No forecast info
I am attempting to use this NS and I think everything is set up right but I am not getting any data from the forecast nodes. Forecast Nodes 1-6 show nothing (just default values in AC). Forecast 0 downloaded data and appeared right (I am assuming forecast 0 is supposed to be todays forecast)  yesterday but has not updated today. it still shows info and the day of week from yesterday.
I am including the error log from the NS. There is an error that shows up, but i don't know what to do with it.
AERISWeather_5-11-2022_52257_AM.zip
It's not getting valid data.
How often are you polling for data?  It looks like about 90 seconds from the log.  I believe you can only make a limited number of queries per day and if you have it set to 90 seconds, it may only be able to get data for a few hours before you've used up the day's allocation.
When I was testing it, I used shortPoll = 240 and longPoll=1200 to try and keep under the limit.
@bpwwer ? I have run out of access to the server. I updated the configuration to the numbers you posted and i guess i will check back tomorrow.
  • 1 month later...
I just got my server up and running (thanks to Bob) and for what its worth it appears Aeris increased the amount of accesses you get for the "PWS Contributors Package" subscription. It used to be 1000 (i'm pretty sure) now its 5000. Because of this i changed my shortpoll to 90 and longpoll to 1000.
