Work With Govee?
Will the MagicHome node server work with Govee lights? The node server will not discover the Govee lights. I manually entered the information and the lights were added to the nodes list. However, they will not connect. The nodes show up in the Admin Console as not connected. The log shows "socket connect failed". The Govee node server is working fine. I wanted to compare MagicHome to Govee if possible.
Thank you!
My Magic home lights got into a state last night where they were controllable from the Magic home app but I was getting failed connection from the node server.  It seemed to be something wrong with the lights themselves as I had to power cycle the lights to get them to work from both the cloud and locally.
You might want to see if the Govee lights work with the MagicHome app and if so, if they can work both with the cloud and locally.  If they can be configured to work locally, then they should work with the node server.
I have the lights configured to work locally. They work with Lumina Stream. However, I am unable to get them to work with the MagicHome app or MagicHome NS.
