Node Server Stops and Doesn't Restart - ITS BACK
This morning my infloor heating was off, so I checked my ST-NuHeat NS and sure enough its says it has stopped again.  My NuHeat account is fine, I can control my thermostat from my phone app or the NuHeat portal.  A few strange things (probably more things I don't understand) when looking at the logs:
The PG3 Log shows every 5 mins a 'configuration update required', see below.  a1 is the ISY and 10 is the POLISY. It then shows a corresponding install of my node servers into the ISY.  I run an ISY994i and a POLISY that is just running the Node servers, nothing strange about my setup.
1/27/2023, 05:27:45 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/27/2023, 05:27:46 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/27/2023, 05:27:46 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/27/2023, 05:27:46 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/27/2023, 05:27:46 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/27/2023, 05:27:46 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/27/2023, 05:32:45 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/27/2023, 05:32:46 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/27/2023, 05:32:46 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/27/2023, 05:32:46 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/27/2023, 05:32:46 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/27/2023, 05:32:46 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/27/2023, 05:37:46 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/27/2023, 05:37:46 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/27/2023, 05:37:46 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/27/2023, 05:37:47 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/27/2023, 05:37:47 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/27/2023, 05:37:47 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/27/2023, 05:42:45 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/27/2023, 05:42:46 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/27/2023, 05:42:46 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/27/2023, 05:42:46 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/27/2023, 05:42:46 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/27/2023, 05:42:46 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/27/2023, 05:44:58 [pg3] info: [00:21:b9:02:50:a1(4)] ISY HTTP Inbound: Received CLISPH for node: 1547108
1/27/2023, 05:45:01 [pg3] info: [00:21:b9:02:50:a1(4)] ISY HTTP Inbound: Received query n004_1547108
1/27/2023, 05:45:01 [pg3] info: [00:21:b9:02:50:a1(4)] ISY HTTP Inbound request ID: 2900
1/27/2023, 05:47:46 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/27/2023, 05:47:46 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/27/2023, 05:47:46 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/27/2023, 05:47:46 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/27/2023, 05:47:46 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/27/2023, 05:47:46 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/27/2023, 05:52:46 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/27/2023, 05:52:46 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/27/2023, 05:52:46 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/27/2023, 05:52:46 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/27/2023, 05:52:46 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/27/2023, 05:52:46 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/27/2023, 05:57:46 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/27/2023, 05:57:46 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/27/2023, 05:57:46 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/27/2023, 05:57:46 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/27/2023, 05:57:46 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/27/2023, 05:57:46 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
The ST-NuHeat Log shows limited information but that it is shutting itself down, see below
2023-01-27 03:00:20 debug: POLY:       -> topic is udi/pg3/ns/clients/00:21:b9:02:50:a1_4, processing
2023-01-27 03:00:20 debug: POLY: Log file set to: logs/debug-2023-01-27.log
2023-01-27 03:00:20 debug: NS: Message Received: { query: { address: 'controller' } }
2023-01-27 03:00:20 warn: POLY: Message query ignored: Shutting down Node Server
2023-01-27 03:00:21 debug: POLY:       -> topic is udi/pg3/ns/clients/00:21:b9:02:50:a1_4, processing
2023-01-27 03:00:21 debug: NS: Message Received: { query: { address: '1547108' } }
2023-01-27 03:00:21 warn: POLY: Message query ignored: Shutting down Node Server
2023-01-27 05:44:58 debug: POLY:       -> topic is udi/pg3/ns/clients/00:21:b9:02:50:a1_4, processing
2023-01-27 05:44:58 debug: NS: Message Received: {
  command: {
    address: '1547108',
    cmd: 'CLISPH',
    value: '78',
    uom: '17',
    query: {}
2023-01-27 05:44:58 warn: POLY: Message command ignored: Shutting down Node Server
2023-01-27 05:45:01 debug: POLY:       -> topic is udi/pg3/ns/clients/00:21:b9:02:50:a1_4, processing
2023-01-27 05:45:01 debug: NS: Message Received: { query: { address: '1547108' } }
2023-01-27 05:45:01 warn: POLY: Message query ignored: Shutting down Node Server
I rebooted the POLISY and the NuHeat Node Server restarted and stayed running on Tuesday per my other forum post and I thought it had been fixed, but today (3 days later) the Noder server has stopped itself again? I again rebooted POLISY and the NuHeat Node Server is running again but not sure for how long?  Next time the NuHeat Node Server stops are there other things I can do besides a POLISY reboot to get it fixed properly or get information for other people smarter than myself to figure out what is going on?
@bpwwer @simplextech
Solved by bpwwer
The 5 minute configuration update is either this PG3 instance fighting for control over those slots with something else or it isn't actually successful at updating the configuration.
Every 5 minutes it queries the ISY/IoP for the node server configuration and verifies it against what it has in it's database.  in this case, it's saying the user name value in the node server configuration is wrong, so it updates it to the correct username.  The username field is set to the PG3 UUID/slot#.    When I have 2 different versions of PG3 running, I've seen them do this, one changes, the other changes it back.   That doesn't seem likely, but the way to check is to look at the configuration right after PG3 updates it.  You may have to restart the admin console to get it to show the correct values.  Look under Node Servers -> Configuration -> slot#.
For NuHeat, it looks like a bug in the node server.  It should only be shutting down if PG3 tells it to shutdown.  Shutting down for any other reason is a bug.  I'll take a look at it at some point.  I just don't know when yet.
Here is what I see when looking in the ISY under Node Servers -> Configuration -> slot#:
I don't see anything change when the PG3 log indicates an "ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10" and the says its installing the node servers again into the ISY
00:21:b9:02:50:a1  = ISY 994i
00:0d:b9:52:c8:10 = POLISY (PG3)
192.168.0.26 = IP of POLISY
I have no idea what to do here?
Edited by jwagner010
Ahh, the node servers are running on PG3 but installed on the i994, correct?   The verification check assumes that the node servers are supposed to be installed on the IoP running on the Polisy.  It's a bug in PG3.
@bpwwer Yes IOP is running on ISY994i (00:21:b9:02:50:a1) and PG3 I assume installs them into the ISY 994i
Yes the Node Servers / PG3 is running on the POLISY (00:0d:b9:52:c8:10 / 192.168.0.10)
If a bug in PG3 do I just need to wait to the next update is pushed out and then do 'update' via the Update Button on the POLISY Admin Console?
On a separate note will this also fix the ST-NuHeat Node Server stopping or do we still need to find the root cause of that?
@bpwwer  @simplextech  ST-NuHeat Node server stopped again this morning, ran for less than 24 hours before it stopped.  Again attaching an extract of the St-NuHeat Log as well as the PG3 log.  When do you think there will be a fix to both PG3 ( @bpwweryou confirmed a bug with PG3) and when will there be a fix to the node server as that was also mentioned as having a bug?
PG3 Log extract from time it looks like problem starts at around 1/28 @ 3:44am:
1/28/2023, 03:44:52 [pg3] error: uncaughtException: read ECONNRESET
Error: read ECONNRESET
    at TCP.onStreamRead (node:internal/stream_base_commons:217:20)
1/28/2023, 03:44:52 [pg3] error: uncaught ECONNRESET exception:  Error: read ECONNRESET
1/28/2023, 03:44:52 [pg3] info: Caught SIGTERM/SIGINT Shutting down.
1/28/2023, 03:44:52 [pg3] info: Stopping running node servers...
1/28/2023, 03:44:52 [pg3] info: [ST-Sonos(1)]: Stopping Node Server
1/28/2023, 03:44:52 [pg3] info: [DysonPureCool(2)]: Stopping Node Server
1/28/2023, 03:44:52 [pg3] info: [DysonPureCool(3)]: Stopping Node Server
1/28/2023, 03:44:52 [pg3] info: [ST-Nuheat(4)]: Stopping Node Server
1/28/2023, 03:44:52 [pg3] info: [OpenWeatherMap(9)]: Stopping Node Server
1/28/2023, 03:44:52 [pg3] error: MQTTS: clientError: 00:21:b9:02:50:a1_9 invalid publish
1/28/2023, 03:44:52 [pg3] info: MQTTS: Client Disconnected: 00:21:b9:02:50:a1_9
1/28/2023, 03:44:52 [pg3] error: MQTTS: clientError: 00:21:b9:02:50:a1_2 invalid publish
1/28/2023, 03:44:52 [pg3] error: MQTTS: clientError: 00:21:b9:02:50:a1_3 invalid publish
1/28/2023, 03:44:52 [pg3] info: MQTTS: Client Disconnected: 00:21:b9:02:50:a1_2
1/28/2023, 03:44:52 [pg3] info: MQTTS: Client Disconnected: 00:21:b9:02:50:a1_3
1/28/2023, 03:44:55 [pg3] info: PG3 shutdown complete with code: 1
1/28/2023, 03:45:13 [pg3] info: Starting PG3 version 3.1.16
1/28/2023, 03:45:13 [pg3] info: Using Workdir /var/polyglot/pg3/
1/28/2023, 03:45:14 [pg3] info: Installing latest udi_interface module
1/28/2023, 03:45:20 [pg3] info: NSChild: PythonInterface /usr/local/bin/pip3 install udi_interface --user: exited with cause code: 0
1/28/2023, 03:45:20 [pg3] info: Starting sqlite database at /var/polyglot/pg3/pg3.db
1/28/2023, 03:45:20 [pg3] info: Encryption key found ID: 19851007-b8a3-4d0d-b08f-12e1eca264af. Database version 1
1/28/2023, 03:45:20 [pg3] info: Query IoX for platform  UUID.
1/28/2023, 03:45:20 [pg3] info: Loaded globalsettings successfully. Database version 1
1/28/2023, 03:45:20 [pg3] info: isy table: Loaded (1) successfully
1/28/2023, 03:45:20 [pg3] info: ISY: 00:21:b9:02:50:a1 5.3.4 192.168.0.10 e8547107-4069-41da-a048-28792d4dc460
1/28/2023, 03:45:20 [pg3] info: Node Server table: Loaded 6 Node Server(s) successfully
1/28/2023, 03:45:20 [pg3] info: store is up-to-date
1/28/2023, 03:45:20 [pg3] info: Updated configuration with overrides
1/28/2023, 03:45:20 [pg3] info: Starting update check
1/28/2023, 03:45:20 [pg3] info: Starting MQTT Server Aedes
1/28/2023, 03:45:20 [pg3] info: Aedes MQTT Broker Service: Started on port 1888
1/28/2023, 03:45:20 [pg3] info: Started MQTT Client Service
1/28/2023, 03:45:21 [pg3] info: Creating ISY queues for 00:21:b9:02:50:a1
1/28/2023, 03:45:21 [pg3] info: HTTP Queue response "Queue Created Successfully,"
1/28/2023, 03:45:21 [pg3] info: Starting event listeners
1/28/2023, 03:45:21 [pg3] info: Starting Store Poll Refresh timer
1/28/2023, 03:45:21 [pg3] info: Starting ISY verification.
1/28/2023, 03:45:21 [pg3] info: Query ISY description at http://192.168.0.10:181/desc
1/28/2023, 03:45:21 [pg3] info: Koa HTTPS Interface Service: Started - Address: 0.0.0.0 Port: 3000
1/28/2023, 03:45:21 [pg3] warn: Default password for user admin still in use! Please change!
1/28/2023, 03:45:21 [pg3] info: Checking ISY's for installed node servers...
