Heartbeat missing from devices
normally, when I link a new device to the ISY99, let's say an IO sensor. I receive 3 devices, example: door opened, door closed, and door heartbeat. However; as of recent, when adding a new device my heartbeat is no longer appearing. Why would this be the case? What could be causing a missing heartbeat?
Insteon_UD994 .1.19)v.4.9.0 (2020 12-22-11)
Open/Close Sensor Model 2843-222
Thx,
Wes
@wes
Here's a sample of two programs I use to monitor heartbeat. The first program should be "enabled at startup". After you create it, manually run the IF clause to initially start the timer.
If the heartbeat is detected, then the first program will restart the timer. If it's not detected, then the second program will run.
Program 1
IF
   Sensor heartbeat is not switched on
    or
    Sensor heartbeat is not switched off
THEN
      wait 28 hours
      run program sensor heartbeat Fail (then path)
ELSE
     (blank)
Program 2
IF
(blank)
THEN
   send notification to your email
ELSE
(blank)
Edited by Techman
Not sure how to write pgm to monitor or start it it does not show in devices. Thoughts?
To clarify, I see the device but no heartbeat entry
image.png.c945ff300de9b6876a6841a6f9508680.pngimage.png.c945ff300de9b6876a6841a6f9508680.png
Kitchen Door has IO sensor
No Heartbeat
Make sure that your admin console is the same version as your ISY firmware.
 Try doing a factory reset on the device then a restore device.
If that doesn't add the heartbeat node than I would uninstall it, factory reset it, and then re-install it
If then you're still unable to see the heartbeat node, then you might want to update your ISY firmware to the latest version which has numerous bug fixes and improvements.
Understood, One last question....How to perform factory reset on I/O sensor
Wes
I'll post back results
To factory reset an IOLinc:
1. Unplug it for 10 seconds
2. While holding down the set button plug it in and continue to keep the set button pressed in for 5 seconds
3. The IOLinc LED will blink once, then the IOLinc will beep as the LED turns back on
Edited by Techman
Latest steps:
  1. I Removed the device, Performed factory reset on device, re-linked the device. Status: Failed. Heartbeat still missing.
  2. I Upgraded ISY99 firmware, then again removed the device, performed factory reset on device, and re-linked the device. Status: Failed. Heartbeat still missing.
Upgraded firmware details:
Any other ideas? This doesn't appear to be local to any particular device. though I will say that motion sensors do show the heartbeat/low Battery like the other devices used too.
Do you have another open/close sensor installed that shows a heartbeat node, or do you have one that isn't installed that you could test?
Either the sensor is defective, or depending on your device firmware version, maybe they eliminated the heartbeat node, which is unlikely
What's the 4-digit date code and hardware version of your device. it should be printed on a sticker inside.
@wes
One other thought,
Search your entire device tree, it's possible the heartbeat node got renamed and is displaying somewhere else in the tree
RE: upgrading from 4.9.0 to 5.3.4 make sure to read the release notes as some user intervention may be required for scenes and programs
have 5 installed with no heartbeat
will post 4-digit date code and hardware version of your device.  later'
You may also want to note the firmware version of the modules. Reported in the Administrative Console. As date code and hardware version. Doesn't always indicate a firmware version. As some modules like the 2413S PLM have the same firmware in more than one revision. I have see 9E in more than one and I maybe the same one still being used.
In that case I would send an email to support@insteon.com and ask them if they eliminated the heartbeat node. Be sure to give them the 4 digit date code and hardware version printed on the sticker in the device. My devices all have the heartbeat node showing in the device tree.
Yea, Insteon support is all but kaput.
date code:  3815 REV 1.B
My sensors are the same firmware and hardware versions. so, it's most likely not anything to do with your sensor.
Did you try deleting the sensor from the ISY, rebooting the isy then adding it back as a new device.
yes to no avail.
I did send email to insteon support and received response.... If you dont have a green light on hub, subscribe for support.
They have killed support on a bad business model.  Time to goto homeassistant and isy and change over one hundred devices.
Wes
Any other thoughts. Cannot be this hard.......
Are you sure you did a factory reset on the devices before you installed them
      1. Remove the battery for 15 seconds
      2. Press and hold the set button while installing the battery
     3. Release the set button when the status led turns on
just FYI.. its been a long time since any of my door sensors and even my motion sensors have shown a reported heartbeat in ISY...i didnt use it so no biggie for me, but i did notice it missing several versions ago on my 994pro. Nothing on the polisy either.
Reset perfect... I need to monitor batteries for a reason.
Signed irreatated.........
Dont get me wrong, you guys are great and the first to help...... Just received a rasberry pie and installed Home assist, They do have a Insteon intergration. I'll play tomorrow.   THe HA does intergrate with isy too.
WIsh me luck
