Sun Not Reporting Values in PG3
I'm everything over to PG3 and all is going reasonably well. However, when installing the Sun node, I am getting no values as to sun position. It shows as connected, but everything else is zero. It was working great on PG2. Any ideas? There is nothing on GitHub.
Solved by Dean
Well, nevermind! There were 2 parameters in PG2. Longitude and Latitude were the only ones required. In PG3, there is also a key for Elevation. I deleted Elevation and its value, restarted the node and Voila, everything works! I use it to close the blinds in my office with the Somfy Z-Wave controller, as the sun beats through the windows heating up the room.
