Polisy Pro and Homeseer
Do I need a plugin to get homeseer to communicate with my new Policy Pro or will the plugin I had with my isy work?
The existing ISYInsteon plug-in on HomeSeer should work fine with an ISY on Polisy.   From an external communication perspective, they are supposed to be the same.
Note however that I have not tested that combination.
  • 4 months later...
Did you get this working? Did you have to change the port on the configuration page of the homeseer plugin?
  • 1 month later...
I suspect the issue here is probably the port.  I am running into a lot of this a lot.  Lots of these systems will not take the hard coded 8080 port for IoP.  They only like port 80.
