Program that runs 24/7
I am looking to create an "if" statement that runs 24/7.  I have many programs that count things at various intervals 24/7.  Currently I am doing a "if" time between 00:01 AM and 23:59 PM.  This works fine but seems seems a bit over the top.  Just trying to clean things up a bit.
Example:
Set Temperature Variable - [ID 0069][Parent 0001]
        From    12:00:00AM
        To      11:59:00PM (same day)
        Repeat Every  10 minutes
           $sFIB.Temp  = 'Guest Bedroom / ZW 002 Multilevel Sensor 1' Temperature °C
           $sFIB.Temp *= 1.8
           $sFIB.Temp += 32
Set "Run at Startup" attribute for that program on the Programs > Summary tab, and leave the IF blank.
You might want to vary, or not always use Repeat every 10 minutes, so that you don't have them all running at the same moment.     or throw in a wait X seconds between the "then" and "repeat" to stagger them by a second, a couple at the same moment won't cause a problem but if there were a lot it could, well at least with a 994.
4 minutes ago, CPrince said:
@MrBill; yes, so obvious I did not think about it!  I rarely use that "Run at Startup". Thanks!
I actually only use it one program, but that program runs a program a couple of minutes after startup that starts all the heartbeats and monitor programs.  Long story short I was battling startup errors at some point and had to find a way to make some things start later.
