LightningLastStrikeDist", "sensor_name": "Lightning Last Strike Distance", "last_reading_value": "3", "channel": 8, "chart_unit": "MI"}], "model": {"id": 6077, "code": "LightningT", "description": "Lightning Tower", "has_wifi": false}}
2022-06-16 20:19:00,457 Thread-68 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:19:00,457 Thread-68 udi_interface INFO AcuriteController:discover: Node 943425 already exists, skipping
2022-06-16 20:19:00,458 Thread-68 udi_interface DEBUG AcuriteLightningTNode:update: AcuriteLightningTNode - update
2022-06-16 20:19:00,459 Thread-68 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV1's value
2022-06-16 20:19:00,459 Thread-68 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV2's value
2022-06-16 20:19:01,204 Thread-68 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLITEMP's value
2022-06-16 20:19:01,205 Thread-68 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Temp: 83.9 F
2022-06-16 20:19:01,765 Thread-68 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in CLIHUM's value
2022-06-16 20:19:01,766 Thread-68 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Humidity: 103 %RH
2022-06-16 20:19:02,216 Thread-68 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in DEWPT's value
2022-06-16 20:19:02,217 Thread-68 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Dew Point: 58 F
2022-06-16 20:19:02,669 Thread-68 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in BARPRES's value
2022-06-16 20:19:02,670 Thread-68 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Barometric Pressure: 30.04 inHg
2022-06-16 20:19:03,431 Thread-68 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV4's value
2022-06-16 20:19:03,431 Thread-68 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Heat Index: 105 F
2022-06-16 20:19:03,875 Thread-68 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV5's value
2022-06-16 20:19:03,876 Thread-68 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Strike Count: 36 None
2022-06-16 20:19:04,322 Thread-68 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV6's value
2022-06-16 20:19:04,322 Thread-68 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Last Strike Distance: 3 MI
2022-06-16 20:19:04,822 Thread-68 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower No change in GV8's value
2022-06-16 20:19:04,823 Thread-68 udi_interface DEBUG AcuriteLightningTNode:update: Device Name: Lightning Tower, Sensor Lightning Closest Strike Distance: 3 MI
2022-06-16 20:19:04,824 Thread-68 udi_interface.node DEBUG node:setDriver: 943425:Lightning Tower Reporting set GV3 to 2 to Polyglot
2022-06-16 20:19:04,824 Thread-68 udi_interface.node DEBUG node:reportDriver: Updating value to 2
2022-06-16 20:19:04,825 Thread-68 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 943425, 'driver': 'GV3', 'value': '2', 'uom': '45'}]}
2022-06-16 20:19:04,827 Thread-68 udi_interface DEBUG AcuriteController:discover: Device Id: 313855
2022-06-16 20:19:04,828 Thread-68 udi_interface DEBUG AcuriteController:discover: Device Name: AC Temps
2022-06-16 20:19:04,829 Thread-68 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 313855, "name": "AC Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 3, "last_check_in_at": "2022-06-17T00:16:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00010486-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "78.6", "temp_high_at": "6:41 PM", "temp_low_value": "53.0", "temp_low_at": "3:41 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2017-01-11T17:01:42.630Z", "sensors": [{"id": 1211149, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "63.1", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 1211150, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "71", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 1211151, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "54", "channel": 3, "chart_unit": "F"}, {"id": 1211148, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.04", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:19:04,830 Thread-68 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:19:04,830 Thread-68 udi_interface INFO AcuriteController:discover: Node 313855 already exists, skipping
2022-06-16 20:19:04,831 Thread-68 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV1's value
2022-06-16 20:19:04,831 Thread-68 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in GV2's value
2022-06-16 20:19:04,965 MQTT udi_interface.interface INFO interface:_message: Successfully set 943425 :: GV3 to 2 UOM 45
2022-06-16 20:19:05,316 Thread-68 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLITEMP's value
2022-06-16 20:19:05,317 Thread-68 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Temp: 63.1 F
2022-06-16 20:19:05,769 Thread-68 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in CLIHUM's value
2022-06-16 20:19:05,770 Thread-68 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Humidity: 71 %RH
2022-06-16 20:19:06,248 Thread-68 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in DEWPT's value
2022-06-16 20:19:06,249 Thread-68 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Dew Point: 54 F
2022-06-16 20:19:06,701 Thread-68 udi_interface.node DEBUG node:setDriver: 313855:AC Temps No change in BARPRES's value
2022-06-16 20:19:06,701 Thread-68 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: AC Temps, Sensor Barometric Pressure: 30.04 inHg