1/28/2023, 03:45:21 [pg3] info: MQTTS: Client Connected: 00:21:b9:02:50:a1_4
1/28/2023, 03:45:21 [pg3] info: MQTTS: Client Connected: pg3_client
1/28/2023, 03:45:21 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 03:45:21 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 03:45:21 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 03:45:21 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 03:45:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 03:45:22 [pg3] info: *****************************************
1/28/2023, 03:45:22 [pg3] info: Latest PG3 version available is 3.1.16
1/28/2023, 03:45:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 03:45:22 [pg3] info: Waiting for store (false) and isy (true) before starting node servers.
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Airscape
1/28/2023, 03:45:22 [pg3] info: Checking for changes in HusqvarnaMower
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Timedata
1/28/2023, 03:45:22 [pg3] info: Checking for changes in YoLink
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Sun
1/28/2023, 03:45:22 [pg3] info: Checking for changes in PurpleAir
1/28/2023, 03:45:22 [pg3] info: Checking for changes in UnifiProtect
1/28/2023, 03:45:22 [pg3] info: Checking for changes in WLED
1/28/2023, 03:45:22 [pg3] info: Checking for changes in AERISWeather
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Flair
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Airthings-C
1/28/2023, 03:45:22 [pg3] info: Checking for changes in August
1/28/2023, 03:45:22 [pg3] info: Checking for changes in HarmonyHub
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Roku
1/28/2023, 03:45:22 [pg3] info: Checking for changes in MiLight
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Sensibo
1/28/2023, 03:45:22 [pg3] info: Checking for changes in AVRemote
1/28/2023, 03:45:22 [pg3] info: Checking for changes in WeatherBit
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Virtual
1/28/2023, 03:45:22 [pg3] info: Checking for changes in NanoLeaf
1/28/2023, 03:45:22 [pg3] info: Checking for changes in NOAA
1/28/2023, 03:45:22 [pg3] info: Checking for changes in OnkyoAVR
1/28/2023, 03:45:22 [pg3] info: Checking for changes in LiFX
1/28/2023, 03:45:22 [pg3] info: Checking for changes in VirtualButtons
1/28/2023, 03:45:22 [pg3] info: Checking for changes in ST-Inventory
1/28/2023, 03:45:22 [pg3] info: Checking for changes in ATest
1/28/2023, 03:45:22 [pg3] info: Checking for changes in AMINEM
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Roomba
1/28/2023, 03:45:22 [pg3] info: Checking for changes in WeatherLink
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Russound
1/28/2023, 03:45:22 [pg3] info: Checking for changes in TeslaPW
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Rachio
1/28/2023, 03:45:22 [pg3] info: Checking for changes in ST-Nuheat
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Hue
1/28/2023, 03:45:22 [pg3] info: Checking for changes in UnifiPresence
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Holidays
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Sonos
1/28/2023, 03:45:22 [pg3] info: Checking for changes in iAquaLink
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Climacell
1/28/2023, 03:45:22 [pg3] info: Checking for changes in ST-Sonos
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Notification
1/28/2023, 03:45:22 [pg3] info: Checking for changes in WirelessTag
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Volumio
1/28/2023, 03:45:22 [pg3] info: Checking for changes in WeatherPoly
1/28/2023, 03:45:22 [pg3] info: Checking for changes in EnvisaLink-HW
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Bond
1/28/2023, 03:45:22 [pg3] info: Checking for changes in BalboaSPA
1/28/2023, 03:45:22 [pg3] info: Checking for changes in HolidaysGoogle
1/28/2023, 03:45:22 [pg3] info: Checking for changes in OpenSprinkler
1/28/2023, 03:45:22 [pg3] info: Checking for changes in DavisWeather
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Twinkly
1/28/2023, 03:45:22 [pg3] info: Checking for changes in IFTTT-Webhooks
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Wemo
1/28/2023, 03:45:22 [pg3] info: Checking for changes in WeatherFlow
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Ping
1/28/2023, 03:45:22 [pg3] info: Checking for changes in TeslaEV
1/28/2023, 03:45:22 [pg3] info: Checking for changes in BASIRRIGATION
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Backup
1/28/2023, 03:45:22 [pg3] info: Checking for changes in DysonPureCool
1/28/2023, 03:45:22 [pg3] info: Checking for changes in AVServer
1/28/2023, 03:45:22 [pg3] info: Checking for changes in EnvisaLink-DSC
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Govee
1/28/2023, 03:45:22 [pg3] info: Checking for changes in OpenWeatherMap
1/28/2023, 03:45:22 [pg3] info: Checking for changes in BlueIris
1/28/2023, 03:45:22 [pg3] info: Checking for changes in MagicHome
1/28/2023, 03:45:22 [pg3] info: Checking for changes in RainMachine
1/28/2023, 03:45:22 [pg3] info: Checking for changes in MQTT
1/28/2023, 03:45:22 [pg3] info: Checking for changes in BASPOOL
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Acurite
1/28/2023, 03:45:22 [pg3] info: Checking for changes in MyQ
1/28/2023, 03:45:22 [pg3] info: Checking for changes in VenstarCT
1/28/2023, 03:45:22 [pg3] info: Checking for changes in iTach-IR
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Plex-WebHook
1/28/2023, 03:45:22 [pg3] info: Checking for changes in BASGARAGE
1/28/2023, 03:45:22 [pg3] info: Checking for changes in FlumeWater
1/28/2023, 03:45:22 [pg3] info: Checking for changes in VUE
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Caseta
1/28/2023, 03:45:22 [pg3] info: Checking for changes in ShellyRGBW2
1/28/2023, 03:45:22 [pg3] info: Checking for changes in ST-EcoWitt
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Blink
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Kasa
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Kaiterra
1/28/2023, 03:45:22 [pg3] info: Checking for changes in ELK
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Sense
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Somfy
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Netatmo-WS
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Ecobee
1/28/2023, 03:45:22 [pg3] info: Checking for changes in BASAO
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Wake-On-Lan
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Push
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Camect
1/28/2023, 03:45:22 [pg3] info: Checking for changes in SolarEdge
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Meteobridge
1/28/2023, 03:45:22 [pg3] info: Checking for changes in TotalConnect
1/28/2023, 03:45:22 [pg3] info: Checking for changes in MySmartBlinds
1/28/2023, 03:45:22 [pg3] info: Checking for changes in HueEmulator
1/28/2023, 03:45:22 [pg3] info: Checking for changes in Eagle-200
1/28/2023, 03:45:22 [pg3] info: Checking for changes in AmbientWeather
1/28/2023, 03:45:22 [pg3] info: Checking for changes in HoneywellHome
1/28/2023, 03:45:23 [pg3] info: Checking for changes in DSC-IT100
1/28/2023, 03:45:23 [pg3] info: Checking for changes in Roku
1/28/2023, 03:45:23 [pg3] info: Checking for changes in PythonTemplate
1/28/2023, 03:45:23 [pg3] info: Checking for changes in Example-1
1/28/2023, 03:45:23 [pg3] info: Checking for changes in Tuya-Devices
1/28/2023, 03:45:23 [pg3] info: Checking for changes in ATest
1/28/2023, 03:45:23 [pg3] info: Checking for changes in Roomba
1/28/2023, 03:45:23 [pg3] info: Checking for changes in TestTeslaEV
1/28/2023, 03:45:23 [pg3] info: Checking for changes in Example-2
1/28/2023, 03:45:23 [pg3] info: Checking for changes in Notification
1/28/2023, 03:45:23 [pg3] info: Checking for changes in Example-4
1/28/2023, 03:45:23 [pg3] info: Checking for changes in OpenSprinkler
1/28/2023, 03:45:23 [pg3] info: Checking for changes in Example-3
1/28/2023, 03:45:23 [pg3] info: Checking for changes in eISYIR
1/28/2023, 03:45:23 [pg3] info: Checking for changes in Sensibo-Air
1/28/2023, 03:45:23 [pg3] info: Checking for changes in VueTest
1/28/2023, 03:45:23 [pg3] info: Checking for changes in MagicHome
1/28/2023, 03:45:23 [pg3] info: Checking for changes in iTach-IR
1/28/2023, 03:45:23 [pg3] info: Checking for changes in Kasa
1/28/2023, 03:45:23 [pg3] info: Checking for changes in ELK
1/28/2023, 03:45:23 [pg3] info: Checking for changes in Ecobee
1/28/2023, 03:45:24 [pg3] info: Starting installed and enabled node servers...
1/28/2023, 03:45:24 [pg3] info: startNs:: DysonPureCool
1/28/2023, 03:45:24 [pg3] info: startNs:: DysonPureCool is valid
1/28/2023, 03:45:24 [pg3] info: startNs:: ST-Nuheat
1/28/2023, 03:45:24 [pg3] info: startNs:: ST-Nuheat is valid
1/28/2023, 03:45:24 [pg3] info: startNs:: OpenWeatherMap
1/28/2023, 03:45:24 [pg3] info: startNs:: OpenWeatherMap is valid
1/28/2023, 03:45:24 [pg3] info: startNs:: ST-Sonos
1/28/2023, 03:45:24 [pg3] info: startNs:: ST-Sonos is valid
1/28/2023, 03:45:24 [pg3] info: checkLicense:: DysonPureCool Valid perpetual license found.
1/28/2023, 03:45:24 [pg3] info: startNs:: DysonPureCool finished update check
1/28/2023, 03:45:24 [pg3] info: checkLicense:: ST-Nuheat Valid perpetual license found.
1/28/2023, 03:45:24 [pg3] info: startNs:: ST-Nuheat finished update check
1/28/2023, 03:45:24 [pg3] info: checkLicense:: OpenWeatherMap Valid perpetual license found.
1/28/2023, 03:45:24 [pg3] info: startNs:: OpenWeatherMap finished update check
1/28/2023, 03:45:24 [pg3] info: checkLicense:: ST-Sonos Valid perpetual license found.
1/28/2023, 03:45:24 [pg3] info: startNs:: ST-Sonos finished update check
1/28/2023, 03:45:24 [pg3] info: [DysonPureCool(3)] :: Starting Node Server - Version 4.0.0
1/28/2023, 03:45:24 [pg3] info: startNs:: DysonPureCool updating database (enabled, timestarted)
1/28/2023, 03:45:24 [pg3] info: [DysonPureCool(2)] :: Starting Node Server - Version 4.0.0
1/28/2023, 03:45:25 [pg3] info: [ST-Nuheat(4)] :: Starting Node Server - Version 1.0.2
1/28/2023, 03:45:25 [pg3] info: startNs:: ST-Nuheat updating database (enabled, timestarted)
1/28/2023, 03:45:25 [pg3] info: startNs:: DysonPureCool starting polls
1/28/2023, 03:45:25 [pg3] info: Starting Node Server Info timer 0
1/28/2023, 03:45:25 [pg3] info: [OpenWeatherMap(9)] :: Starting Node Server - Version 3.1.4
1/28/2023, 03:45:26 [pg3] info: startNs:: OpenWeatherMap updating database (enabled, timestarted)
1/28/2023, 03:45:26 [pg3] info: [ST-Sonos(1)] :: Starting Node Server - Version 1.0.6
1/28/2023, 03:45:26 [pg3] info: startNs:: ST-Sonos updating database (enabled, timestarted)
1/28/2023, 03:45:26 [pg3] info: startNs:: ST-Nuheat starting polls
1/28/2023, 03:45:26 [pg3] info: Starting Node Server Info timer 0
1/28/2023, 03:45:27 [pg3] info: startNs:: OpenWeatherMap starting polls
1/28/2023, 03:45:27 [pg3] info: Starting Node Server Info timer 0
1/28/2023, 03:45:27 [pg3] info: startNs:: ST-Sonos starting polls
1/28/2023, 03:45:29 [pg3] info: MQTTS: Client Connected: 00:21:b9:02:50:a1_3
1/28/2023, 03:45:30 [pg3] info: MQTTS: Client Connected: 00:21:b9:02:50:a1_2
1/28/2023, 03:45:30 [pg3] error: MQTTS: ClientID: 00:21:b9:02:50:a1_4 is already connected. Disallowing multiple connections.
