Scene WILL NOT delete ISY994 Insteon
ISSUE RESOLVED - thank you!
I have the following device with an issue:
ISY 9941/IR PRO (1110)
  • OpenADR (21010)
  • Z-Wave (21100)
  • Portal Integration - UDI (21075)
There is a scene that simply WILL NOT delete. I am upgrading to the Eisy and want to have a fully functioning install from back-up of the ISY with no "glitches" or issues. note: there is no mention of this "bad scene" (or mentioned devices below) upon launch of the ISY interface.
Scene name is "Auto DR", you can see in there is NOTHING in the scene... (PIC1)
when I try to delete the scene (PIC2), I get the results (PIC3):
Failed writing device link
(35.73.EA - A-B)
[-200000/-511
(35.73.EA - A-B)
[-200000/-511
This device mentioned (35.73.EA is a functioning mini remote 2342-2) which has no reference to being in a scene. It controls two devices in the system (A-B & C-D only)(PIC4/PIC5). Those devices are functioning in a timer program in the system. Those devices are NOT in any other scenes in the system.
Ive attempted to "Restore" the device (mini remote) and now get the following results when trying to remove the Scene "Auto DR":
"Request Failed" (PIC6), nothing else, no attempt by ISY to even try to remove it, no mention of the mini remote.
Any help on how to fix this and permanently delete this scene from my system is most appreciated. Thank you in advance.
Edited by 3jtexas
Resolved
Solved by kzboray
@3jtexas Auto DR should not be removed, nor do I believe it can be.
AutoDR is Automatic Demand Response. Where supported, it allows the utility (power company) to send a message that the ISY would react to by turning off heavy loads during peak times. There is likely more to it but that is my understanding. The AutoDR scene I believe is where you would place the "Heavy Loads" that should be turned off on request.
I agree with @kzboray , AutoDR is the only scene that's "factory installed" and can't be removed.
You can however rename it, I renamed mine "~Auto DR" which drops it to the bottom of the list where it's just ignored.
Thanks for the helpful information- problem resolved!
