What will this realy do:
will it repeat this sequence 4 times? 4 times 5min = 20 min
thanks..
From Sunrise + 20 minutes
For 20 minutes
Repeat Every 5 minutes
Set 'Front Door Light' Off
Set 'Back Ext Trim Lights' Off
This will turn OFF all outside security lights
Yes, it will repeat the sequence 4 times, but it is based on time only, Specifically:
- the 'Then' is run at Sunrise + 20 minutes
- 20 minutes later, then 'Then' is stopped abruptly, and the 'Else' is run
If you want to guarantee it runs and completes 4 times every 5 minutes, you can do this:
       Time is Sunset  + 20 minutes
       Repeat 4 times
          Wait  5 minutes
