Plex node server configuration issue?
@CH491 @ralbrighthaving probably a configuration problem getting this node server to work. All messages in PG3 seem successful, node server shows up in the Polisy, yet none of the media options shown from the article are available. On the main status display, I see Plex Webhook Listener with the 4 fields; Node server online, listening port, client count, and rapid trigger. In the program section, the only options available are the same 4. I’ve added the Plex webhook address as specified, what else should I try?