1/28/2023, 03:45:30 [pg3] error: MQTTS: clientError: 00:21:b9:02:50:a1_4 Auth Error
1/28/2023, 03:45:30 [pg3] info: [ST-Nuheat(4)] :: Exit cause code: 2 - signal: null
1/28/2023, 03:45:30 [pg3] info: MQTTS: Client Connected: 00:21:b9:02:50:a1_9
1/28/2023, 03:45:30 [pg3] info: [ST-Sonos 1] :: STDOUT: 2023-01-28T08:45:30.778Z INFO Could not find file /var/polyglot/pg3/ns/0021b90250a1_1/node-sonos-http-api/settings.json
1/28/2023, 03:45:31 [pg3] info: MQTTS: Client Connected: 00:21:b9:02:50:a1_1
1/28/2023, 03:45:32 [pg3] info: [00:21:b9:02:50:a1_1] Set notices
1/28/2023, 03:45:32 [pg3] info: [00:21:b9:02:50:a1_1] Set customparamsdoc
1/28/2023, 03:45:34 [pg3] info: [00:21:b9:02:50:a1_3] Set notices
1/28/2023, 03:45:34 [pg3] info: [00:21:b9:02:50:a1_2] Set notices
1/28/2023, 03:45:34 [pg3] info: [00:21:b9:02:50:a1_9] Set notices
1/28/2023, 03:45:34 [pg3] info: upload successful
1/28/2023, 03:45:35 [pg3] info: upload successful
1/28/2023, 03:45:35 [pg3] info: node controller on profile 3 already exists, no nodeDef or driver changes detected
1/28/2023, 03:45:35 [pg3] info: node controller on profile 9 already exists, no nodeDef or driver changes detected
1/28/2023, 03:45:35 [pg3] info: node controller on profile 2 already exists, no nodeDef or driver changes detected
1/28/2023, 03:45:35 [pg3] info: [00:21:b9:02:50:a1_3] Set customparamsdoc
1/28/2023, 03:45:35 [pg3] info: [00:21:b9:02:50:a1_9] Set customparamsdoc
1/28/2023, 03:45:35 [pg3] info: [00:21:b9:02:50:a1_2] Set customparamsdoc
1/28/2023, 03:45:36 [pg3] info: upload successful
1/28/2023, 03:45:45 [pg3] info: node bef655e on profile 1 already exists, no nodeDef or driver changes detected
1/28/2023, 03:45:45 [pg3] info: node forecast_0 on profile 9 already exists, no nodeDef or driver changes detected
1/28/2023, 03:45:47 [pg3] info: node be95175 on profile 1 already exists, no nodeDef or driver changes detected
1/28/2023, 03:45:47 [pg3] info: node forecast_1 on profile 9 already exists, no nodeDef or driver changes detected
1/28/2023, 03:45:48 [pg3] info: node be8062e on profile 1 already exists, no nodeDef or driver changes detected
1/28/2023, 03:45:49 [pg3] info: node forecast_2 on profile 9 already exists, no nodeDef or driver changes detected
1/28/2023, 03:45:50 [pg3] info: node be950dc on profile 1 already exists, no nodeDef or driver changes detected
1/28/2023, 03:45:51 [pg3] info: node bef6783 on profile 1 already exists, no nodeDef or driver changes detected
1/28/2023, 03:45:52 [pg3] info: node forecast_3 on profile 9 already exists, no nodeDef or driver changes detected
1/28/2023, 03:45:52 [pg3] info: node bef6f3c on profile 1 already exists, no nodeDef or driver changes detected
1/28/2023, 03:45:53 [pg3] info: node forecast_4 on profile 9 already exists, no nodeDef or driver changes detected
1/28/2023, 03:45:59 [pg3] info: upload successful
1/28/2023, 03:46:01 [pg3] info: upload successful
1/28/2023, 03:46:03 [pg3] info: upload successful
1/28/2023, 03:46:07 [pg3] info: upload successful
1/28/2023, 03:50:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 03:50:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 03:50:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 03:50:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 03:50:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 03:50:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 03:54:58 [pg3] info: [00:21:b9:02:50:a1(1)] ISY HTTP Inbound: Received PAUSE for node: bef655e
1/28/2023, 03:54:58 [pg3] info: [00:21:b9:02:50:a1(1)] ISY HTTP Inbound: Received PAUSE for node: bef6f3c
1/28/2023, 03:54:58 [pg3] info: [00:21:b9:02:50:a1(1)] ISY HTTP Inbound: Received PAUSE for node: be950dc
1/28/2023, 03:54:59 [pg3] info: [00:21:b9:02:50:a1(1)] ISY HTTP Inbound: Received PAUSE for node: be8062e
1/28/2023, 03:54:59 [pg3] info: [00:21:b9:02:50:a1(1)] ISY HTTP Inbound: Received PAUSE for node: be95175
1/28/2023, 03:55:00 [pg3] info: [00:21:b9:02:50:a1(1)] ISY HTTP Inbound: Received PAUSE for node: bef6783
1/28/2023, 03:55:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 03:55:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 03:55:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 03:55:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 03:55:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 03:55:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:00:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 04:00:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 04:00:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:00:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 04:00:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 04:00:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:05:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 04:05:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 04:05:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:05:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 04:05:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 04:05:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:10:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 04:10:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 04:10:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:10:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 04:10:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 04:10:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:15:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 04:15:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 04:15:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:15:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 04:15:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 04:15:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:20:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 04:20:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 04:20:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:20:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 04:20:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 04:20:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:25:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 04:25:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 04:25:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:25:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 04:25:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 04:25:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:30:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 04:30:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 04:30:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:30:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 04:30:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 04:30:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:35:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 04:35:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 04:35:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:35:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 04:35:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 04:35:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:40:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 04:40:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 04:40:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:40:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 04:40:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 04:40:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:45:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 04:45:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 04:45:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:45:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 04:45:23 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 04:45:23 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:50:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 04:50:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 04:50:23 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:50:23 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 04:50:23 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 04:50:23 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:55:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 04:55:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 04:55:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 04:55:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 04:55:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 04:55:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:00:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 05:00:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 05:00:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:00:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 05:00:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 05:00:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:05:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 05:05:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 05:05:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:05:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 05:05:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 05:05:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:10:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 05:10:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 05:10:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:10:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 05:10:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 05:10:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:15:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 05:15:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 05:15:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:15:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 05:15:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 05:15:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:20:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 05:20:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 05:20:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:20:23 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 05:20:23 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 05:20:23 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:25:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 05:25:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 05:25:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:25:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 05:25:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 05:25:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:30:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 05:30:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 05:30:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:30:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 05:30:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 05:30:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:35:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 05:35:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 05:35:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:35:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 05:35:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 05:35:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:40:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 05:40:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 05:40:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:40:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 05:40:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 05:40:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:45:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 05:45:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 05:45:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:45:23 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 05:45:23 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 05:45:23 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:45:25 [pg3] info: [00:21:b9:02:50:a1_3] controller reporting command DON
1/28/2023, 05:45:26 [pg3] info: [00:21:b9:02:50:a1_2] controller reporting command DON
1/28/2023, 05:50:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 05:50:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 05:50:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:50:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 05:50:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 05:50:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:55:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 05:55:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 05:55:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 05:55:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 05:55:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 05:55:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:00:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 06:00:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 06:00:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:00:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 06:00:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 06:00:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:05:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 06:05:23 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 06:05:23 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:05:23 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 06:05:23 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 06:05:23 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:10:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 06:10:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 06:10:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:10:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 06:10:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 06:10:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:15:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 06:15:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 06:15:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:15:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 06:15:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 06:15:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:20:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 06:20:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 06:20:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:20:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 06:20:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 06:20:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:25:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 06:25:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 06:25:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:25:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 06:25:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 06:25:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:29:57 [pg3] info: [00:21:b9:02:50:a1(4)] ISY HTTP Inbound: Received CLISPH for node: 1547108
1/28/2023, 06:30:02 [pg3] info: [00:21:b9:02:50:a1(4)] ISY HTTP Inbound: Received query n004_1547108
1/28/2023, 06:30:02 [pg3] info: [00:21:b9:02:50:a1(4)] ISY HTTP Inbound request ID: 2923
1/28/2023, 06:30:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 06:30:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 06:30:23 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:30:23 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 06:30:23 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 06:30:23 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:35:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 06:35:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 06:35:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:35:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 06:35:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 06:35:23 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:40:22 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 06:40:22 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 06:40:22 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:40:22 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 06:40:22 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 06:40:22 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:43:22 [pg3] error: uncaughtException: read ECONNRESET
1/28/2023, 06:43:22 [pg3] error: uncaught ECONNRESET exception:  Error: read ECONNRESET
1/28/2023, 06:43:22 [pg3] info: Caught SIGTERM/SIGINT Shutting down.
1/28/2023, 06:43:22 [pg3] info: Stopping running node servers...
1/28/2023, 06:43:22 [pg3] info: [ST-Sonos(1)]: Stopping Node Server
1/28/2023, 06:43:22 [pg3] info: [DysonPureCool(2)]: Stopping Node Server
1/28/2023, 06:43:22 [pg3] info: [DysonPureCool(3)]: Stopping Node Server
1/28/2023, 06:43:22 [pg3] info: [OpenWeatherMap(9)]: Stopping Node Server
1/28/2023, 06:43:22 [pg3] error: MQTTS: clientError: 00:21:b9:02:50:a1_9 invalid publish
1/28/2023, 06:43:22 [pg3] info: MQTTS: Client Disconnected: 00:21:b9:02:50:a1_9
1/28/2023, 06:43:22 [pg3] error: MQTTS: clientError: 00:21:b9:02:50:a1_3 invalid publish
1/28/2023, 06:43:22 [pg3] error: MQTTS: clientError: 00:21:b9:02:50:a1_2 invalid publish
1/28/2023, 06:43:22 [pg3] info: MQTTS: Client Disconnected: 00:21:b9:02:50:a1_3
1/28/2023, 06:43:22 [pg3] info: MQTTS: Client Disconnected: 00:21:b9:02:50:a1_2
1/28/2023, 06:43:25 [pg3] info: PG3 shutdown complete with code: 1
1/28/2023, 06:43:44 [pg3] info: Starting PG3 version 3.1.16
1/28/2023, 06:43:44 [pg3] info: Using Workdir /var/polyglot/pg3/
1/28/2023, 06:43:44 [pg3] info: Installing latest udi_interface module
1/28/2023, 06:43:51 [pg3] info: NSChild: PythonInterface /usr/local/bin/pip3 install udi_interface --user: exited with cause code: 0
1/28/2023, 06:43:51 [pg3] info: Starting sqlite database at /var/polyglot/pg3/pg3.db
1/28/2023, 06:43:51 [pg3] info: Encryption key found ID: 19851007-b8a3-4d0d-b08f-12e1eca264af. Database version 1
1/28/2023, 06:43:51 [pg3] info: Query IoX for platform  UUID.
