Can't see ELK node after purchase
New to eisy and just 'migrated' my ISY944i yesterday.  I am trying to get the ELKM1 integration working as I use it for my mobile clients
I purchased the ELK integration from the Node Server Store.  Purchase was successful, as it showed up under my purchases tab.  I checked my dashboard and did not see it on my ISY dashboard.  I checked the log and did not see any reference to that node being started or errros for the node.  I tried to (Re)Install from the purchases screen, but no luck.
Am I missing a step to get this node started?
I did the same thing with OpenWeatherMap and it worked just fine.  I was able to configure and get info to populate in the ISY on my new EISY with weather info.
Here is a screen shot of my dashboard.  I expected to see an ELK node too.
Am I missing a step?
Solved by mdarcy
I did figure it out.  I thought I chose a 'slot' when installing the Elk node.  I did not.  I chose the next open slot during the install process and it appeared on my Dashboard.
