error won't let the Roomba Node server start
unconfirmed
I'm receiving the following error, which won't let the Roomba Node server start.
2022-08-13 22:23:13,700 MainThread polyinterface      INFO     polylogger:set_basic_config: set_basic_config: enable=True level=30
2022-08-13 22:23:14,134 MainThread polyinterface      INFO     polyinterface:init_interface: Received Config from STDIN.
2022-08-13 22:23:14,135 MainThread polyinterface      INFO     __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting...
2022-08-13 22:23:14,226 MainThread polyinterface      ERROR    polyinterface:write: Traceback (most recent call last):
2022-08-13 22:23:14,227 MainThread polyinterface      ERROR    polyinterface:write: File "./roomba-poly.py", line 11, in <module>
2022-08-13 22:23:14,228 MainThread polyinterface      ERROR    polyinterface:write: from roomba import Roomba
2022-08-13 22:23:14,228 MainThread polyinterface      ERROR    polyinterface:write: File "/home/pi/.local/lib/python3.7/site-packages/roomba/__init__.py", line 2, in <module>
2022-08-13 22:23:14,229 MainThread polyinterface      ERROR    polyinterface:write: from .roomba import Roomba
2022-08-13 22:23:14,230 MainThread polyinterface      ERROR    polyinterface:write: File "/home/pi/.local/lib/python3.7/site-packages/roomba/roomba.py", line 43, in <module>
2022-08-13 22:23:14,231 MainThread polyinterface      ERROR    polyinterface:write: from password import Password
2022-08-13 22:23:14,231 MainThread polyinterface      ERROR    polyinterface:write: ModuleNotFoundError
2022-08-13 22:23:14,232 MainThread polyinterface      ERROR    polyinterface:write: :
2022-08-13 22:23:14,232 MainThread polyinterface      ERROR    polyinterface:write: No module named 'password'
I've tried copying the password.py file from the repo into several places, and added the ./local/bin to my path, all to no avail.
Environment is Raspberry Pi 3;
Version 2.2.11 Status: Connected
Frontend Version: 2.2.9-5
ISY Version: 5.3.0
Any help would be greatly appreciated.
Cheers,
Unconfirmed.
Link to comment
Share on other sites
That's odd since the node server itself doesn't use the 'password' module, it comes from the underlying Roomba python project.  As a first step, I'd recommend uninstalling the node server and also the Roomba module.  Then re-install the node server from the store and let it install the prerequisites automatically.
pip uninstall roomba
pip3 uninstall roomba
Also, this node server is pretty old now, there could be some modules or commands no longer supported by the current version of python.  I think it has been ported over to Polyglot 3 if you switch over to the Polisy.
Link to comment
      36.5k
      367.6k
