Installing new SSD before ZMatter Installation
In the process of upgrading my SSD before installing ZMatter I noticed the reference slot is in what appears to be the wrong position on the SSD board.  Is this a manufacturing error or can I simply install the board upside down.  I don't want to risk destroying my Polisy.
Ron
Looking at msata ssd on Amazon, they are all oriented like your current polisy one. It's also consistent with USB to SSD adapter you'd need to image new drive. I don't believe your new drive is a manufacturer's error but could be specialty designed for some different applications? You can try and see if it will mount at all, without turning power on. But, honestly, I'd be concerned with heat dissipation when installed upside down. Probably better off getting another one.
Why do you need so much storage on Polisy?
