Zwave leak sensor questions
I am running the latest versions of PGx and IoX on an easy with a Zmatter USB plugin
I have a Dome water leak sensor
In the AC I have 4 node entries for the leak sensor
The Wake Up node shows Is Awake, Keep, Wake interval at the top of the AC. There are drop downs for setting these values but when I try to set them the Wake Interval never shows a value. It is always blank. Is this normal?
Also, the first node has Water Alarm, Battery Level at the top of the AC screen but the only time I get a value there is when I physically wake up the sensor then do a query in the AC. Just wondering how to get this field to automatically update so that I can be notified of a low battery level.
thanks,
Gary