1/28/2023, 06:43:51 [pg3] info: Loaded globalsettings successfully. Database version 1
1/28/2023, 06:43:51 [pg3] info: isy table: Loaded (1) successfully
1/28/2023, 06:43:51 [pg3] info: ISY: 00:21:b9:02:50:a1 5.3.4 192.168.0.10 e8547107-4069-41da-a048-28792d4dc460
1/28/2023, 06:43:51 [pg3] info: Node Server table: Loaded 6 Node Server(s) successfully
1/28/2023, 06:43:51 [pg3] info: store is up-to-date
1/28/2023, 06:43:51 [pg3] info: Updated configuration with overrides
1/28/2023, 06:43:51 [pg3] info: Starting update check
1/28/2023, 06:43:51 [pg3] info: Starting MQTT Server Aedes
1/28/2023, 06:43:51 [pg3] info: Aedes MQTT Broker Service: Started on port 1888
1/28/2023, 06:43:52 [pg3] info: Started MQTT Client Service
1/28/2023, 06:43:52 [pg3] info: Creating ISY queues for 00:21:b9:02:50:a1
1/28/2023, 06:43:52 [pg3] info: HTTP Queue response "Queue Created Successfully,"
1/28/2023, 06:43:52 [pg3] info: Starting event listeners
1/28/2023, 06:43:52 [pg3] info: Starting Store Poll Refresh timer
1/28/2023, 06:43:52 [pg3] info: Starting ISY verification.
1/28/2023, 06:43:52 [pg3] info: Query ISY description at http://192.168.0.10:181/desc
1/28/2023, 06:43:52 [pg3] info: Koa HTTPS Interface Service: Started - Address: 0.0.0.0 Port: 3000
1/28/2023, 06:43:52 [pg3] warn: Default password for user admin still in use! Please change!
1/28/2023, 06:43:52 [pg3] info: Checking ISY's for installed node servers...
1/28/2023, 06:43:52 [pg3] info: MQTTS: Client Connected: pg3_client
1/28/2023, 06:43:52 [pg3] info: MQTTS: Client Connected: 00:21:b9:02:50:a1_4
1/28/2023, 06:43:52 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 06:43:52 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 06:43:52 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Airscape
1/28/2023, 06:43:53 [pg3] info: Checking for changes in HusqvarnaMower
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Timedata
1/28/2023, 06:43:53 [pg3] info: Checking for changes in YoLink
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Sun
1/28/2023, 06:43:53 [pg3] info: Checking for changes in PurpleAir
1/28/2023, 06:43:53 [pg3] info: Checking for changes in UnifiProtect
1/28/2023, 06:43:53 [pg3] info: Checking for changes in WLED
1/28/2023, 06:43:53 [pg3] info: Checking for changes in AERISWeather
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Flair
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Airthings-C
1/28/2023, 06:43:53 [pg3] info: Checking for changes in August
1/28/2023, 06:43:53 [pg3] info: Checking for changes in HarmonyHub
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Roku
1/28/2023, 06:43:53 [pg3] info: Checking for changes in MiLight
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Sensibo
1/28/2023, 06:43:53 [pg3] info: Checking for changes in AVRemote
1/28/2023, 06:43:53 [pg3] info: Checking for changes in WeatherBit
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Virtual
1/28/2023, 06:43:53 [pg3] info: Checking for changes in NanoLeaf
1/28/2023, 06:43:53 [pg3] info: Checking for changes in NOAA
1/28/2023, 06:43:53 [pg3] info: Checking for changes in OnkyoAVR
1/28/2023, 06:43:53 [pg3] info: Checking for changes in LiFX
1/28/2023, 06:43:53 [pg3] info: Checking for changes in VirtualButtons
1/28/2023, 06:43:53 [pg3] info: Checking for changes in ST-Inventory
1/28/2023, 06:43:53 [pg3] info: Checking for changes in ATest
1/28/2023, 06:43:53 [pg3] info: Checking for changes in AMINEM
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Roomba
1/28/2023, 06:43:53 [pg3] info: Checking for changes in WeatherLink
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Russound
1/28/2023, 06:43:53 [pg3] info: Checking for changes in TeslaPW
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Rachio
1/28/2023, 06:43:53 [pg3] info: Checking for changes in ST-Nuheat
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Hue
1/28/2023, 06:43:53 [pg3] info: Checking for changes in UnifiPresence
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Holidays
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Sonos
1/28/2023, 06:43:53 [pg3] info: Checking for changes in iAquaLink
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Climacell
1/28/2023, 06:43:53 [pg3] info: Checking for changes in ST-Sonos
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Notification
1/28/2023, 06:43:53 [pg3] info: Checking for changes in WirelessTag
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Volumio
1/28/2023, 06:43:53 [pg3] info: Checking for changes in WeatherPoly
1/28/2023, 06:43:53 [pg3] info: Checking for changes in EnvisaLink-HW
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Bond
1/28/2023, 06:43:53 [pg3] info: Checking for changes in BalboaSPA
1/28/2023, 06:43:53 [pg3] info: Checking for changes in HolidaysGoogle
1/28/2023, 06:43:53 [pg3] info: Checking for changes in OpenSprinkler
1/28/2023, 06:43:53 [pg3] info: Checking for changes in DavisWeather
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Twinkly
1/28/2023, 06:43:53 [pg3] info: Checking for changes in IFTTT-Webhooks
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Wemo
1/28/2023, 06:43:53 [pg3] info: Checking for changes in WeatherFlow
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Ping
1/28/2023, 06:43:53 [pg3] info: Checking for changes in TeslaEV
1/28/2023, 06:43:53 [pg3] info: Checking for changes in BASIRRIGATION
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Backup
1/28/2023, 06:43:53 [pg3] info: Checking for changes in DysonPureCool
1/28/2023, 06:43:53 [pg3] info: Checking for changes in AVServer
1/28/2023, 06:43:53 [pg3] info: Checking for changes in EnvisaLink-DSC
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Govee
1/28/2023, 06:43:53 [pg3] info: Checking for changes in OpenWeatherMap
1/28/2023, 06:43:53 [pg3] info: Checking for changes in BlueIris
1/28/2023, 06:43:53 [pg3] info: Checking for changes in MagicHome
1/28/2023, 06:43:53 [pg3] info: Checking for changes in RainMachine
1/28/2023, 06:43:53 [pg3] info: Checking for changes in MQTT
1/28/2023, 06:43:53 [pg3] info: Checking for changes in BASPOOL
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Acurite
1/28/2023, 06:43:53 [pg3] info: Checking for changes in MyQ
1/28/2023, 06:43:53 [pg3] info: Checking for changes in VenstarCT
1/28/2023, 06:43:53 [pg3] info: Checking for changes in iTach-IR
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Plex-WebHook
1/28/2023, 06:43:53 [pg3] info: Checking for changes in BASGARAGE
1/28/2023, 06:43:53 [pg3] info: Checking for changes in FlumeWater
1/28/2023, 06:43:53 [pg3] info: Checking for changes in VUE
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Caseta
1/28/2023, 06:43:53 [pg3] info: Checking for changes in ShellyRGBW2
1/28/2023, 06:43:53 [pg3] info: Checking for changes in ST-EcoWitt
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Blink
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Kasa
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Kaiterra
1/28/2023, 06:43:53 [pg3] info: Checking for changes in ELK
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Sense
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Somfy
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Netatmo-WS
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Ecobee
1/28/2023, 06:43:53 [pg3] info: Checking for changes in BASAO
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Wake-On-Lan
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Push
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Camect
1/28/2023, 06:43:53 [pg3] info: Checking for changes in SolarEdge
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Meteobridge
1/28/2023, 06:43:53 [pg3] info: Checking for changes in TotalConnect
1/28/2023, 06:43:53 [pg3] info: Checking for changes in MySmartBlinds
1/28/2023, 06:43:53 [pg3] info: Checking for changes in HueEmulator
1/28/2023, 06:43:53 [pg3] info: Checking for changes in Eagle-200
1/28/2023, 06:43:53 [pg3] info: Checking for changes in AmbientWeather
1/28/2023, 06:43:53 [pg3] info: Checking for changes in HoneywellHome
1/28/2023, 06:43:53 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 06:43:54 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 06:43:54 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:43:54 [pg3] info: Waiting for store (false) and isy (true) before starting node servers.
1/28/2023, 06:43:54 [pg3] info: *****************************************
1/28/2023, 06:43:54 [pg3] info: Latest PG3 version available is 3.1.16
1/28/2023, 06:43:54 [pg3] info: Checking for changes in DSC-IT100
1/28/2023, 06:43:54 [pg3] info: Checking for changes in Roku
1/28/2023, 06:43:54 [pg3] info: Checking for changes in PythonTemplate
1/28/2023, 06:43:54 [pg3] info: Checking for changes in Example-1
1/28/2023, 06:43:54 [pg3] info: Checking for changes in Tuya-Devices
1/28/2023, 06:43:54 [pg3] info: Checking for changes in ATest
1/28/2023, 06:43:54 [pg3] info: Checking for changes in Roomba
1/28/2023, 06:43:54 [pg3] info: Checking for changes in TestTeslaEV
1/28/2023, 06:43:54 [pg3] info: Checking for changes in Example-2
1/28/2023, 06:43:54 [pg3] info: Checking for changes in Notification
1/28/2023, 06:43:54 [pg3] info: Checking for changes in Example-4
1/28/2023, 06:43:54 [pg3] info: Checking for changes in OpenSprinkler
1/28/2023, 06:43:54 [pg3] info: Checking for changes in Example-3
1/28/2023, 06:43:54 [pg3] info: Checking for changes in eISYIR
1/28/2023, 06:43:54 [pg3] info: Checking for changes in Sensibo-Air
1/28/2023, 06:43:54 [pg3] info: Checking for changes in VueTest
1/28/2023, 06:43:54 [pg3] info: Checking for changes in MagicHome
1/28/2023, 06:43:54 [pg3] info: Checking for changes in iTach-IR
1/28/2023, 06:43:54 [pg3] info: Checking for changes in Kasa
1/28/2023, 06:43:54 [pg3] info: Checking for changes in ELK
1/28/2023, 06:43:54 [pg3] info: Checking for changes in Ecobee
1/28/2023, 06:43:55 [pg3] info: Starting installed and enabled node servers...
1/28/2023, 06:43:55 [pg3] info: startNs:: DysonPureCool
1/28/2023, 06:43:55 [pg3] info: startNs:: DysonPureCool is valid
1/28/2023, 06:43:55 [pg3] info: startNs:: ST-Nuheat
1/28/2023, 06:43:55 [pg3] info: startNs:: ST-Nuheat is valid
1/28/2023, 06:43:55 [pg3] info: startNs:: OpenWeatherMap
1/28/2023, 06:43:55 [pg3] info: startNs:: OpenWeatherMap is valid
1/28/2023, 06:43:55 [pg3] info: startNs:: ST-Sonos
1/28/2023, 06:43:55 [pg3] info: startNs:: ST-Sonos is valid
1/28/2023, 06:43:55 [pg3] info: checkLicense:: DysonPureCool Valid perpetual license found.
1/28/2023, 06:43:55 [pg3] info: startNs:: DysonPureCool finished update check
1/28/2023, 06:43:55 [pg3] info: checkLicense:: ST-Nuheat Valid perpetual license found.
1/28/2023, 06:43:55 [pg3] info: startNs:: ST-Nuheat finished update check
1/28/2023, 06:43:55 [pg3] info: checkLicense:: ST-Sonos Valid perpetual license found.
1/28/2023, 06:43:55 [pg3] info: startNs:: ST-Sonos finished update check
1/28/2023, 06:43:55 [pg3] info: checkLicense:: OpenWeatherMap Valid perpetual license found.
