IoX & Home Assistant on Eisy
If I install Home Assistant on Eisy will IoX and Home Assistant be able to share the same 2413u Insteon PLM connected to one of the USB ports? or will the two services conflict with each other and fight for the PLM?
Edited by JCBond
Solved by MrBill
you would still need to use Home Assistants Universal Devices integration to bring your Insteon into Home Assistant. You would NOT use Home Assistants Insteon Integration.   If two services were trying to use the modem they would both just be confused.
Has anyone successfully gotten home assistant running on eisy? If so, please share steps
I have not tried as we were advised against doing this.  I current have HA on a RPi 3 and (hopefully) soon on a Yellow Box.
