How would I do this?
I have a 2450 - Smarthome IOLinc - 1 Input - 1 Output plugged into my garage, with a sensor attached to the door. I want the door to close if it's left open for more the 15 minutes. How do I do this?
Status 'garage sensor' is on
Wait 15 minutes
set 'garage' on
  • 6 months later...
    Wait 15 minutes
    set 'garage' on
Did you get this setup working?
I would think you used the output node to connect to the door trigger and that what you discribed worked good.
