Geofencing to run a program only at night
Greetings,
I've started playing with Geofencing. Quite exciting.
Tested it just turning on a light when I come home. That works well
However, i need that light to turn only between sunset and sunrise the next day.
So I wrote the program Geo-Light
If time sunset-sunrise
Then turn on light
   Wait 15mins
   Turn off light.
And in GeoFence I call Geo-Light...
Except Geo-Light runs whenever sunset comes around🙄 without waiting for me to drive close to home...
Is there a better way then setting a Variable when geofencing is triggered and adding that test in the IF statement of the program?
Cheers.
Solved by Jimbo.Automates
1 hour ago, Jimbo.Automates said:
Just disable the program so it can't run automatically.
But personally I'd just have UDMobile set a variable and add that to your if conditions because you may want to know that for other programs as well.
Sent from my Pixel 6 Pro using Tapatalk
SOLVED!
Thanks @Jimbo.Automates