1/28/2023, 06:43:55 [pg3] info: startNs:: OpenWeatherMap finished update check
1/28/2023, 06:43:55 [pg3] info: [DysonPureCool(3)] :: Starting Node Server - Version 4.0.0
1/28/2023, 06:43:55 [pg3] info: startNs:: DysonPureCool updating database (enabled, timestarted)
1/28/2023, 06:43:55 [pg3] info: [ST-Nuheat(4)] :: Starting Node Server - Version 1.0.2
1/28/2023, 06:43:56 [pg3] info: startNs:: ST-Nuheat updating database (enabled, timestarted)
1/28/2023, 06:43:56 [pg3] info: [DysonPureCool(2)] :: Starting Node Server - Version 4.0.0
1/28/2023, 06:43:56 [pg3] info: startNs:: DysonPureCool updating database (enabled, timestarted)
1/28/2023, 06:43:56 [pg3] info: startNs:: DysonPureCool starting polls
1/28/2023, 06:43:56 [pg3] info: Starting Node Server Info timer 0
1/28/2023, 06:43:56 [pg3] info: [ST-Sonos(1)] :: Starting Node Server - Version 1.0.6
1/28/2023, 06:43:57 [pg3] info: startNs:: ST-Sonos updating database (enabled, timestarted)
1/28/2023, 06:43:57 [pg3] info: startNs:: ST-Nuheat starting polls
1/28/2023, 06:43:57 [pg3] info: Starting Node Server Info timer 0
1/28/2023, 06:43:57 [pg3] info: startNs:: DysonPureCool starting polls
1/28/2023, 06:43:57 [pg3] info: [OpenWeatherMap(9)] :: Starting Node Server - Version 3.1.4
1/28/2023, 06:43:57 [pg3] info: startNs:: OpenWeatherMap updating database (enabled, timestarted)
1/28/2023, 06:43:58 [pg3] info: startNs:: ST-Sonos starting polls
1/28/2023, 06:43:58 [pg3] info: Starting Node Server Info timer 0
1/28/2023, 06:43:58 [pg3] info: startNs:: OpenWeatherMap starting polls
1/28/2023, 06:44:00 [pg3] info: [ST-Sonos 1] :: STDOUT: 2023-01-28T11:44:00.419Z INFO Could not find file /var/polyglot/pg3/ns/0021b90250a1_1/node-sonos-http-api/settings.json
1/28/2023, 06:44:00 [pg3] error: MQTTS: ClientID: 00:21:b9:02:50:a1_4 is already connected. Disallowing multiple connections.
1/28/2023, 06:44:00 [pg3] error: MQTTS: clientError: 00:21:b9:02:50:a1_4 Auth Error
1/28/2023, 06:44:01 [pg3] info: MQTTS: Client Connected: 00:21:b9:02:50:a1_3
1/28/2023, 06:44:01 [pg3] info: [ST-Nuheat(4)] :: Exit cause code: 2 - signal: null
1/28/2023, 06:44:01 [pg3] info: MQTTS: Client Connected: 00:21:b9:02:50:a1_1
1/28/2023, 06:44:01 [pg3] info: [00:21:b9:02:50:a1_3] Set notices
1/28/2023, 06:44:01 [pg3] info: MQTTS: Client Connected: 00:21:b9:02:50:a1_2
1/28/2023, 06:44:02 [pg3] info: upload successful
1/28/2023, 06:44:02 [pg3] info: node controller on profile 3 already exists, no nodeDef or driver changes detected
1/28/2023, 06:44:02 [pg3] info: MQTTS: Client Connected: 00:21:b9:02:50:a1_9
1/28/2023, 06:44:02 [pg3] info: [00:21:b9:02:50:a1_3] Set customparamsdoc
1/28/2023, 06:44:03 [pg3] info: [00:21:b9:02:50:a1_1] Set notices
1/28/2023, 06:44:03 [pg3] info: [00:21:b9:02:50:a1_1] Set customparamsdoc
1/28/2023, 06:44:05 [pg3] info: [00:21:b9:02:50:a1_2] Set notices
1/28/2023, 06:44:05 [pg3] info: upload successful
1/28/2023, 06:44:06 [pg3] info: [00:21:b9:02:50:a1_9] Set notices
1/28/2023, 06:44:06 [pg3] info: node controller on profile 2 already exists, no nodeDef or driver changes detected
1/28/2023, 06:44:06 [pg3] info: [00:21:b9:02:50:a1_2] Set customparamsdoc
1/28/2023, 06:44:07 [pg3] info: node controller on profile 9 already exists, no nodeDef or driver changes detected
1/28/2023, 06:44:07 [pg3] info: [00:21:b9:02:50:a1_9] Set customparamsdoc
1/28/2023, 06:44:07 [pg3] info: upload successful
1/28/2023, 06:44:08 [pg3] info: upload successful
1/28/2023, 06:44:09 [pg3] info: node be95175 on profile 1 already exists, no nodeDef or driver changes detected
1/28/2023, 06:44:09 [pg3] info: node forecast_0 on profile 9 already exists, no nodeDef or driver changes detected
1/28/2023, 06:44:13 [pg3] info: node be8062e on profile 1 already exists, no nodeDef or driver changes detected
1/28/2023, 06:44:14 [pg3] info: node forecast_1 on profile 9 already exists, no nodeDef or driver changes detected
1/28/2023, 06:44:15 [pg3] info: node be950dc on profile 1 already exists, no nodeDef or driver changes detected
1/28/2023, 06:44:16 [pg3] info: node forecast_2 on profile 9 already exists, no nodeDef or driver changes detected
1/28/2023, 06:44:17 [pg3] info: node bef655e on profile 1 already exists, no nodeDef or driver changes detected
1/28/2023, 06:44:18 [pg3] info: node forecast_3 on profile 9 already exists, no nodeDef or driver changes detected
1/28/2023, 06:44:18 [pg3] info: node bef6783 on profile 1 already exists, no nodeDef or driver changes detected
1/28/2023, 06:44:19 [pg3] info: node forecast_4 on profile 9 already exists, no nodeDef or driver changes detected
1/28/2023, 06:44:20 [pg3] info: node bef6f3c on profile 1 already exists, no nodeDef or driver changes detected
1/28/2023, 06:44:26 [pg3] info: upload successful
1/28/2023, 06:44:28 [pg3] info: upload successful
1/28/2023, 06:44:30 [pg3] info: upload successful
1/28/2023, 06:44:34 [pg3] info: upload successful
1/28/2023, 06:48:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 06:48:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 06:48:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:48:54 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 06:48:54 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 06:48:54 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:53:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 06:53:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 06:53:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:53:54 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 06:53:54 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 06:53:54 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:58:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 06:58:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 06:58:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 06:58:54 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 06:58:54 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 06:58:54 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:03:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 07:03:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 07:03:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:03:54 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 07:03:54 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 07:03:54 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:08:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 07:08:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 07:08:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:08:55 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 07:08:55 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 07:08:55 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:13:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 07:13:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 07:13:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:13:54 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 07:13:54 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 07:13:54 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:18:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 07:18:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 07:18:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:18:54 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 07:18:54 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 07:18:54 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:23:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 07:23:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 07:23:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:23:54 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 07:23:54 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 07:23:54 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:28:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 07:28:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 07:28:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:28:54 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 07:28:54 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 07:28:54 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:29:42 [pg3] info: [00:21:b9:02:50:a1(3)] ISY HTTP Inbound: Received POWER for node: controller
1/28/2023, 07:29:44 [pg3] info: [00:21:b9:02:50:a1(3)] ISY HTTP Inbound: Received AIRFLOW for node: controller
1/28/2023, 07:29:46 [pg3] info: [00:21:b9:02:50:a1(3)] ISY HTTP Inbound: Received OSCILLATION for node: controller
1/28/2023, 07:29:48 [pg3] info: [00:21:b9:02:50:a1(3)] ISY HTTP Inbound: Received HUMIDITY_SETPOINT for node: controller
1/28/2023, 07:29:50 [pg3] info: [00:21:b9:02:50:a1(3)] ISY HTTP Inbound: Received HUMIDITY_AUTO_MODE for node: controller
1/28/2023, 07:29:52 [pg3] info: [00:21:b9:02:50:a1(3)] ISY HTTP Inbound: Received AUTO_MODE for node: controller
1/28/2023, 07:29:54 [pg3] info: [00:21:b9:02:50:a1(3)] ISY HTTP Inbound: Received NIGHT_MODE for node: controller
1/28/2023, 07:29:59 [pg3] info: [00:21:b9:02:50:a1(3)] ISY HTTP Inbound: Received OSCILLATION for node: controller
1/28/2023, 07:33:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 07:33:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 07:33:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:33:54 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 07:33:54 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 07:33:54 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:38:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 07:38:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 07:38:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:38:54 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 07:38:55 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 07:38:55 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:43:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 07:43:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 07:43:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:43:54 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 07:43:54 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 07:43:54 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:48:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 07:48:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 07:48:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:48:54 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 07:48:54 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 07:48:54 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:53:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 07:53:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 07:53:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:53:54 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 07:53:54 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 07:53:54 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:58:48 [pg3] info: Successful login
1/28/2023, 07:58:48 [pg3] info: MQTTS: Client Connected: pg3frontend_yt1fX
1/28/2023, 07:58:50 [pg3] info: [00:21:b9:02:50:a1_4] Retrieved customparams
1/28/2023, 07:58:50 [pg3] info: [00:21:b9:02:50:a1_4] Retrieved customparamsdoc
1/28/2023, 07:58:50 [pg3] info: [00:21:b9:02:50:a1_4] Retrieved customtypeddata
