Unable to get NEW NR's working - TCP CLIENT DNS error
Hi folks,
Fimware / UI 5.3.0
It's been a while since I added a NR. I have a total of 56 of them working fine the last one added maybe six months or so ago.
When trying to create a new HTTPS POST NR, I either copy an existing NR or create a new one from scratch, I get a TCP client DNS error with a strange error code: [sfvad vadv]
All previously added NR's continue to work flawlessly. I cannot see any issue with the ISY DNS, I've configured both the router IP and Google DNS, same issue. I don't understand why if I copy a working NR, save, then test it fails. Could anyone shed some light?
I've restored config to a test ISY unit, same problem. No apparent issues with the SD card.
edit: added info
Edited by mango
Update: Tried DHCP, same issue. Router is DECO X60, no DNSMasq.
Update 2:
I have 'resolved' the issue by completely deleting and re-adding manually each NR. I can now add new functional NRs. I can only assume there was some corruption somewhere that carried over a backup/restore. Not sure but onwards and upwards...
