PG3 Version 3.1.16 and ISY Zmatter continues to show ISY as not connected
I have just moved from an ISY994 to ISY on Poliglot on Polisy it did show connected for a short time when at first1321427875_IsyDisconnected.thumb.JPG.67818741184657166d328333ff25d09a.JPG. Everything seems to be working fine except ISY continues to show not connects (see screen cap). Any idea what thee problem might be
Double check that the ISY configuration is correct.   To connect to the ISY running on the Polisy you should have the IP address set to 127.0.0.1:8080 and re-enter the username and password.
The PG3 log should show why it is unable to connect to the ISY instance but it most likely either a wrong IP/port or wrong password.
Thanks I will check both.
@bpwwer Thanks for the info I traced the problem to the node server Total Connect that did not load correctly as soon as I removed it it the ISY connected fine.
That's strange. A node server shouldn't be able to effect that connection.
Can you try installing it again?
If it does the same thing, capture the node server and PG3 log and post or pm it to me.
