Everything Sensor (with mmw)
kurelgyer
I'll pass on installing anything mmW inside my home.  The only exception is if it can be connected to an autonomous paintball sentry to track intruders.  Makes police lineup identification much easier.
There are some good PTZ cameras that can take a paintball gun duct taped (Canadian style, eh?) to the top.
You can then write some scripts to control pan and zoom. You may even find some tracking software and I would be sure ISY could find a way to pull the trigger with a modified door latch release, home automation style.
You may want to consider some dual channel operator mechanism for lower risk intrusions. Do a search for good squirtguns filled with old urine.
The sentence below may have other meanings.
'The maker is currently aiming to make it work with effortlessly Home Assistant.  It appears to be very open.'
Link to comment
Like???  He's posted everything on Github and says you can install your own software on it.  Open.
Link to comment
