Potentially a challenge for superusers: Problem running "Network Resources"
For all the "Network Resource" gurus..  This is potentially a tough one..  Yes - I searched for the answer here first, and finally gave up.  Literally spent hours on this.
I have 45 Network Resources currently, all work fine.  All of them fire off HTTP Gets to a local system (same LAN) (a Philips Hue hub).
However, when I try to create a new Network Resource to a public website (IFTTT, zapier, UptimeRobot, et.al), all FAIL.
This is extremely frustrating.  I have tried every possible HTTP protocol type (Get/Post/Put etc) that websites will accept for webhooks, and the "Test" runs FAIL for every config.  I also tried checking/unchecking all the checkboxes in the config window, tried Gets/Puts/Posts as HTTP and HTTPS (with the proper port numbers plugged in), to no avail.  Same or similar error messages as shown in my photos here.
NOW - please know that ALL of these webhooks work just fine if I cut and paste them into a simple web browser URL bar.  The servers all give a "successful" response, which is why I'm hating my ISY at the moment.
Side question for the firmware developers:  After using this for over 10 years, why doesn't the ISY Network Resource creation window have a "simple browser URL input" option, that will emulate whatever the heck a standard modern web browser (Chromium etc?) GET is doing, and just send it!  People are given webhooks as a whole/single string and not all this protocol/encoding detail to send to their servers, yet this dialog box doesn't have a field to accept the URL as a simple full length URL with all defaults assumed!  I really hate how I can't simply paste the entire webhook in as a single URL.  Once I start breaking the URL apart into domain, protocol, http/https, path etc types, this increases the chance of errors, and something is failing.  I feel like I have to know HTTPS protocol inside and out, plus all the possible HTTP headers to send, just to send a dang webhook!  even one without any JSON variables!  thanks for letting me vent.
Yes I took the time to go download and re-read the "Home Automation Cookbook?, and followed it step by step to build an IFTTT webhook, and it failed.  I noticed this cookbook didn't tell me the "Encode URL" checkbox state, which was frustrating.
And as you'll see, this failure error message is really worthless guys.  When I download a "Log" file and open it in Excel, it has nothing about this failure in it!  frustrating again.
Heck I even updated from 4.6.6 to 5.3.4 today to see if this would fix it, OR if the error messages would be more helpful.  No joy.
I assume "Internet Access:  Disabled" is because I use Mobilinc, correct?
Anyone seen this before?  Appreciate any help!
This is an example of just one of the webhooks that fails with the error message attached.  A simple one-way et webhook to uptimerobot.  This works FINE when dropped into a browser URL bar:
This is the canned error I'm getting to all external Network Resource tests:
Edited by majmarker
Here's a new error response to an HTTP request to IFTTT:
and yes - I can rub the Mobilinc app on my phone (on cellular) and control the unit just fine from anywhere...  hmmm..
Ok - so if I simply check the "SNI" checkbox, these work.  WTH?!@?!@?>@
why not have that checked by default?!?!  or pls give it a better name!  Literally lost hours today on this..
I'll leave this thread here in case anyone else needs it..
Thank you.  I am just starting to work with NR some and was keeping an eye on this thread.
Looks like you had some rubber duck debugging on this one!😀
