Does pg3 connect to the Nest thermostats anymore?`
When the first version of the Polyglot came out, I was able to connect my Nest thermostats to my ISY. Is there another way to connect them to the Eisy that others are using? Thanks
Nest changed its API and the Node Server no longer works with ISY.
I use Home Assistant as a complement to my ISY and HA has a working Nest integration.
8 hours ago, pyrorobert said:
Okay thank you. What a bummer!
Consider getting Home Assistant, it is an excellent complement to ISY. I mostly use HA as a front for  ISY on my computers, but it has Integrations (HA term for node servers) that ISY does not.
Homeseer now has a working Nest plugin.  I've installed it and it handles my 8 Nest thermostats flawlessly.