2022-06-16 20:19:06,702 Thread-68 udi_interface.node DEBUG node:setDriver: 313855:AC Temps Reporting set GV3 to 2 to Polyglot
2022-06-16 20:19:06,703 Thread-68 udi_interface.node DEBUG node:reportDriver: Updating value to 2
2022-06-16 20:19:06,703 Thread-68 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 313855, 'driver': 'GV3', 'value': '2', 'uom': '45'}]}
2022-06-16 20:19:06,705 Thread-68 udi_interface DEBUG AcuriteController:discover: Device Id: 1065633
2022-06-16 20:19:06,706 Thread-68 udi_interface DEBUG AcuriteController:discover: Device Name: Bedroom Temps
2022-06-16 20:19:06,707 Thread-68 udi_interface DEBUG AcuriteController:discover: Device JSON: {"id": 1065633, "name": "Bedroom Temps", "model_code": "2in1T", "placement_code": "IN", "status_code": "green", "battery_level": "Normal", "signal_strength": 4, "last_check_in_at": "2022-06-17T00:16:56.000+00:00", "timezone": "America/New_York", "meta_file": "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/meta.json", "summary_files": ["https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-16.json", "https://dataapi.myacurite.com/mar-sensor-readings/24C86E0A5062-00006008-2in1T/1h-summaries/2022-06-17.json"], "temp_high_value": "79.7", "temp_high_at": "12:46 PM", "temp_low_value": "77.5", "temp_low_at": "1:36 AM", "daily_cumulative_strikes": null, "daily_cumulative_measured_light": null, "current_comfort_index": null, "created_at": "2020-09-06T21:46:43.678Z", "sensors": [{"id": 5041656, "sensor_code": "Temperature", "sensor_name": "Temperature", "last_reading_value": "78.6", "channel": 1, "chart_unit": "F", "show_tenths": true}, {"id": 5041657, "sensor_code": "Humidity", "sensor_name": "Humidity", "last_reading_value": "49", "channel": 2, "chart_unit": "%RH", "display_unit": "%"}, {"id": 5041658, "sensor_code": "Dew Point", "sensor_name": "Dew Point", "last_reading_value": "58", "channel": 3, "chart_unit": "F"}, {"id": 5041655, "sensor_code": "Barometric Pressure", "sensor_name": "Pressure", "last_reading_value": "30.04", "channel": 9, "chart_unit": "inHg"}], "wired_sensors": [], "model": {"id": 4023, "code": "2in1T", "description": "Temp & Humidity Sensor", "has_wifi": false}}
2022-06-16 20:19:06,708 Thread-68 udi_interface DEBUG AcuriteController:discover: Controller Address: controller
2022-06-16 20:19:06,708 Thread-68 udi_interface INFO AcuriteController:discover: Node 1065633 already exists, skipping
2022-06-16 20:19:06,709 Thread-68 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV1's value
2022-06-16 20:19:06,710 Thread-68 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in GV2's value
2022-06-16 20:19:06,850 MQTT udi_interface.interface INFO interface:_message: Successfully set 313855 :: GV3 to 2 UOM 45
2022-06-16 20:19:07,193 Thread-68 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLITEMP's value
2022-06-16 20:19:07,194 Thread-68 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Temp: 78.6 F
2022-06-16 20:19:07,638 Thread-68 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in CLIHUM's value
2022-06-16 20:19:07,639 Thread-68 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Humidity: 49 %RH
2022-06-16 20:19:08,086 Thread-68 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in DEWPT's value
2022-06-16 20:19:08,087 Thread-68 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Dew Point: 58 F
2022-06-16 20:19:08,531 Thread-68 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps No change in BARPRES's value
2022-06-16 20:19:08,531 Thread-68 udi_interface DEBUG AcuriteDeviceNode:update: Device Name: Bedroom Temps, Sensor Barometric Pressure: 30.04 inHg
2022-06-16 20:19:08,532 Thread-68 udi_interface.node DEBUG node:setDriver: 1065633:Bedroom Temps Reporting set GV3 to 2 to Polyglot
2022-06-16 20:19:08,533 Thread-68 udi_interface.node DEBUG node:reportDriver: Updating value to 2
2022-06-16 20:19:08,533 Thread-68 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 1065633, 'driver': 'GV3', 'value': '2', 'uom': '45'}]}
2022-06-16 20:19:08,535 Thread-68 udi_interface INFO AcuriteController:query: AcuriteController - query
2022-06-16 20:19:08,646 MQTT udi_interface.interface INFO interface:_message: Successfully set 1065633 :: GV3 to 2 UOM 45
Scroll to Top
Edited by tlightne
@tlightne  Do me a favor and send a screen shot of the dashboard.  Are you using the web based on the mobile app?
James
@JPaul
First the Atlas node is a selectable item along with all the data points in the programs tab, so that is resolved.
Screen shots of my admin console and the mobile dashboard.
Everything matches the dashboard except the lightning data.
This is the 1-day chart for the lightning strike data. The Acurite Access reports the strikes every 5 minutes and then reset to 0 then reports the next 5-minute count of strikes. The highest peak in the graph is only 5 strikes. The total strike is cumulative over the 24-hour period and resets completely at midnight. I assume you have the node server setting both of the strike distances to 0 when a strike count of 0 is returned by the API. There were a couple of 0 returned at the begin of the storm that would have reported incorrectly.
Hope this helps,
Robert
@rob7419  Thanks for the help.  I think what is going on it that for lightning data the app is calling the report API.  I'm going to just mimic what the app does when I get a little time.  I'll ping you all when it's ready.