1/28/2023, 07:58:50 [pg3] info: [00:21:b9:02:50:a1_4] Retrieved notices
1/28/2023, 07:58:50 [pg3] info: [00:21:b9:02:50:a1_4] Retrieved oauth
1/28/2023, 07:58:54 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/28/2023, 07:58:54 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/28/2023, 07:58:54 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:58:54 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/28/2023, 07:58:54 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/28/2023, 07:58:54 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/28/2023, 07:59:17 [pg3] debug: MQTT Results: [frontend/system/jwagner010] :: {"pg3LogLevel":{"success":true,"level":"debug"}}
1/28/2023, 07:59:17 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/687d33b3-f471-4b68-9768-7360b3eaa1a5 to broker pg3_broker
1/28/2023, 07:59:24 [pg3] debug: Downloading logfile :: /var/polyglot/pg3/logs/pg3-current.log
ST-NuHeat Log extract from time it looks like problem starts at around 1/28 @ 3:44am:
2023-01-28 03:42:55 debug: POLY:       -> topic is udi/pg3/ns/clients/00:21:b9:02:50:a1_4, processing
2023-01-28 03:42:55 debug: NS: Message Received: { shortPoll: {} }
2023-01-28 03:42:55 info: NS: Short Poll: Update nodes
2023-01-28 03:42:55 debug: NS: Message Sent: {
  set: [
    { address: 'controller', driver: 'ST', value: '1', uom: 2 },
    [length]: 1
2023-01-28 03:42:55 debug: POLY: _sendMessage: sending
      {"set":[{"address":"controller","driver":"ST","value":"1","uom":2}]} to udi/pg3/ns/status/00:21:b9:02:50:a1_4
2023-01-28 03:42:56 debug: POLY:       -> topic is udi/pg3/ns/clients/00:21:b9:02:50:a1_4, processing
2023-01-28 03:42:56 debug: NS: Message Received: {
  set: [
    [length]: 1
2023-01-28 03:44:52 debug: POLY:       -> topic is udi/pg3/ns/clients/00:21:b9:02:50:a1_4, processing
2023-01-28 03:44:52 debug: NS: Message Received: { stop: {} }
2023-01-28 03:44:52 warn: POLY: Received stop message
2023-01-28 03:44:52 info: NS: Graceful stop
2023-01-28 03:45:21 info: POLY: MQTT client connected
2023-01-28 03:45:21 info: NS: MQTT Connection started
2023-01-28 03:45:21 debug: POLY: Sending config/getAll to PG3
2023-01-28 03:45:21 debug: NS: Message Sent: { getIsyInfo: {} }
2023-01-28 03:45:21 debug: POLY: _sendMessage: sending
      {"getIsyInfo":{}} to udi/pg3/ns/system/00:21:b9:02:50:a1_4
2023-01-28 03:45:21 debug: NS: Message Sent: { config: {} }
      {"config":{}} to udi/pg3/ns/system/00:21:b9:02:50:a1_4
2023-01-28 03:45:21 debug: NS: Message Sent: { getAll: {} }
      {"getAll":{}} to udi/pg3/ns/custom/00:21:b9:02:50:a1_4
2023-01-28 03:45:29 info: NS: Starting Node Server
2023-01-28 03:45:29 info: POLY: Interface starting
2023-01-28 03:45:29 info: POLY: Getting config from environment
2023-01-28 03:45:30 error: POLY: MQTT Error:  Connection refused: Identifier rejected
2023-01-28 06:29:57 debug: POLY:       -> topic is udi/pg3/ns/clients/00:21:b9:02:50:a1_4, processing
2023-01-28 06:29:57 debug: NS: Message Received: {
  command: {
    address: '1547108',
    cmd: 'CLISPH',
    value: '78',
    uom: '17',
    query: {}
2023-01-28 06:29:57 warn: POLY: Message command ignored: Shutting down Node Server
2023-01-28 06:30:02 debug: POLY:       -> topic is udi/pg3/ns/clients/00:21:b9:02:50:a1_4, processing
2023-01-28 06:30:02 debug: NS: Message Received: { query: { address: '1547108' } }
2023-01-28 06:30:02 warn: POLY: Message query ignored: Shutting down Node Server
2023-01-28 06:43:52 info: POLY: MQTT client connected
2023-01-28 06:43:52 info: NS: MQTT Connection started
2023-01-28 06:43:52 debug: POLY: Sending config/getAll to PG3
2023-01-28 06:43:52 debug: NS: Message Sent: { getIsyInfo: {} }
2023-01-28 06:43:52 debug: POLY: _sendMessage: sending
2023-01-28 06:43:52 debug: NS: Message Sent: { config: {} }
2023-01-28 06:43:52 debug: NS: Message Sent: { getAll: {} }
2023-01-28 06:43:52 debug: POLY:       -> topic is udi/pg3/ns/clients/00:21:b9:02:50:a1_4, processing
2023-01-28 06:43:52 debug: NS: Message Received: {
  getIsyInfo: {
    isy_ip_address: '192.168.0.10',
    isy_username: 'jwagner010',
    isy_password: 'ISYGotigers2+',
    isy_port: 181,
    isy_https: 0
2023-01-28 06:43:52 warn: POLY: Message getIsyInfo ignored: Shutting down Node Server
2023-01-28 06:43:52 warn: POLY: Message config ignored: Shutting down Node Server
  getAll: [
      uuid: '00:21:b9:02:50:a1',
      profileNum: 4,
      key: 'customparams',
      value: '{"Username":"jason_wagner99@yahoo.com","Password":"Gotigers2","Scale":"Fahrenheit"}',
      dbVersion: 1
      profileNum: 4,
      key: 'customparamsdoc',
      value: '<h2>Configuring this node server</h2>\n' +
        '\n' +
        '<p>Enter the appropriate username (e-mail) and password used for the\n' +
        'http://www.mynuheat.com website.</p>\n' +
        '\n' +
        '<h3>Temperature Scales</h3>\n' +
        '\n' +
        '<ul><li>Fahrenheit</li><li>Metric</li></ul>\n' +
        '\n' +
        '<h3>Polling Parameters</h3>\n' +
        '\n' +
        '<ul><li>ShortPoll<ul><li>Time period between query of Thermostat temperature and settings</li><li>Default: 3 minutes (180 Seconds)</li><li>Shortest polling is 60 seconds</li></ul></li><li>LongPoll<ul><li>Nothing</li></ul></li></ul>\n' +
        '\n' +
        '<h3>Configuration</h3>\n' +
        '\n' +
        '<ul><li>Username: Your mynuheat.com username</li><li>Password: Your mynuheat.com password</li><li>Scale: (Fahrenheit | Celsius)</li></ul>\n' +
        '\n' +
        '<p>After enter configuration information and pressing &quot;Save&quot; the Node Server will poll\n' +
        'mynuheat.com and get setup nodes for each thermostat.</p>',
      dbVersion: 1
      profileNum: 4,
      key: 'customtypeddata',
      value: '{}',
      dbVersion: 1
      profileNum: 4,
      key: 'notices',
      value: '{}',
      dbVersion: 1
      profileNum: 4,
      key: 'nsdata',
      value: 'null',
      dbVersion: 1
      profileNum: 4,
      key: 'oauth',
      value: 'null',
      dbVersion: 1
    [length]: 6
2023-01-28 06:43:52 warn: POLY: Message getAll ignored: Shutting down Node Server
2023-01-28 06:44:00 info: NS: Starting Node Server
2023-01-28 06:44:00 info: POLY: Interface starting
2023-01-28 06:44:00 info: POLY: Getting config from environment
2023-01-28 06:44:01 error: POLY: MQTT Error:  Connection refused: Identifier rejected
19 hours ago, jwagner010 said:
@bpwwer Yes IOP is running on ISY994i (00:21:b9:02:50:a1) and PG3 I assume installs them into the ISY 994i
Yes the Node Servers / PG3 is running on the POLISY (00:0d:b9:52:c8:10 / 192.168.0.10)
If a bug in PG3 do I just need to wait to the next update is pushed out and then do 'update' via the Update Button on the POLISY Admin Console?
On a separate note will this also fix the ST-NuHeat Node Server stopping or do we still need to find the root cause of that?
The PG3 bug is only effecting those messages displayed in the PG3 log.  The check is wrong and then PG3 re-installs the node server config.  Other than installing the config when it isn't needed, this doesn't effect anything else.  It is fixed and will be available in the next release.  Yes, you'll just need to do a upgrade packages to pick up the new release.  It will probably be a few days from now.
No, this fix won't effect ST-NuHeat.  I'm planning to look into the node server this weekend.  It needs to be updated to work on the eisy so I'll look into why it's stopping at the same time.
First thank you for looking into both issues, very much appreciated.
It’s hard to keep up with all the new hardware and software versions.  My POLISY is running PG3 version 3.1.16, so the updated version of PG3 on my POLISY when it drops next week will be 3.1.17? Just want to be sure I am on the look out for the right version.
Again thanks for looking into both issues.
I started working on the node server and I reviewed the logs you posted above.  What I think happened is that PG3 encountered a network error that it wasn't able to handle so it shutdown.
When PG3 shutdown, it stopped (or attempted to stop) the node server.  However, it looks like the node server didn't stop so that when PG3 restarted, it was unable to start the node server because it was already running. PG3.
I've made a couple of changes to the node server to insure that it really does stop when PG3 tells it to. I should be able to release a new version tomorrow.
Thank you, will be on the lookout and post test results for you.  Again thanks for looking at this so quickly and over a weekend, totally unexpected.
Hi @bpwwer I installed 1.03 of the ST-NuHeat node server on my POLISY and it will not start at all now even after a reboot.  I have rebooted the POLISY a number of times and the node server still doesn't start.  There is no ST-NuHeat node server log to download, but I have attached the PG3 log since the last reboot.  At 20:16:29 there are a bunch of errors I don't understand:
1/29/2023, 20:15:05 [pg3] info: Caught SIGTERM/SIGINT Shutting down.
1/29/2023, 20:15:05 [pg3] info: Stopping running node servers...
1/29/2023, 20:15:05 [pg3] info: [ST-Sonos(1)]: Stopping Node Server
1/29/2023, 20:15:05 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:50:a1_1] {"stop":{}}
1/29/2023, 20:15:05 [pg3] info: [DysonPureCool(2)]: Stopping Node Server
1/29/2023, 20:15:05 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:50:a1_2] {"stop":{}}
1/29/2023, 20:15:05 [pg3] info: [DysonPureCool(3)]: Stopping Node Server
1/29/2023, 20:15:05 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:50:a1_3] {"stop":{}}
1/29/2023, 20:15:05 [pg3] info: [OpenWeatherMap(9)]: Stopping Node Server
1/29/2023, 20:15:05 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:50:a1_9] {"stop":{}}
1/29/2023, 20:15:05 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/687d33b3-f471-4b68-9768-7360b3eaa1a5 to broker pg3_broker
1/29/2023, 20:15:05 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:50:a1_1 to broker pg3_broker
1/29/2023, 20:15:05 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:50:a1_2 to broker pg3_broker
1/29/2023, 20:15:05 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:50:a1_3 to broker pg3_broker
1/29/2023, 20:15:05 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:50:a1_9 to broker pg3_broker
1/29/2023, 20:15:06 [pg3] error: MQTTS: clientError: 00:21:b9:02:50:a1_9 invalid publish
1/29/2023, 20:15:06 [pg3] error: MQTTS: clientError: 00:21:b9:02:50:a1_3 invalid publish
1/29/2023, 20:15:06 [pg3] error: MQTTS: clientError: 00:21:b9:02:50:a1_2 invalid publish
1/29/2023, 20:15:06 [pg3] info: MQTTS: Client Disconnected: 00:21:b9:02:50:a1_9
1/29/2023, 20:15:06 [pg3] debug: Client 00:21:b9:02:50:a1_9 unsubscribed from udi/pg3/ns/clients/00:21:b9:02:50:a1_9
1/29/2023, 20:15:06 [pg3] debug: UpdateConnected: current status = {"connected":0}
1/29/2023, 20:15:06 [pg3] debug: Query driver db for {"status_driver":"ST"} on node {"status_node":"controller"}.
1/29/2023, 20:15:06 [pg3] info: MQTTS: Client Disconnected: 00:21:b9:02:50:a1_3
1/29/2023, 20:15:06 [pg3] debug: Client 00:21:b9:02:50:a1_3 unsubscribed from udi/pg3/ns/clients/00:21:b9:02:50:a1_3
1/29/2023, 20:15:06 [pg3] debug: ******   No connection status node/driver defined.
