My ISY has lost the time....
After the last power outage, I noticed things were not working right. Programs weren't running when being executed from the homeseer plugin.
I just now noticed that the time has been lost. On the java console while logged in, the time shows as 1/25/1942!!!!
Is there a battery backup? If there is, it ran out pretty darned quick.
I tried searching for this issue but whenever I type in time, it just says no topics found.
Anyone know how to reset the time?
In the Administration Console
Configuration tab.
Time can be set there.
What version of firmware is in the ISY99i?
There is an issue with I believe 2.7.6 and below if the automatic time sync is being used with the NTP Servers. Sometimes the time server gives bad data and the date changes the date to the year 1941. There are a few threads on this happening. Mine changed I believe six times to a date in 1941. I turned off the auto sync for now.
In the search area. Search for 1941. It will find 11 other threads.
Maybe your 1942 is related to this also.
I believe there was a post here that the ISY99i has a super cap in it that should keep the time for around six hours with no power. How long was your power out?
