Adding Hue to Harmony Hub
I'm trying to configure the HueEmulator. I've installed the node server, set the configuration information in the NS settings and I can see the NS in the ISY admin console. Note, I have also tried the actual IP address instead of "localhost" in the NS settings with no change in outcome.
When I try and add the Hue Hub to the Harmony Hub, it asks me to press the center button on the Hue Hub. I have tried to set "Listen" from False to True to simulate the center button push but it won't recognize. Any troubleshooting suggestions?
Edited by endobiker
Solved by Jimbo.Automates
Are there any errors in the node server log?
Jimbo,
I am seeing an error in the NS log (below):
 hueUpnp  ERROR  hueUpnp:run: hueUpnp: Responder Socket Error: [Errno 48] Address already in use
Something else must be using port 8081?  What other node servers or programs do you have running on your Polisy?
You can change it to something else, like 8082 and restart the node server.
It worked- thanks!
