installed and already blowing rate limit
Thanks for doing this Node server.
I have 7 Wave Plus devices. Does 1 API call return all info about all devices, or does it take one call per reading or per device?
All I've done is set things up and one device has no data and the log reports "WARNING Controller:api_get: API Rate limit exceeded, waiting until 2022-07-09 16:45:23.514700 query the Airthings service."
I set short poll to 120 secs, for what that's worth.
Maybe this is just because of the rush of calls due to set up but for future reference how calls will it "cost" to update my 7 devices?
Also, I'm not seeing the VOC level, just a "Clean" report. Can the level be provided instead, or is that all Airthings returns?
Ignore the question, There is a value field for VOC. I was distracted by the assessment field that's actually labeled "VOC Level"
Instead, can you explain what the time value is - and if there's a way to convert it to something meaningful?
