Error in Log file: incorrect header check
I've been using the Climacell node server with my Polisy for several months and it is working well.  But I don't have any explanation for this recurring error in the log files.  This error is logged every hour at the exact same time. At first I thought that was just a one off header check error, but it happens precisely once per hour and I use shorPoll 120 (2 minutes) and longPoll 600 (10 minutes).  The normal shortPoll and longPoll calls seem to succeed without errors. So I don't know what's being called once per hour.  My system firmware version and parameters are:
Polisy 5.4.5
PG3: 3.1.15
Cilimacell Node Server: 2.0.1
Climacell configuration parameters:  shortPoll  120,  longPoll 600
Anything I can do to resolve this?  Or maybe there is discrepancy between the Node Server and Tomorrow.io?
2022-12-04 09:42:54,058 Thread-704 udi_interface      ERROR    query:query_conditions: Current observation update failure
2022-12-04 09:42:54,059 Thread-704 udi_interface      ERROR    query:query_conditions: ('Received response with content-encoding: gzip, but failed to decode it.', error('Error -3 while decompressing data: incorrect header check'))
2022-12-04 09:44:54,045 Thread-705 udi_interface      ERROR    query:query_conditions: Current observation update failure
2022-12-04 09:44:54,046 Thread-705 udi_interface      ERROR    query:query_conditions: ('Received response with content-encoding: gzip, but failed to decode it.', error('Error -3 while decompressing data: incorrect header check'))
2022-12-04 09:46:54,065 Thread-706 udi_interface      ERROR    query:query_conditions: Current observation update failure
2022-12-04 09:46:54,066 Thread-706 udi_interface      ERROR    query:query_conditions: ('Received response with content-encoding: gzip, but failed to decode it.', error('Error -3 while decompressing data: incorrect header check'))
2022-12-04 09:48:48,810 Thread-707 udi_interface      ERROR    query:query_forecast: Forecast data failure: ('Received response with content-encoding: gzip, but failed to decode it.', error('Error -3 while decompressing data: incorrect header check'))
2022-12-04 09:48:54,063 Thread-708 udi_interface      ERROR    query:query_conditions: Current observation update failure
2022-12-04 09:48:54,065 Thread-708 udi_interface      ERROR    query:query_conditions: ('Received response with content-encoding: gzip, but failed to decode it.', error('Error -3 while decompressing data: incorrect header check'))
2022-12-04 09:50:54,852 Thread-709 udi_interface      ERROR    query:query_conditions: Current observation update failure
2022-12-04 09:50:54,853 Thread-709 udi_interface      ERROR    query:query_conditions: ('Received response with content-encoding: gzip, but failed to decode it.', error('Error -3 while decompressing data: incorrect header check'))
2022-12-04 09:52:54,146 Thread-710 udi_interface      ERROR    query:query_conditions: Current observation update failure
2022-12-04 09:52:54,147 Thread-710 udi_interface      ERROR    query:query_conditions: ('Received response with content-encoding: gzip, but failed to decode it.', error('Error -3 while decompressing data: incorrect header check'))
2022-12-04 09:54:54,124 Thread-711 udi_interface      ERROR    query:query_conditions: Current observation update failure
2022-12-04 09:54:54,125 Thread-711 udi_interface      ERROR    query:query_conditions: ('Received response with content-encoding: gzip, but failed to decode it.', error('Error -3 while decompressing data: incorrect header check'))
2022-12-04 09:56:54,127 Thread-712 udi_interface      ERROR    query:query_conditions: Current observation update failure
2022-12-04 09:56:54,128 Thread-712 udi_interface      ERROR    query:query_conditions: ('Received response with content-encoding: gzip, but failed to decode it.', error('Error -3 while decompressing data: incorrect header check'))
2022-12-04 09:58:48,882 Thread-713 udi_interface      ERROR    query:query_forecast: Forecast data failure: ('Received response with content-encoding: gzip, but failed to decode it.', error('Error -3 while decompressing data: incorrect header check'))
2022-12-04 09:58:54,828 Thread-714 udi_interface      ERROR    query:query_conditions: Current observation update failure
2022-12-04 09:58:54,829 Thread-714 udi_interface      ERROR    query:query_conditions: ('Received response with content-encoding: gzip, but failed to decode it.', error('Error -3 while decompressing data: incorrect header check'))
Solved by rwsani99
I think I've found the problem:  my configuration setting of shortPoll 120 and longPoll 600 was exceeding my hourly and daily allowance of updates with my default (free) Tomorrow.io account.  The allowance with a free Tomorrow.io account is 500/day, 25/hr, 3/sec.  Now that I've changed to shortPoll 300 and longPoll 3600, I'm seeing no more errors.  And updates of current weather ever 5 minutes and forecasts every hour are more than sufficient for my needs.
