Final Followup logs
@shbatm
As a final followup to the issues we had, I updated HA to 2023.7.1 and your version 16.
I have attached the log files before and after the upgrade from 15 to 16 to show you the "new normal".
The could not communicate with device: 14 7F 2D 1 error I know is an error on my side with Insteon
All looks pretty good to me
Thanks for all your help.
home-assistant_2023-07-07T15-06-57.008Z.log home-assistant_2023-07-07T15-03-02.894Z.log
Edited by stevehoyt
Link to comment
Quote
2023-07-07 05:51:15.339 ERROR (MainThread) [pyisyox] Error parsing language file for node server slot 15, invalid format
Looks like something didn't fully update yet--this is the old error message. Make sure you've fully restarted Home Assistant after updating from HACS. You can double-check the version in your the "/config/custom_components/isy994/manifest.json" file to make sure it says `pyisyox==1.0.0a10` and `4.0.16`.
Nevermind. I had the files flipped.
The "The unit of sensor.xxx cannot be converted to the unit of previously compiled statistics" can be cleared by going to Developer Tools > Statistics and looking for the "Fix" buttons.
developer_statistics.svg
Edited by shbatm
Link to comment
