How to add Mini Remote to ISY without knowing device address
I have a Mini Remote (part number2342-2) whose device address label has been destroyed. Is there a way to add this device to the ISY without knowing the device address?
Solved by kzboray
I don't have access to a mini-remote atm, but if you manually link it to a device that has been added to AC, you should then be able to see the min-remote address in AC. After linking them manually, I would recommend you factory reset both devices and instead re- link them in AC.
Manual Linking:
1) Tap Mini Remote scene button of choice
2) Press and hold Mini Remote set button until it beeps
Mini Remote LED will start blinking green
3) Turn responder on (or any other state such as on 50% or even off)
4) Press and hold responder set button until it double-beeps
Mini Remote will double-beep and its LED will stop blinking
5) Test by tapping Mini Remote scene button just programmed
Responder load will respond appropriately
Edited by kzboray
I followed your directions and have manually linked the Mini Remote to a device that has been added to AC but am not finding the Mini Remote in AC. Can you tell me where to look in AC to find it? Thanks.
Please disregard the question above, I was able to find the the Mini Remote in the devices links table. Thanks for your help.
