Push Node server will not start
Solved by bpwwer
The node server is already running.  If you try to start a second copy, it fails because only one node server can be running in a slot.
Since node servers are independent processes on the OS, under rare conditions they will continue to run when PG3 attempts to stop them.  When that happens, PG3 gets confuses because it doesn't know the node server is still running and lets you try and start it again, which then fails.
Possibly, restarting PG3 will clear.  If not, then the only way is to either manually kill it via the console or restart Polisy
