Clip Command and MP3 files
I would like to use the Clip command and play an MP3 file as per the jishi API documentation.  The documentation says the MP3 files should be stored in the static/clips folder, do we have access to this folder?  I did ssh into the EISY and could not find any folders for this node server.
I used to use the jishi API on another server and it worked great for presets etc.  I would like to do the same with the node server.
