Polisy Migration
I started on the ISY to Polisy migration.  I am stuck.  IoX will not detect my serial PLM.  My ISY works fine with the same PLM.  I built the cable myself as I don't have one.  I have searched all over and have come up with the same pin out.
image.thumb.png.49b39c88de58eed0adb776c9e4285647.png This can't be rocket science.  I have built many custom RS232 cables in my life.  I am using the parts as in the picture.  I have continuity between pins (RG45-DB9) 1-3, 7-5 and 8-2.  What gives?  Is the serial port disabled?  What am I missing?
Solved by Techman
It looks like you have your Rx and Tx connections reversed.  Also make sure that Insteon is enabled in your configuration screen.
Let me know if that resolves your issue
Edited by Techman
UDI sells a Serial to USB adapter. To use a 2413S on a Polisy. https://www.universal-devices.com/product/serial-plm-kit/
Don't have any information on the units serial port and if it is live.
I think your pin out may need checking.
From the sheet in the 2413S box. RJ45  Pin 1 to DB9S PC pin 2, RJ45 Pin 7 to DB9S Pin 5 and RJ45 Pin 8 to DB9S Pin 3
Edited by Brian H
Add information
