No values in IoX PG3 3.1.17 on IoX 5.5.7
Version: 1.0.11 on PG3 3.1.17 on IoX 5.5.7 isn't providing the counters on the Admin Console anymore...not sure when it stopped working.  Is there a known issue? Any resolution?  Not critical, just curious.  FYI, I have 10 other Node Servers that are working fine.  Restarted the NS several times (which used to work) but still isn't updating the counters.  Total Nodes, Node Server Nodes and Error Log Entries are the only counters displayed.
What happens if you right click on the ST-Inventory node in the AC and select query?  Does it populate the values then?
When I re-installed and start it, I saw the same thing you did, just the total nodes, node server nodes and error log entries populated.  As I tried to debug, I noticed that everything was working but it wasn't sending the other values to IoX which is actually correct for the way it was written.  It should only send values that have changed and none of the values were changing so they were never sent.  A query forces it to send all values.
So I'm not sure if this is a bug or not. It seems to be working as designed, but I'm not sure the design is correct.  A better design might be to always send the values even if they haven't changed.
@bpwwerThe Query worked.  Thanks!  I had tried the discover button both on the AC and on the NS page but that didn't change anything.  Didn't think of trying the query.  Darn it!  I appreciate the response.