1/29/2023, 20:15:06 [pg3] info: MQTTS: Client Disconnected: 00:21:b9:02:50:a1_2
1/29/2023, 20:15:06 [pg3] debug: Client 00:21:b9:02:50:a1_2 unsubscribed from udi/pg3/ns/clients/00:21:b9:02:50:a1_2
1/29/2023, 20:15:06 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/687d33b3-f471-4b68-9768-7360b3eaa1a5 to broker pg3_broker
1/29/2023, 20:15:06 [pg3] info: MQTTS: Client Disconnected: 00:21:b9:02:50:a1_1
1/29/2023, 20:15:06 [pg3] debug: Client 00:21:b9:02:50:a1_1 unsubscribed from udi/pg3/ns/clients/00:21:b9:02:50:a1_1
1/29/2023, 20:15:06 [pg3] debug: Scheduling http://192.168.0.10:181/rest/ns/9/nodes/n009_controller/report/status/ST/0/25 to group statusGroup
1/29/2023, 20:15:06 [pg3] debug: Created Status Queue for Node Server 9
1/29/2023, 20:15:06 [pg3] debug: ISY Response: [Try: 1] [00:21:b9:02:50:a1] :: [200] :: 138.085263ms - http://192.168.0.10:181/rest/ns/9/nodes/n009_controller/report/status/ST/0/25
1/29/2023, 20:15:06 [pg3] debug: MQTT Results: [ns/status/00:21:b9:02:50:a1,9] :: {"set":[{"address":"controller","driver":"ST","value":0,"uom":25}]}
1/29/2023, 20:15:06 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:50:a1_9] {"set":[{"address":"controller","driver":"ST","value":0,"uom":25}]}
1/29/2023, 20:15:06 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:50:a1_9 to broker pg3_broker
1/29/2023, 20:15:08 [pg3] info: ST-Sonos stopped
1/29/2023, 20:15:08 [pg3] info: Waiting for ST-Sonos to go away
1/29/2023, 20:15:08 [pg3] info: DysonPureCool stopped
1/29/2023, 20:15:08 [pg3] info: Waiting for DysonPureCool to go away
1/29/2023, 20:15:08 [pg3] info: OpenWeatherMap stopped
1/29/2023, 20:15:08 [pg3] info: Waiting for OpenWeatherMap to go away
1/29/2023, 20:15:09 [pg3] info: [DysonPureCool(3)] :: Exit cause code: null - signal: SIGTERM
1/29/2023, 20:15:09 [pg3] info: [DysonPureCool(2)] :: Exit cause code: null - signal: SIGTERM
1/29/2023, 20:15:09 [pg3] info: [ST-Sonos(1)] :: Exit cause code: null - signal: SIGTERM
1/29/2023, 20:15:09 [pg3] info: [OpenWeatherMap(9)] :: Exit cause code: null - signal: SIGTERM
1/29/2023, 20:15:09 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/687d33b3-f471-4b68-9768-7360b3eaa1a5 to broker pg3_broker
1/29/2023, 20:15:10 [pg3] info: Store Stopping Gracefully
1/29/2023, 20:15:10 [pg3] info: Removing ISY queues for 00:21:b9:02:50:a1
1/29/2023, 20:16:17 [pg3] info: Starting PG3 version 3.1.16
1/29/2023, 20:16:17 [pg3] info: Using Workdir /var/polyglot/pg3/
1/29/2023, 20:16:17 [pg3] info: Installing latest udi_interface module
1/29/2023, 20:16:24 [pg3] info: NSChild: PythonInterface /usr/local/bin/pip3 install udi_interface --user: exited with cause code: 0
1/29/2023, 20:16:24 [pg3] info: Starting sqlite database at /var/polyglot/pg3/pg3.db
1/29/2023, 20:16:24 [pg3] info: Encryption key found ID: 19851007-b8a3-4d0d-b08f-12e1eca264af. Database version 1
1/29/2023, 20:16:24 [pg3] info: Query IoX for platform  UUID.
1/29/2023, 20:16:24 [pg3] info: Loaded globalsettings successfully. Database version 1
1/29/2023, 20:16:24 [pg3] info: isy table: Loaded (1) successfully
1/29/2023, 20:16:24 [pg3] info: ISY: 00:21:b9:02:50:a1 5.3.4 192.168.0.10 e8547107-4069-41da-a048-28792d4dc460
1/29/2023, 20:16:24 [pg3] info: Node Server table: Loaded 6 Node Server(s) successfully
1/29/2023, 20:16:24 [pg3] info: store is up-to-date
1/29/2023, 20:16:24 [pg3] info: Updated configuration with overrides
1/29/2023, 20:16:25 [pg3] info: Starting update check
1/29/2023, 20:16:25 [pg3] info: Starting MQTT Server Aedes
1/29/2023, 20:16:25 [pg3] info: Aedes MQTT Broker Service: Started on port 1888
1/29/2023, 20:16:25 [pg3] info: Started MQTT Client Service
1/29/2023, 20:16:25 [pg3] info: Creating ISY queues for 00:21:b9:02:50:a1
1/29/2023, 20:16:25 [pg3] info: HTTP Queue response "Queue Created Successfully,"
1/29/2023, 20:16:25 [pg3] info: Starting event listeners
1/29/2023, 20:16:25 [pg3] info: Starting Store Poll Refresh timer
1/29/2023, 20:16:25 [pg3] info: Starting ISY verification.
1/29/2023, 20:16:25 [pg3] info: Query ISY description at http://192.168.0.10:181/desc
1/29/2023, 20:16:25 [pg3] info: Koa HTTPS Interface Service: Started - Address: 0.0.0.0 Port: 3000
1/29/2023, 20:16:25 [pg3] warn: Default password for user admin still in use! Please change!
1/29/2023, 20:16:25 [pg3] info: Checking ISY's for installed node servers...
1/29/2023, 20:16:25 [pg3] info: MQTTS: Client Connected: pg3_client
1/29/2023, 20:16:26 [pg3] info: ISY node server user configuration update required 00:21:b9:02:50:a1 vs 00:0d:b9:52:c8:10
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Airscape
1/29/2023, 20:16:26 [pg3] info: Checking for changes in HusqvarnaMower
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Timedata
1/29/2023, 20:16:26 [pg3] info: Checking for changes in YoLink
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Sun
1/29/2023, 20:16:26 [pg3] info: Checking for changes in PurpleAir
1/29/2023, 20:16:26 [pg3] info: Checking for changes in UnifiProtect
1/29/2023, 20:16:26 [pg3] info: Checking for changes in WLED
1/29/2023, 20:16:26 [pg3] info: Checking for changes in AERISWeather
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Flair
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Airthings-C
1/29/2023, 20:16:26 [pg3] info: Checking for changes in August
1/29/2023, 20:16:26 [pg3] info: Checking for changes in HarmonyHub
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Roku
1/29/2023, 20:16:26 [pg3] info: Checking for changes in MiLight
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Sensibo
1/29/2023, 20:16:26 [pg3] info: Checking for changes in AVRemote
1/29/2023, 20:16:26 [pg3] info: Checking for changes in WeatherBit
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Virtual
1/29/2023, 20:16:26 [pg3] info: Checking for changes in NanoLeaf
1/29/2023, 20:16:26 [pg3] info: Checking for changes in NOAA
1/29/2023, 20:16:26 [pg3] info: Checking for changes in OnkyoAVR
1/29/2023, 20:16:26 [pg3] info: Checking for changes in LiFX
1/29/2023, 20:16:26 [pg3] info: Checking for changes in VirtualButtons
1/29/2023, 20:16:26 [pg3] info: Checking for changes in ST-Inventory
1/29/2023, 20:16:26 [pg3] info: Checking for changes in ATest
1/29/2023, 20:16:26 [pg3] info: Checking for changes in AMINEM
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Roomba
1/29/2023, 20:16:26 [pg3] info: Checking for changes in WeatherLink
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Russound
1/29/2023, 20:16:26 [pg3] info: Checking for changes in TeslaPW
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Rachio
1/29/2023, 20:16:26 [pg3] info: Checking for changes in ST-Nuheat
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Hue
1/29/2023, 20:16:26 [pg3] info: Checking for changes in UnifiPresence
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Holidays
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Sonos
1/29/2023, 20:16:26 [pg3] info: Checking for changes in iAquaLink
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Climacell
1/29/2023, 20:16:26 [pg3] info: Checking for changes in ST-Sonos
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Notification
1/29/2023, 20:16:26 [pg3] info: Checking for changes in WirelessTag
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Volumio
1/29/2023, 20:16:26 [pg3] info: Checking for changes in WeatherPoly
1/29/2023, 20:16:26 [pg3] info: Checking for changes in EnvisaLink-HW
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Bond
1/29/2023, 20:16:26 [pg3] info: Checking for changes in BalboaSPA
1/29/2023, 20:16:26 [pg3] info: Checking for changes in HolidaysGoogle
1/29/2023, 20:16:26 [pg3] info: Checking for changes in OpenSprinkler
1/29/2023, 20:16:26 [pg3] info: Checking for changes in DavisWeather
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Twinkly
1/29/2023, 20:16:26 [pg3] info: Checking for changes in IFTTT-Webhooks
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Wemo
1/29/2023, 20:16:26 [pg3] info: Checking for changes in WeatherFlow
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Ping
1/29/2023, 20:16:26 [pg3] info: Checking for changes in TeslaEV
1/29/2023, 20:16:26 [pg3] info: Checking for changes in BASIRRIGATION
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Backup
1/29/2023, 20:16:26 [pg3] info: Checking for changes in DysonPureCool
1/29/2023, 20:16:26 [pg3] info: Checking for changes in AVServer
1/29/2023, 20:16:26 [pg3] info: Checking for changes in EnvisaLink-DSC
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Govee
1/29/2023, 20:16:26 [pg3] info: Checking for changes in OpenWeatherMap
1/29/2023, 20:16:26 [pg3] info: Checking for changes in BlueIris
1/29/2023, 20:16:26 [pg3] info: Checking for changes in MagicHome
1/29/2023, 20:16:26 [pg3] info: Checking for changes in RainMachine
1/29/2023, 20:16:26 [pg3] info: Checking for changes in MQTT
1/29/2023, 20:16:26 [pg3] info: Checking for changes in BASPOOL
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Acurite
1/29/2023, 20:16:26 [pg3] info: Checking for changes in MyQ
1/29/2023, 20:16:26 [pg3] info: Checking for changes in VenstarCT
1/29/2023, 20:16:26 [pg3] info: Checking for changes in iTach-IR
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Plex-WebHook
1/29/2023, 20:16:26 [pg3] info: Checking for changes in BASGARAGE
1/29/2023, 20:16:26 [pg3] info: Checking for changes in FlumeWater
1/29/2023, 20:16:26 [pg3] info: Checking for changes in VUE
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Caseta
1/29/2023, 20:16:26 [pg3] info: Checking for changes in ShellyRGBW2
1/29/2023, 20:16:26 [pg3] info: Checking for changes in ST-EcoWitt
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Blink
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Kasa
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Kaiterra
1/29/2023, 20:16:26 [pg3] info: Checking for changes in ELK
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Sense
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Somfy
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Netatmo-WS
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Ecobee
1/29/2023, 20:16:26 [pg3] info: Checking for changes in BASAO
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Wake-On-Lan
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Push
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Camect
1/29/2023, 20:16:26 [pg3] info: Checking for changes in SolarEdge
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Meteobridge
1/29/2023, 20:16:26 [pg3] info: Checking for changes in TotalConnect
1/29/2023, 20:16:26 [pg3] info: Checking for changes in MySmartBlinds
1/29/2023, 20:16:26 [pg3] info: Checking for changes in HueEmulator
1/29/2023, 20:16:26 [pg3] info: Checking for changes in Eagle-200
1/29/2023, 20:16:26 [pg3] info: Checking for changes in AmbientWeather
1/29/2023, 20:16:26 [pg3] info: Checking for changes in HoneywellHome
1/29/2023, 20:16:27 [pg3] info: [00:21:b9:02:50:a1_9] 'OpenWeatherMap' installed into ISY successfully...
1/29/2023, 20:16:27 [pg3] info: [00:21:b9:02:50:a1_3] 'DysonPureCool' installed into ISY successfully...
1/29/2023, 20:16:27 [pg3] info: [00:21:b9:02:50:a1_4] 'ST-Nuheat' installed into ISY successfully...
1/29/2023, 20:16:27 [pg3] info: [00:21:b9:02:50:a1_1] 'ST-Sonos' installed into ISY successfully...
1/29/2023, 20:16:27 [pg3] info: [00:21:b9:02:50:a1_2] 'DysonPureCool' installed into ISY successfully...
1/29/2023, 20:16:27 [pg3] info: Waiting for store (false) and isy (true) before starting node servers.
