IoX Release v5.5.2 - OUTDATED
* IoX = ISY on Anything.
Welcome to ZMatter Z-Wave+ Beta !
In this build we focused primarily on migration either from a Z-Wave network using our original implementation on Polisy/Eisy, or from an ISY-994 backup (containing a 500 Series Z-Wave backup).
    Getting Started
    • Make a backup of Polisy (Admin Console | File | Backup IoX )
    • Launch the Admin Console, go to the Configuration tab, click on Update Packages. Warning, this might take a while depending on how current your OS is
    • Once completed (4 beeps + 1), unplug Polisy
    • If you are using INSTEON, make sure the PLM is connected
    • Power up your Polisy note that initial boot might take a much longer time than normal because udx might want to install missing packages to assist with migration (in the future)
    • Once boot up is complete, Launch Admin Console
    Migrating to ZMatter Z-Wave+
    • Go to the configuration tab and press the Migrate to ZMatter Z-Wave button to start migration
    • Please pay close attention to the instructions
    • Do not unplug or install any Z-Wave boards / dongles until instructed to do so during migration
    • When IoX restarts for the first time during migration, you will see that your old Z-Wave nodes are not enabled.  As the device interviews proceed, they will become enabled as they are updated with data from the new Z-Wave implementation.
    • The best way to monitor the progress is to open the Admin Console Event Viewer to level 3
    • For those who want lots of low-level details, you can also use this from the command line: tail -f /var/isy/FILES/LOG/ZWAY.LOG
    • Note: The only way to go back to the original Z-Wave implementation is to restore a backup that was made prior to moving to ZMatter Z-Wave+
         Here are the installation instructions for those of you with a ZMatter Z-Wave board (not USB dongle):
    Features
    • Migration from existing network (e.g. Zooz)
    • Migration from ISY-994 500 Series Backup
    Bug Fixes
    • Set/Query Configuration parameters
    • Some sensor values not available (e.g. humidity for multisensor 6)
    • Change default of "Detect Button Press" to OFF
    • Hail not working for some devices (not able to fully test this because we do not have a device with this problem)
    Next
    • Bug fixes, including better support for detecting events from button presses, motion sensors etc.
