Message about pending Firmware in eisy logs
I have had a SSH session open to the eisy for the last few days since migrating. (Running 5.5.5)
This was running the following command in the SSH window.
sudo tail -f /var/udx/logs/log
It seems that all the normal package checking with no errors but there a message about needing to update a iwbmt firmware keeps on coming up. It seems that the checks happen about every 8 hours or so.
Message example from this morning.
Sun Feb 12 02:25:15 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: pkg iwmbt-firmware must be upgraded to 20221109
It dosnt seem to be causing any errors but then I dont know if it is supposed to automatically update and then in the future this will cause an issue.
The full update cycle log.
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for updated packages ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for pkg ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for ca_root_nss ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for dual-dhclient ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for bash ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for p5-IO-Socket-SSL ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for git ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for sudo ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for mosquitto ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for libwebsockets ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for e2fsprogs-libuuid ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for c-ares ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for rapidjson ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for mongo-c-driver ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for npm ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for isy ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for udx ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for tpm2-tools ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for dmidecode ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for pg3x ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for grub2-bhyve ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for wifibox ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for xorg ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for xfce ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for drm-kmod ...
Sun Feb 12 02:25:14 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for libbson ...
Sun Feb 12 02:25:15 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for curl ...
Sun Feb 12 02:25:15 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for iwmbt-firmware ...
Sun Feb 12 02:25:15 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for virtual_oss ...
Sun Feb 12 02:25:15 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for virtual_oss_ctl ...
Sun Feb 12 02:25:15 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for ungoogled-chromium ...
Sun Feb 12 02:25:15 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for mDNSResponder ...
Sun Feb 12 02:25:15 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for openjdk8 ...
Sun Feb 12 02:25:15 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for icedtea-web ...
Sun Feb 12 02:25:15 EST 2023|/usr/local/etc/udx.d/static/pkgstat.ops: checking for the availability of updates for libarchive ...
That is normal.  It is not supposed to automatically update.  You have to manually use the Upgrade Packages button on the configuration tab of the admin console.
BUT don't do this now!!  something is broken and you'll likely end up with a system that doesn't work.  I don't have a ETA for when this will be fixed.
