UnifiPresence not working after Polisy update.
After a recent update UnifiPresence does not work.  I get the below errors.  I had the error on PG2 and then tried it on PG3 and have the same problem.  Any suggestion?
2022-08-10 07:26:45,127 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2022-08-10 07:26:48,480 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.46 Starting... 2022-08-10 07:26:48,485 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2022-08-10 07:26:48,486 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:53:d7:3c_7/./unifi_poly.py", line 15, in <module> 2022-08-10 07:26:48,487 MainThread udi_interface ERROR udi_interface:write: from pushover import init, Client 2022-08-10 07:26:48,488 MainThread udi_interface ERROR udi_interface:write: ModuleNotFoundError 2022-08-10 07:26:48,489 MainThread udi_interface ERROR udi_interface:write: : 2022-08-10 07:26:48,490 MainThread udi_interface ERROR udi_interface:write: No module named 'pushover'
@bpwwer, might you have any suggestions?
Maybe?
pip install pushover-python
Edited by Whitehambone
Added code
