Turn Logging Off
Is it possible to turn down the logging?  It is filling up my Polisy log and event viewer on level 1 with kWs every time it changes which is about every second.
From the polyglot dashboard you can select the node server details and then the "Log" button.  From there you can change the logging level.  I believe it is set to Info by default.  Changing to  Error or Warning should reduce the amount of logging significantly.
That changes the logging in PG3 but not in the Polisy log or the event viewer.  I just changed the short poll frequency to  every 30 secs which helps but would be nice to only have an entry in the ISY if the value changed by X amount or be able to just turn it off completely.
Thank You!
