BR40 Z-Wave Plus Light Bulb
I've been searching high and low and can't come up with a BR40 Z-WAVE Plus lamp for installation in a Halo H7-410P Downlight.  What's out there for a downlight can in Z-Wave Plus sized BR40?  What are you using in a Halo H7 for Z-Wave?  I could always replace the switch but I don't have a neutral available and didn't have any luck in another installation with a Inovelli Dimmer and the Aeotech Bypass.  I've got an Insteon bulb that has been working for years but I'm trying to move to Z-Wave.  Found a couple R30s out there but none say Z-Wave plus and the R30 won't fill the trim either.  Does anyone know of a Z-Wave Plus BR40 lamp they could recommend?
I have one switch box in my home where it is practically impossible to get a neutral wire. I tried many solutions including Inovelli but I have fallen out of love with Inovelli. Their no neutral switches gave me problems.
A few months ago I installed the "No Neutral"  Enbrighten 52252 Z-Wave Plus Smart Light Dimmer   and it has worked perfectly since.
As you may know Zwave devices really only work well when you have a good mesh network, meaning a minimum number of (non-battery) devices that cover your home. To be safe I usually include my Zwave devices close to my ISY (I built a switchbox with a plug)  and then move the switch to its intended location.
From time to time I get an error message in the Administrative Console that there is no communication with this switch, but to the best of my memory it has never failed to work.
Edited by asbril
P.S.   I don't know if this is necessary, or even useful, but I created a program whereby the no neutral switch is always ON :
IF
Switch A status is  <= 2 %
THEN
Switch A 3%
So, when the switch is OFF, it still has power. With its Led bulbs, thr consumption must be minimum.
