PG 3.1.11 -> 3.1.15 Failed Upgrade?
Hi All,
I tried to update PG3 this morning from 3.1.11 to 3.1.15. I followed the directions:
- Admin Console, Configuration, Upgrade Packages. Heard 5 beeps (not 4?)
- Restarted PG3 from System -> Restart Polyglot 3 (heard a few more beeps.)
After logging back into the ISY Console, I noted:
- ISY Launcher has changed its name to IoX Launcher; not a big deal I guess.
- The UUID of my ISY is showing as 00:00:00:00:00:01:
539458487_Screenshot2022-11-27at10_27_04AM.thumb.png.144070c8e3552fe0bd5f8c3598b70cc2.png
- Still can access ISY though, however the console is stuck in a “System Busy” loop. After it reaches 100, it repeats:
1513638557_Screenshot2022-11-27at10_19_57AM.thumb.png.5c59e98698303f64e179656602426960.png
- None of my Node Servers are showing up in the left under “Network” (I only have three - Hue, Elk and Camect)
In the PG3 log, it shows this in a loop :
537602511_Screenshot2022-11-27at10_31_55AM.thumb.png.7974ba827b5820d1436702910dce0468.png
The blanked out UUID are my correct UUID.
Any thoughts on how to fix this? Thank you!
Jordan
Solved by bpwwer
There was a support ticket with the same issue (uuid = 00:00:00:00:00:01). In that case a reboot of the Polisy resolved the issue.
I suggest you try that first.  If that doesn't resolve the issue, then file a support ticket as something may be preventing the Polisy from fully initializing on startup.
