Weatherlink entities not all showing up in Home Assistant
Posted (edited)
Hi @shbatm et al
I have the weatherlink PG3 Node Server running. When I check in Home Assistant only a couple entries show up....
Weather link query, enabled, device communication, and  a sensor, which though enabled  won't let me use it in any cards.
It always changes the name to weatherlink instead of sensor.weatherlink.
Hence it appears some connection is being made between HA and the weather link Node Server info.
As you can see from my screen shots below, there is a lot of info I would like to access in HA. I have reloaded both the integration and restarted HA. Am I missing something? Should I be able to see all in weather link info in HA.
Edited by stevehoyt
If you're using the current core version in Home Assistant then everything will be a state attribute in the single sensor.
One of the changes being made in the testing version is to break these all out into individual entities. If you're wanting to test: look for the Alpha Testing topic here and make sure you enable "Load Node Servers" in the configure options dialog.
      37.3k
      373.6k
