Backup SD card in ISY?
Solved by MrBill
If you have z-wave run a z-wave backup first.  Admin Console > Z-wave > Backup
Then Admin Console > File > Backup ISY  (this step will save the file to your computer, the saved backup file will include the z-wave backup if you made one above.)
If your MicroSD dies.... Insert a new one (32gb or less, look for the A1 rating).  After booting you must install the apprioriate firmware file first (help > manually upgrade) then after the ISY reboots at then end of that, Restore your backup file.
There is no supported method of making card images to backup or using other software.  I've seen other people say they've had success doing that, but note the only SUPPORTED method outlined above.   I'd follow it in case you ever nned UD support to help... they don't help with image copy methods.