1/29/2023, 20:16:27 [pg3] info: Checking for changes in DSC-IT100
1/29/2023, 20:16:27 [pg3] info: Checking for changes in Roku
1/29/2023, 20:16:27 [pg3] info: Checking for changes in PythonTemplate
1/29/2023, 20:16:27 [pg3] info: Checking for changes in Example-1
1/29/2023, 20:16:27 [pg3] info: Checking for changes in Tuya-Devices
1/29/2023, 20:16:27 [pg3] info: Checking for changes in ATest
1/29/2023, 20:16:27 [pg3] info: Checking for changes in Roomba
1/29/2023, 20:16:27 [pg3] info: Checking for changes in TestTeslaEV
1/29/2023, 20:16:27 [pg3] info: Checking for changes in Example-2
1/29/2023, 20:16:27 [pg3] info: Checking for changes in Notification
1/29/2023, 20:16:27 [pg3] info: Checking for changes in Example-4
1/29/2023, 20:16:27 [pg3] info: Checking for changes in OpenSprinkler
1/29/2023, 20:16:27 [pg3] info: Checking for changes in Example-3
1/29/2023, 20:16:27 [pg3] info: Checking for changes in eISYIR
1/29/2023, 20:16:27 [pg3] info: Checking for changes in Sensibo-Air
1/29/2023, 20:16:27 [pg3] info: Checking for changes in VueTest
1/29/2023, 20:16:27 [pg3] info: Checking for changes in MagicHome
1/29/2023, 20:16:27 [pg3] info: Checking for changes in iTach-IR
1/29/2023, 20:16:27 [pg3] info: Checking for changes in Kasa
1/29/2023, 20:16:27 [pg3] info: Checking for changes in ELK
1/29/2023, 20:16:27 [pg3] info: Checking for changes in Ecobee
1/29/2023, 20:16:27 [pg3] info: *****************************************
1/29/2023, 20:16:27 [pg3] info: Latest PG3 version available is 3.1.16
1/29/2023, 20:16:28 [pg3] info: Starting installed and enabled node servers...
1/29/2023, 20:16:28 [pg3] info: startNs:: DysonPureCool
1/29/2023, 20:16:28 [pg3] info: startNs:: DysonPureCool is valid
1/29/2023, 20:16:28 [pg3] info: startNs:: ST-Nuheat
1/29/2023, 20:16:28 [pg3] info: startNs:: ST-Nuheat is valid
1/29/2023, 20:16:28 [pg3] info: startNs:: OpenWeatherMap
1/29/2023, 20:16:28 [pg3] info: startNs:: OpenWeatherMap is valid
1/29/2023, 20:16:28 [pg3] info: startNs:: ST-Sonos
1/29/2023, 20:16:28 [pg3] info: startNs:: ST-Sonos is valid
1/29/2023, 20:16:28 [pg3] info: checkLicense:: DysonPureCool Valid perpetual license found.
1/29/2023, 20:16:28 [pg3] info: startNs:: DysonPureCool finished update check
1/29/2023, 20:16:28 [pg3] info: checkLicense:: ST-Nuheat Valid perpetual license found.
1/29/2023, 20:16:28 [pg3] info: startNs:: ST-Nuheat finished update check
1/29/2023, 20:16:28 [pg3] info: checkLicense:: OpenWeatherMap Valid perpetual license found.
1/29/2023, 20:16:28 [pg3] info: startNs:: OpenWeatherMap finished update check
1/29/2023, 20:16:28 [pg3] info: checkLicense:: ST-Sonos Valid perpetual license found.
1/29/2023, 20:16:28 [pg3] info: startNs:: ST-Sonos finished update check
1/29/2023, 20:16:28 [pg3] info: [DysonPureCool(3)] :: Starting Node Server - Version 4.0.0
1/29/2023, 20:16:28 [pg3] info: startNs:: DysonPureCool updating database (enabled, timestarted)
1/29/2023, 20:16:29 [pg3] info: [DysonPureCool(2)] :: Starting Node Server - Version 4.0.0
1/29/2023, 20:16:29 [pg3] info: startNs:: DysonPureCool updating database (enabled, timestarted)
1/29/2023, 20:16:29 [pg3] info: [ST-Nuheat(4)] :: Starting Node Server - Version 1.0.3
1/29/2023, 20:16:29 [pg3] info: startNs:: ST-Nuheat updating database (enabled, timestarted)
1/29/2023, 20:16:29 [pg3] error: [ST-Nuheat(4)] :: STDERR: node:internal/modules/cjs/loader:998
  throw err;
Error: Cannot find module '/var/polyglot/pg3/ns/0021b90250a1_4/st-nuheat.js'
    at Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
    at Module._load (node:internal/modules/cjs/loader:841:27)
    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    at node:internal/main/run_main_module:23:47 {
  code: 'MODULE_NOT_FOUND',
  requireStack: []
Node.js v18.12.1
1/29/2023, 20:16:29 [pg3] info: [ST-Nuheat(4)] :: Exit cause code: 1 - signal: null
1/29/2023, 20:16:29 [pg3] info: startNs:: ST-Nuheat starting polls
1/29/2023, 20:16:29 [pg3] info: Starting Node Server Info timer 0
1/29/2023, 20:16:29 [pg3] info: startNs:: DysonPureCool starting polls
1/29/2023, 20:16:29 [pg3] info: [OpenWeatherMap(9)] :: Starting Node Server - Version 3.1.4
1/29/2023, 20:16:29 [pg3] info: startNs:: OpenWeatherMap updating database (enabled, timestarted)
1/29/2023, 20:16:30 [pg3] info: [ST-Sonos(1)] :: Starting Node Server - Version 1.0.7
1/29/2023, 20:16:30 [pg3] info: startNs:: ST-Sonos updating database (enabled, timestarted)
1/29/2023, 20:16:30 [pg3] info: startNs:: DysonPureCool starting polls
1/29/2023, 20:16:30 [pg3] info: Starting Node Server Info timer 0
1/29/2023, 20:16:30 [pg3] info: startNs:: OpenWeatherMap starting polls
1/29/2023, 20:16:31 [pg3] info: startNs:: ST-Sonos starting polls
1/29/2023, 20:16:31 [pg3] info: Starting Node Server Info timer 0
1/29/2023, 20:16:33 [pg3] info: [ST-Sonos 1] :: STDOUT: 2023-01-30T01:16:33.732Z INFO Could not find file /var/polyglot/pg3/ns/0021b90250a1_1/node-sonos-http-api/settings.json
1/29/2023, 20:16:34 [pg3] info: MQTTS: Client Connected: 00:21:b9:02:50:a1_2
1/29/2023, 20:16:34 [pg3] info: MQTTS: Client Connected: 00:21:b9:02:50:a1_3
1/29/2023, 20:16:34 [pg3] info: MQTTS: Client Connected: 00:21:b9:02:50:a1_9
1/29/2023, 20:16:34 [pg3] info: MQTTS: Client Connected: 00:21:b9:02:50:a1_1
1/29/2023, 20:16:35 [pg3] info: [00:21:b9:02:50:a1_1] Set notices
1/29/2023, 20:16:35 [pg3] info: [00:21:b9:02:50:a1_1] Set customparamsdoc
1/29/2023, 20:16:37 [pg3] info: [00:21:b9:02:50:a1_3] Set notices
1/29/2023, 20:16:37 [pg3] info: [00:21:b9:02:50:a1_2] Set notices
1/29/2023, 20:16:37 [pg3] info: [00:21:b9:02:50:a1_9] Set notices
1/29/2023, 20:16:38 [pg3] info: upload successful
1/29/2023, 20:16:38 [pg3] info: node controller on profile 3 already exists, no nodeDef or driver changes detected
1/29/2023, 20:16:39 [pg3] info: [00:21:b9:02:50:a1_3] Set customparamsdoc
1/29/2023, 20:16:39 [pg3] info: node controller on profile 2 already exists, no nodeDef or driver changes detected
1/29/2023, 20:16:39 [pg3] info: [00:21:b9:02:50:a1_2] Set customparamsdoc
1/29/2023, 20:16:39 [pg3] info: node controller on profile 9 already exists, no nodeDef or driver changes detected
1/29/2023, 20:16:40 [pg3] info: [00:21:b9:02:50:a1_9] Set customparamsdoc
1/29/2023, 20:16:41 [pg3] info: upload successful
1/29/2023, 20:16:48 [pg3] warn: ISY Response: [Try: 1] [00:21:b9:02:50:a1] :: [ECONNRESET] :: 8.620693ms - http://192.168.0.10:181/rest/ns/2/nodes/n002_controller/report/status/GV18/1/25
1/29/2023, 20:16:48 [pg3] info: node bef655e on profile 1 already exists, no nodeDef or driver changes detected
1/29/2023, 20:16:48 [pg3] info: node forecast_0 on profile 9 already exists, no nodeDef or driver changes detected
1/29/2023, 20:16:53 [pg3] info: node be95175 on profile 1 already exists, no nodeDef or driver changes detected
1/29/2023, 20:16:53 [pg3] info: node forecast_1 on profile 9 already exists, no nodeDef or driver changes detected
1/29/2023, 20:16:54 [pg3] info: node be8062e on profile 1 already exists, no nodeDef or driver changes detected
1/29/2023, 20:16:55 [pg3] info: node forecast_2 on profile 9 already exists, no nodeDef or driver changes detected
1/29/2023, 20:16:56 [pg3] info: node be950dc on profile 1 already exists, no nodeDef or driver changes detected
1/29/2023, 20:16:57 [pg3] info: node bef6783 on profile 1 already exists, no nodeDef or driver changes detected
1/29/2023, 20:16:57 [pg3] info: node forecast_3 on profile 9 already exists, no nodeDef or driver changes detected
1/29/2023, 20:16:58 [pg3] info: node bef6f3c on profile 1 already exists, no nodeDef or driver changes detected
1/29/2023, 20:16:59 [pg3] info: node forecast_4 on profile 9 already exists, no nodeDef or driver changes detected
1/29/2023, 20:17:05 [pg3] info: upload successful
1/29/2023, 20:17:07 [pg3] info: upload successful
1/29/2023, 20:17:09 [pg3] info: upload successful
1/29/2023, 20:17:13 [pg3] info: upload successful
1/29/2023, 20:17:57 [pg3] info: Successful login by jwagner010
1/29/2023, 20:17:57 [pg3] info: MQTTS: Client Connected: pg3frontend_vzb1C
1/29/2023, 20:18:07 [pg3] debug: MQTT Results: [frontend/system/jwagner010] :: {"pg3LogLevel":{"success":true,"level":"debug"}}
1/29/2023, 20:18:07 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/687d33b3-f471-4b68-9768-7360b3eaa1a5 to broker pg3_broker
1/29/2023, 20:18:14 [pg3] debug: Downloading logfile :: /var/polyglot/pg3/logs/pg3-current.log
I screwed up the packaging.  You'll have to re-install but it should work now.
Go to the node server store, select refresh store.  Then select the node server, click the install button and use the "Reinstall here?" button to re-install.
At work now but I reinstalled remotely and all looks fine, the NS starts and is staying running, I will test it tonight when I get home and keep an eye out to ensure it stays running.
Will also keep an eye out for the PG3 update and test the reinstallation into ISY994i every 5 minute issue.
Again thank you for your help on this, very much appreciated.
@bpwwerI have held off upgrading PG3 to 3.1.17 on my Polisy as I had seen a number of reports showing random node servers not starting. Is it safe to upgrade to 3.1.17 on my Polisy now to see if it fixes the issue of node servers reinstalling into my ISY994i every 5 minutes or should I wait still?
There isn't any functional difference between 3.1.16 and 3.1.17.  One of the library components was upgraded so that PG3 would continue to work with other updates to the OS.
The same for PG3x 3.1.21 and 3.1.22.
I have not made a new release with feature/bug-fix additions for either PG3 or PG3x yet.
