What is hubEndpt?
RRoyceus
Go to solution Solved by kewashi,
1 hour ago, RRoyceus said:
What is hubEndpt?
This is the URL that points to the HousePanel.groovy app on your Hubitat box. It will be in a format similar to below
Key = hubEndpt Value = Hubitat endpt in format http://192.168.x.y/apps/api/n
where "n" is an integer number, and x and y are the IP address specifics of your hub. You can find this information after you install the HousePanel.groovy file as a user app on your Hubitat box. Open up a log window and then do the installation. The app information will show in the log. Of you can find it later by just looking at the id number of the app once it is installed. You will also need to give a callback port in the install that is set in the config.
So glad you have it up and running and that you like it.  I've made some updates to fix music devices and a few other tweaks, and I updated the GUI portion of HousePanel to have a few more visual goodies, so if you are using it I would grab an update from the GitHub repo. Otherwise, if you are just using the node server and don't have music devices from Sonos, just keep enjoying the current node server as-is.
      37.5k
      375.5k
