Polisy and a USB hub
Hi Everyone,
I'm new here picked up a polisy and a insteon USB dongle and with a little help from Mike. Wala back in business with insteon and the far superior isy on polisy. So I want to start getting into some z-wave stuff saw a battery powered thermostat which doesn't require a c-wire which solve a big issue for me. So here are some questions:
Has anyone used a USB hub with the polisy? (Clearance Issue)
Has anyone Used a wifi adaptor instead of a hardline for the network connection?
This is what some of us are using. It frees up the second usb port and moves the Zwave dongle to a better location:
 USB 3.0 Adapter 90 Degree Male to Female Combo Vertical Up and Down Angle Coupler Connector by Oxsubor : Electronics (amazon.com)
Not sure the Polisy would support a wi-fi adapter but the pro version has built-in wi-fi.
You could also use the Polisy's network resources to talk to wi-fi enabled devices.
