Upgraded to 1.0.11
I just upgraded to 1.0.11 and as usual checked log after upgrade.  The following was in the in log and as you see said report this:
2023-04-11 12:09:06 error: NS: uncaughtException REPORT THIS!: ReferenceError: use_mosquittio is not defined at MqttClient.<anonymous> (/var/polyglot/pg3/ns/0021b900f1fd_8/node_modules/polyinterface-v3/lib/Interface.js:261:7) at MqttClient.emit (node:events:525:35) at TLSSocket.f (/var/polyglot/pg3/ns/0021b900f1fd_8/node_modules/once/once.js:25:25) at TLSSocket.onerror (/var/polyglot/pg3/ns/0021b900f1fd_8/node_modules/end-of-stream/index.js:44:12) at TLSSocket.emit (node:events:525:35) at emitErrorNT (node:internal/streams/destroy:151:8) at emitErrorCloseNT (node:internal/streams/destroy:116:3) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
