Eisy and Insteon 2448A7
I have an Insteon 2448A7 USB dongle that I was using with my ISY994 (with a serial adapter). Now I have an Eisy, which is said to natively support the 2448A7 - great! I enable Insteon support, plug in the dongle, reboot, and try to add an Insteon device (at the time I did the migration to the Eisy, I didn't have any Insteon devices on the ISY.) I go through the initial dialog to identify which device I am adding (a leak detector in this case), it tells me which button to push, etc., which I do. Then... nothing. No activity in the event viewer, nothing in the log, nothing on the screen.
Is there a way for me to see if the Eisy is even seeing the 2448A7? What sort of diagnostics can I do?
The Eisy User Guide references a "Restore PLM" option, but I don't see that anywhere. (The page it links to is for the ISY99i, and there is no such option in the Admin that I can find.)
Edited by Steve L
On the configuration page, make sure Insteon support is still selected (did you hit save before rebooting).
Restore Modem (PLM) is under the File menu.
Try Tools, Diagnostics, PLM Info/Status.
Edit: Did you reboot the eisy or just the IoX?  Probably need to reboot eisy.
Edited by gzahar
