Adding Analog input to a Sonoff Basic, need to read the Sensor Value
Greetings;
Long time no post!
I have a little project, which requires me to read water turbidity and accordingly open/close a sluice. Therea are several approaches to this,  but at first glance, the easiest is to use an existing Sonoff Basic (or SV) and have the ADC port read the value of the turbidity sensor (https://tasmota.github.io/docs/ADC/).
The Tasmota MQTT would then publish the analog reading to tele/Creek/SENSOR . So far so good.
The MQTT node server by @xKing lets me upload a .YAML file, in which I specify all the Sonoff switches I have. An individual entry looks like this:
- id: "Creek"
  type: "switch"
  status_topic: "stat/Creek/POWER"
  cmd_topic: "cmnd/Creek/power"
The above looks just at the status of the Relay and lets me control it.
How do I add the
tele/Creek/SENSOR
to this, so in IoP, I can read the tele/Creek/SENSOR and turn the cmnd/Creek/power ON?
I could write a rule in Tasmota for such a simple task, but eventually I need to integrate data from my Davis WeatherStation into the decision process, so I'd rather get things set up right in the first place.
Cheers!
16 hours ago, TriLife said:
Greetings;
Long time no post!
- id: "Creek"
  type: "switch"
How do I add the
tele/Creek/SENSOR
Cheers!
Follow-up on this:
The same .YAML file has another couple of items in it:
- id: "ClrTemp"
  type: "TempHumid"
  status_topic: "tele/ClrTemp/SENSOR"
  cmd_topic: "cmnd/ClrTemp/POWER"
This answers the first question about the syntax for tele/Creek/SENSOR
the other entry is for a Sonoff 4CH unit:
# QUAD Wine Cellar (TOPIC in Sonoff MQTT CONFIG is "CLR4CH") IP x.120
- id: "ClrCinta" #{1:"Orientes", 2:"Cellar", 3:"Cinta", 4:"Floor"}
  type: "switch"
  status_topic: "stat/CLR4CH/POWER1"
  cmd_topic: "cmnd/CLR4CH/power1"
- id: "ClrFan"
  type: "switch"
  status_topic: "stat/CLR4CH/POWER2"
  cmd_topic: "cmnd/CLR4CH/power2"
- id: "ClrOpen"
  type: "switch"
  status_topic: "stat/CLR4CH/POWER3"
  cmd_topic: "cmnd/CLR4CH/power3"
- id: "ClrClose"
  type: "switch"
  status_topic: "stat/CLR4CH/POWER4"
  cmd_topic: "cmnd/CLR4CH/power4"
So, based on this, I think I'll have to create 2 ids, one for the analog sensor, the other for the relay. Something like this:
# TOPIC in modified Sonoff SV MQTT CONFIG "Creek"!
- id: "Turbidity"
  name: "Creek Turbidity"
  type: "analog"
  status_topic: "tele/Creek/SENSOR"
- id: "Sluice"
  type: "switch"
BTW, the ADC input takes inputs up to 1V only, so a Voltage divider is in order.
I'll update after trials.
On 4/21/2023 at 11:50 AM, TriLife said:
Follow-up on this:
- id: "ClrTemp"
  type: "TempHumid"
  type: "switch"
- id: "ClrFan"
  type: "switch"
- id: "ClrOpen"
  type: "switch"
- id: "ClrClose"
  type: "switch"
- id: "Turbidity"
  type: "analog"
- id: "Sluice"
  type: "switch"
This worked, kind of.
First, the ADC on the Sonoff (3 different units) was given erratic readings. So I ended up ordering a WeMo Mini D1. That worked well.
And with the Yaml as shown, I can get readings of ADC and tue relay in the IoX.
I cannot, however seem to access the ADC to write a program in IoX. Started a separate thread on this. So far no news on how to fix it.
Cheers.
