newest version & ELK
What is the latest ISY firmware version that works with the ELK M1 and what is required to set it up. I could use a detailed step by step instruction. Is there a section of the maunual I can look at? :?:?
This is a pretty good reference: www.elkproducts.com/pdf/ELK-Insteon-ISY99i.pdf
There might have been some issues with some of the recent alpha versions of the firmware but I just followed the instructions using 2.7.11alpha without any problems. I believe all versions of the firmware between 2.7.0 and 2.7.6 should work fine too.
